Old 03-27-2018, 05:48 PM   #1
Professional Texan
TexasBob's Avatar
Chevrolet Trailer Plug
I'm I the only one who thinks trailer plugs on late model Chevy pickups are up side down? If rotated 180 degrees, gravity and the cover latch apply pressure to keep the plug in tightly.
Has anyone tried to rotate this assembly?
ID:	166374   Click image for larger version
Texas Bob
2015 Chevrolet Silverado HD2500 Z71
2013 Prime Time Tracer Executive 2640 RLS
TexasBob is offline   Reply With Quote
Old 03-27-2018, 06:32 PM   #2
I have never tried rotating mine but you are definitely not the only one that thinks they are upside down.
____________________
2017 Silverado 3500 Z71 CC / L5P Duramax/Allison
2018 Grand Design Reflection 311 BHS
2015 Coachmen Apex 259BHSS 50th Anniversary (sold)
rjc1024 is offline   Reply With Quote
Old 03-27-2018, 06:45 PM   #3
Professional Texan
TexasBob's Avatar
I'm hoping someone who has rotated it will reply with athree step process and tell me how easy it is to do.
Texas Bob
Old 03-27-2018, 06:46 PM   #4
raspivey's Avatar
I noticed, but the cover "clicks" into place on the plug firmly enough that I don't worry about it.
Old 03-27-2018, 07:09 PM   #5
I think they probably do that so you can see it better and it is easier to plug into. But it would seem to be upside down. I have seen people put the grounds on the top of the plugs in a house also, I think so it makes contact first when plugging in if the plug is at any angle.
willykel is offline   Reply With Quote
Old 03-27-2018, 07:14 PM   #6
DieselDrax's Avatar
The spring and the lock tab on the plug cover do just fine that way, flipping it over won't make it work any better.
Flip it over and then the text on the covers will be upside down, right now they're right-side up...so...GM says it's not upside down.
2017 GMC Canyon - CCLB, 4x4, 2.8L Duramax, ARE Z-series shell
2013 Shamrock 21SS
DieselDrax is offline   Reply With Quote
Old 03-27-2018, 07:41 PM   #7
Professional Texan
TexasBob's Avatar
Actually it would make it better. Mainly because of the variation of the diameter of the plug. Mine is a little loose and tends to slope down a bit. If the latch were on the top, as they were for a long time, it would hold the plug level.
However if your plug is tight, top or bottom would not matter.
Texas Bob
Old 03-28-2018, 06:52 AM   #8
Flip it and the flat four will be upside down.
2013 Rockwood 2109S
2010 Dodge Ram 1500 Crew Cab 4x4 Hemi
GearHd6 is offline   Reply With Quote
Old 03-28-2018, 08:13 AM   #9
My Ram is 180 degrees from the Chevy’s; it would seem the open cover would be a ‘shield’ from rain when plugged in, to me.
My17Ram is offline   Reply With Quote
Old 03-28-2018, 09:16 AM   #10
NMWildcat's Avatar
I have always had my plugs installed in the bed after market. Had them installed both ways. Works just fine either way and I can't say I prefer one over the other.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
Old 03-28-2018, 10:00 AM   #11
Denver To Yuma In 90 Days
I don't have a problem with mine on the rear bumper of my 2015 Chevy 2500HD.
However, the pigtail on my 5'ver was kinda long when I bought it and once while backing it in a tight turn, the pigtail got caught on the hitch receiver (no ball mount in it) and it ripped right out of the junction box on the king pin.
Blew a bunch of fuses in the truck (under the hood) and in the trailer.
Not a fun day!
Now I run a bungee cord between the two bed hooks to keep the pigtail from dropping that low, even though it is now 10-inches shorter than it was.
JohnD10 is offline   Reply With Quote
trailer
