Old 01-19-2020, 03:18 PM   #1
CLass C towing a CRV honda
Getting a class C RV and need advice on towing a car.
Mmyoyo is offline   Reply With Quote
Old 01-19-2020, 03:49 PM   #2
“Advice on towing a car” is a very broad topic, because you have flat (four-down) towing, dolly towing, flat bed trailer towing, automatic or manual transmission preference, etc. I suggest you first check out this annual guide to dinghy towing: https://www.motorhome.com/download-dinghy-guides/
Then come back with specific questions. It first looks overwhelming, because it is overwhelming. Towing a car is not as simple as towing a trailer.
You mentioned “towing a CRV” in your title. Check the above guides for what model years with automatic transmissions are compatible with flat towing. Late model CRVs cannot be flat towed with their CVT transmission.
2020 Sunseeker 2440DS Ford, Trekker cap, Topaz paint
BehindBars is offline   Reply With Quote
Old 01-19-2020, 04:19 PM   #3
We have a 2014 SunSeeker and tow a CR-V. In fact we have two CR-Vs set up for flat towing. Long story, but we set up the 2013 for flat tow and a couple years later found a used 2012 in great condition already set up with base plate and lights. All I had to do on the 2012 was add the breakaway for my RVI brake. Looking for another daily drive we brought this 2012. CR-Vs work great for us. As mentioned, newer CR-Vs (2015 and newer) can not be flat towed. Not sure what Class C you have but I have seen many CR-vs towed behind a class C. Just need to check GCVW limits. As mentioned also, do diligence in researching make and model of any vehicle you are thinking about towing.
2014 SunSeeker 3050SF
2012 Honda CR-V Toad or
2013 Honda CR-V Toad
UpstateTiger is offline   Reply With Quote
class c, towing
