Originally Posted by bikendan
You need to look at the payload sticker on the driver's door.
"Honda says it’s towing capacity is 5K and cargo 1500."
This statement is a general one and not specific to your particular Ridgeline.
Payload capacity varies between vehicles, depending on trim level and specs. The payload sticker is specific to what the truck weighed when it left the factory.
The 5000lbs towing capacity is only if it has the factory tow package.
But this trailer is better suited than the Rockwood you were previously looking at.
Ok here are the actual numbers. Truck total maximum is 6019. GAWR rear axle 3263. Total payload 1543 minus passenger’s and stuff. So I did weigh the truck with my stuff (tools etc) including full tank of gas and was 4620. Max total combined is 10,031 including truck/trailer. So 6019 (max truck GW) minus 4620 leaves me with 1399 for everything.
Assume 500 hitch weight (specs say up to 600) and me and wife at say 400 (to be safe) equals 900 rolling out the door. That still leaves 200 (to be safe) added cargo or passenger. So if true coachman is say mildly loaded and is 3500 then 3500 plus say 5500 truck total puts my combined at 9k which is 1 k below specs.
So I should be ok and not have a trailer that would be too heavy. Ideas or comments welcome.
