Old 02-06-2020, 06:07 PM   #1
Curt A20 vs Patriot 18K
Just purchased a 2020 Sabre 36BHQ and need to purchase a hitch to pull it with. An independent shop recommended either the Curt A20 or the Patriot 18K and I'm looking for feedback on both to help make the decision.
budthespud is offline   Reply With Quote
Old 02-06-2020, 08:10 PM   #2
Hope you get some replies as these were the same exact two hitches I was recommended at a shop.
Scoob is offline   Reply With Quote
Old 02-06-2020, 08:13 PM   #3
B and B's Avatar
I would look at a Reese 18k . I have had this for 3 fifth wheels. Full clamshell locking mechanism. Full binkley head. Grease it up and quite minimal chucking even on 16,500 lbs.
Old 02-06-2020, 08:45 PM   #4
zs325RES's Avatar
I canít comment on comparing the two, but I got the Curt A20.
Very impressed with the quality, and like that with a simple removal of a large pin, the head comes out easily. The grease zerks are also a plus for maintainance.
2020 SOB - Jayco North Point 387RDFS
2013 Crusader 325RES Touring Edition - SOLD
TV: 2018 GMC Sierra Denali HD CC SRW L5P Duramax
Curt Q20
zs325RES is offline   Reply With Quote
Old 02-06-2020, 10:00 PM   #5
How long have you been using it?
Old 02-07-2020, 12:05 PM   #6
zs325RES's Avatar
Hi Scoob,
Total disclaimer here, I installed it after I put my 5er into storage last fall, so I've not yet had the chance to work it.
I did a lot of research (Amazon has a lot of useful info) and decided on the A20.
I had a Curt Q16 before, and this looks like a much better design.
Curt Q20
Old 02-07-2020, 02:12 PM   #7
DRM796's Avatar
Use to have a Patriot 16K until we upgraded the camper and truck. Now we have the Companion 20k. They are easy to get in and out of the truck. Also never had any problems hitching up. They are made in America with a limited lifetime warranty. I had a small part break, called B&W and in a couple of days had the part in my hands. Excellent service. Had the Patriot for 6 years and the Companion for 2.
2019 Alpine 3700fl
2016 Chevy Silverado 3500HD DRW High Country
"Best money we ever wasted"
2012 Wildcat 313RE traded in 5/2018
DRM796 is offline   Reply With Quote
Old 02-07-2020, 02:45 PM   #8
I have had the CURT 20 SLIDER for 6 years now and been a very good hitch for me. I have only used the slider twice just testing it out since I never had to use it yet. Have towed cross country with it and about 30000 miles towing with it and no problems!
JoeSue is offline   Reply With Quote
Old 02-07-2020, 05:07 PM   #9
Curt A20 vs Patriot 18 K
We went to the Curt/mopar when we got
Our 2018 ram after pulling with a patriot for 5 years & some 30000 mi. The Curt, in my opinion, is a POS. Hard to disconnect and sloppy ride. if I had the $$, I would go back to Patriot.
Lovelandtraveler is offline   Reply With Quote
Old 02-07-2020, 05:42 PM   #10
primo20's Avatar
Another b&w recommendation. Had 2 b&w with a curt in between then. No comparison in quality and performance.
2018 DURANGO 2500 343MBQ | 2019 Silverado 3500 DRW Duramax
primo20 is offline   Reply With Quote
Old 02-07-2020, 05:45 PM   #11
Pretty much the consensus I have heard, I dont know about the OP but I will be going with the Patriot 18K
Old 02-07-2020, 09:29 PM   #12
I have the Patriot 18K - Love it! It was easy to install and adjust the head height so the trailer is level. It is easy to take the head off and then pull the pins to remove the bottom half. Love the locking jaws. Only maintenance is to apply some lithium grease every now & then around the jaws and under the head.
Mike K
2019 Cedar Creek 34RL2 w/disc brakes
2017 GMC 3500 D/A, DRW, 40Gal Aux Tank
USN 76-82
Retired Dept of Navy: Navy/USMC Flt Test Engineer
Splashes3 is offline   Reply With Quote
Old 02-07-2020, 09:59 PM   #13
Riverdude's Avatar
X2
Riverdude is offline   Reply With Quote
Old 02-08-2020, 09:26 PM   #14
Curt 5er hitches
Just for information, Kurt hitches are made in China.
Eddy-g is offline   Reply With Quote
Old 02-10-2020, 05:11 AM   #15
frank4711's Avatar
Yep .... B&W Patriot 18K as good as it gets.
Frank & Cindy--- (SOB) 5th Wheel ---2019 Ram 3500 Cummins 6.7 SRW 4x4 8' bed--- Payload 4394------Remi & Sage camping pups---TST 507 TPMS ... B&W Patriot 18K---3.73 axle ... Predator 3500---2019 48 days ---2020 28 days Camping
frank4711 is offline   Reply With Quote
Old 02-21-2020, 12:08 PM   #16
Curt Q16
I have had the Curt Q16 for a year now and seems to work fine. Easy to hitch up and easy to lube. Only ďcomplaintĒ I have is it seems to have a lot of slop when taking off from a stop. I think itís pretty normal but still kinda worrisome..
Dkdickerson is offline   Reply With Quote
Old 02-22-2020, 10:45 PM   #17
i did the b&w puck system for ram 3500. its the 20k, its a beast
Ram36BHQ is offline   Reply With Quote
Old 02-23-2020, 12:29 PM   #18
mwheue's Avatar
I have owned and used both curt and b&w models you are asking about. The B&W is by far quieter and easier to remove if needed. It is a heavier hitch to lift out, but quality!
mwheue is offline   Reply With Quote
Old 02-24-2020, 09:50 PM   #19
I have the 18k Patriot and love it. Have never used a Curt so can't compare but after seeing the B&W history abd knowing the quality of their products I am glad to have a B&W hitch.
ADJ423 is offline   Reply With Quote
