07-23-2022, 09:26 AM
Do I need a weight distribution hitch?
I have a 2020 Toyota Tundra Platinum with 2W/4W drive. I also have a factory towing package on it and according to the owner's manual, I can pull 9800 pounds. I have purchased a travel trailer (Rockwood Roo) and the empty weight on it is 5639 pounds. Tongue weight is 738 pounds. Based on speaking with others, I would not pull it with tanks. When I hitch the trailer, the back end of my truck drops a bit. I have not measured how much it drops. I pulled it 400 miles from the dealer to my house with no sway issues and no problems. I get a weight distribution hitch, and do I need sway control? I appreciate your thoughts.
07-23-2022, 09:32 AM
My opinion is yes, you should have a weight distribution hitch.
It’s an absolute necessity if your vehicle’s rear axle weight when loaded is greater than the gross axle weight on your vehicle’s door jamb sticker.
Hook up to your camper and go to the nearest truck stop to weigh your rig on their scales.
07-23-2022, 09:37 AM
Very definitely YES...
you need a WDH...
start shopping at etrailer dot com and watch some youtube videos before making the best decision and educate yourself...
2014 Shamrock 183
07-23-2022, 09:59 AM
You should get a WDH as well as sway control for your setup. I would strongly suggest some research on your part, due to the many type of WDH's and sway control, to determine what is best for your case. I would look at WDH's and weather they allow backing up, some do and some do not. I would also look into sway control, you will not NEED it until it to late. Ounce of prevention type of thing.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
07-23-2022, 10:03 AM
Past Tow vehicle but still own: 2017 Ford Expedition XLT EL factory tow package. Added towing mirrors, 10 ply tires on separate rims, sumo springs, larger rear sway bar.
Current tow vehicle: 2020 Ford F350 Lariat supercab
4x4. 7.3 gas. 4,400+lb payload capacity.
2021 Cherokee Greywolf 23MK
Equalizer 1,000lb WDH
07-23-2022, 10:04 AM
My opinion is yes. It will help stability and performance in those West Texas winds.
22 Freedom Express 257BHS
19 F-150 3.5 Max-Tow
07-23-2022, 10:05 AM
Yes - to both questions.
2007 Sierra 2500HD Duramax | ECSB
2012 Rockwood Minilite 2104 - Purchased 08/2012 - Sold 07/2022
2022 SOB 29' 5th wheel - purchased 09/2022; 400w solar on roof; 150w suitcase kit; 206ah LiFePO4; 2k inverter; boondock ready
07-23-2022, 10:12 AM
these are false numbers... your trailer will NEVER be empty again
add your normal camping gear, a battery and propane and your tongue weight will go up as will the total trailer weight...
https://youtu.be/w9Dgxe584Ss
2014 Shamrock 183
07-23-2022, 10:57 AM
I don't know about Toyota, but Ford specs on my F150 for weight carrying hitches (non weight distributing) have a max tongue weight of 500 lbs. Over 500 lbs should be on a weight distributing hitch.
Note that the reason for WD is to maintain appropriate load on the front axles of your vehicle, not issues with sway. Without the correct weight ratio between front and rear axles, your vehicle steering can be seriously compromised. If your truck is noticeably squatting, you probably need WD.
Sway control is a totally separate issue. Any towed trailer can and will sway under the "wrong" conditions, speed being a major contributor. Somewhere on this forum is a thread with a guy who got into a flat spin when his popup trailer started seriously swaying and he lost control.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
07-23-2022, 12:18 PM
Do I need a WDH?
If the tongue weight of the trailer approaches or exceeds the hitch weighting of the vehicle, then YES, you do need a WDH. It would also be advisable to add a sway control bar as well.
Bob
07-23-2022, 12:42 PM
Yes, you need a WDH. Read the owner's manual towing section, it will say it's required for that amount of tongue weight.
Also post a pic of the truck's payload capacity sticker, on the driver's door. The sag may be from exceeding that number. Tundras are infamous for poor payload capacities.
07-23-2022, 12:52 PM
Bob
No.
You need a wdh when the manual for the tow vehicle says you need it. (some vehicles don't need one up the maximum rating on the hitch)
...and if the trailer exceeds the hitch 'weighting' of the vehicle (I assume you mean rating) it is too heavy for the vehicle. A wdh doesn't make it ok.
24 Ram 3500 CC/SRW/LB/50 gal tank/CTD
2024 XLR 31A LE
07-23-2022, 01:22 PM
Someimes Re- member
I tow a ±5,000 lb trailer with a 2022 Tundra (Previously with a 2004 Tundra). Check your Truck Specifications, it probably shows that you are limited to 500 or 700 lbs on your Hitch Receiver WITHOUT a WD Hitch, or considerably more WITH a WD Hitch.
I use and HIGHLY RECOMMEND the Andersen WD Hitch, It is easy to install, easy to hitch/unhitch, provides Sway Control, is easy to adjust for more or less Weight Distribution, and DOES NOT REQUIRE REMOVAL to back-up.
When towing my Trailer with the Andersen Hitch I barely know the trailer is there, NO SWAY when passing or being passed by a big rig or in side winds, and NO TROUBLE backing into tight camp sites. It uncouples from the truck with the removal of ONE PIN, and raising the hitch form the ball, very simple.
2021 E-Pro E19FBS
250 AH LiFePO4, 190w Roof Solar, 200w Portable Solar, 1kw Inverter, 12v Refrigerator, many Mods
2022 Toyota Tundra, 3.5L V6 Twin Turbo w/Tow Pkg, Rear Air Suspension, Andersen Anti-Sway WDH
07-23-2022, 02:20 PM
Direct copy from the 2020 Toyota Tundra Owners Manual:
Reference 4-1 Trailer towing
"● If the gross trailer weight is over 2000 lb. (907 kg), a sway control
device with sufficient capacity is required.
● If the gross trailer weight is over 5000 lb. (2268 kg), a weight distributing hitch with sufficient capacity is required."
2023 Explorer ST-Line w/Tow package
2021 Surveyor Legend 19RBLE
2018 Haulin 6 x 12 Cargo Trailer by Forest River
2017 Laredo 325RL Sold
2016 Vengeance 29V Sold
1970 Yellowstone Used as down payment for first house
07-23-2022, 04:16 PM
It's amazing what information can be found in your vehicle's owners manual.
07-24-2022, 01:44 PM
4way sway control
Get the Equal-i-zer brand with 4 way sway control with the optional nylon inserts. The most popular hitch of all time OR one of the good copies like Anderson. Sway is one of the main reasons of rolled over trailers. Especially when a big gust of wind hits the side and it all just flips on it's side. These hitches are as good as the $2-3000 hitches and eaiser to get parts for down the line. Best bang for the buck!
07-24-2022, 07:29 PM
Thank you.
Thanks for all the advice. I will get a wdh with sway control. Nice to be able to rely on experienced campers.
07-24-2022, 08:55 PM
X2 loved my equalizer 4 point. Bought it to keep my trailer straight on my 3/4 Ram kept it until I got rid of TT. Towed a much heavier TT with my 2014 Tundra. Never could have done it without the WDH. Onside note just 60 or so miles west of you, traveled the lots in these parts
2022 Chevy 3500 Diesel SWD
2022 Columbus 329 DVC
07-25-2022, 08:44 AM
Yes, you probably need both weight distribution and sway control. I vote again for the Andersen hitch. It takes care of weight distribution and sway, is very easy to hook/unhook and easy to adjust. I use one with a 7K lb. trailer and easily get the weight transfer I need, it controls sway and "porpoising" way better than than my old round bar WDH.
07-27-2022, 01:53 PM
X2 for the Andersen. I used it on my Roo 19 and now on my Imagine 2800BH.
Hobienick
2022 Grand Design Imagine 2800BH
2020 Rockwood Roo 19 (Sold Jul 2022)
2012 F150 SuperCrew Ecoboost
