Old 06-10-2020, 01:31 PM   #1
Do I need a weight distribution hitch?
Hello. Newbie here. I just bought a Geo Pro 19BH. It has a dry weight of just over 3000lbs with a hitch weight of 360. The CCC is 772lbs. My truck is a 2020 Sierra 1500 AT4 with a towing capacity of 9200lbs. The truck manual says I don’t need a WDH below 7000lbs. Any thoughts on if I actually need one.
bigevilcat is offline   Reply With Quote
Old 06-10-2020, 01:39 PM   #2
007matman's Avatar
Some will say no. I would say yes.
I used one with a pop-up and it made a big difference. Is it required? Probably not. Will you have a better (and safer). towing experience if you use one.. yes.
007matman is offline   Reply With Quote
Old 06-10-2020, 01:46 PM   #3
Chris Pastuzyn's Avatar
Welcome from New Jersey, I would agree with 007Matman 100% Definitely will be a better towing experience especially on longer drives, You don't need a crazy expensive one ,I saw on another post Harbor freight had one.
Chris Pastuzyn is offline   Reply With Quote
Old 06-10-2020, 02:08 PM   #4
bikendan's Avatar
Originally Posted by bigevilcat View Post
Hello. Newbie here. I just bought a Geo Pro 19BH. It has a dry weight of just over 3000lbs with a hitch weight of 360. The CCC is 772lbs. My truck is a 2020 Sierra 1500 AT4 with a towing capacity of 9200lbs. The truck manual says I donít need a WDH below 7000lbs. Any thoughts on if I actually need one.
Please don't use fictional brochure/website dry weight numbers, they are fantasy numbers.
Use 13% of the trailer's GVWR for a ballpark loaded tongue weight, puts you at 500lbs. Add the fact it's a single axle trailer and over 20ft long, YES you should get a WDH.
I suggest a Fastway E2 WDH.
And you need to look at your truck's payload capacity, not its towing capacity.
Equalizer WDH
Old 06-10-2020, 02:16 PM   #5
BigH's Avatar
Folks around here have an unnatural attraction to a wdh...I'll post the unpopular truth.
A wdh becomes necessary when it removes enough weight off of the steering axle that it effects handling. Your truck was tested using SAE J2807. If your manual says you don't need one it is a complete waste of time and money provided you properly load the trailer...keeping weight forward of the rear trailer axle and keeping your tongue weight high enough should be a perfectly stable tow. -There is no chance I would buy a wdh before properly hooking up and loading up the trailer to test it out...
17 Chevy 2500 DC Long box Gasser Z71 4.10
18 Vengeance 28V
BigH is offline   Reply With Quote
Old 06-10-2020, 02:23 PM   #6
Just as confused as you
Scrapper's Avatar
Those dry weights are for an unloaded trailer, without battery(ies), no water in the fresh water holding tank, and empty LP tanks. Batteries can weigh 60 to 110# each depending on the size and type. Water weighs 8.3 lbs per gallon. A 20# LP tank weighs about 18 lbs empty and holds 4.6 gal of liquid propane, when full the 20# tank becomes around 35 lbs, if you have two that will be 70# on the hitch. Add to those any clothing, dishes & utensils, blankets, bikes, games and toys for the kids, chairs, outdoor rug and anything else you want to carry with you.
Once loaded your hitch weight can be over 500 lbs. There is a sticker on your trucks receiver and also listed in your Silverado 1500 owners manual that says if your gross hitch weight is over 500# a WDH is required even if the rear of the truck doesn't sag. When reading the owners manual be sure you are understanding that all the builds from 1500 to 3500 are included. Be sure you have the right model and drive train when referencing the charts.
On top of that single axle trailers are prone to sway, especially when going down grade or being passed by big rigs. Meeting a big rig at highway speeds on 2-way highways will also induce sway.
Take a look on https://www.etrailer.com/faq-how-to-...ue-weight.aspx. A low cost WDH with built-in sway control can be found at Harbor Freight for around $200.
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Scrapper is online now   Reply With Quote
Old 06-10-2020, 02:35 PM   #7
BigH's Avatar
Originally Posted by Scrapper View Post
... your Silverado owners manual that says if your gross hitch weight is over 500# a WDH is required even if the rear of the truck doesn't sag.
I think your 500lbs is off unless something changed...
If his manual says its not needed below 7000lbs that would be a minimum of 700lbs without a wdh not 500lbs
18 Vengeance 28V
Old 06-10-2020, 03:40 PM   #8
Scrapper's Avatar
You are correct the manual says in the chart that the limit is 700#. The sticker on the receiver hitch says Weight Carrying 500#, Weight Distribution 1200#. You may have to drop the spare tire to see the sticker.
Richard & Jill
Old 06-10-2020, 05:29 PM   #9
My door sticker says ...
GVWR=7100
GCWR=15,000
RGAWR=3800
Curb Weight=5750
Max Payload=1350
SAE J2807 conventional TWR=9000
Max Tonge Weight =900 lbs.
Old 06-10-2020, 05:36 PM   #10
cboss's Avatar
Bottom Line: Get a WDH! You will be happier and safer.
I would not even think about towing our camper without a WDH.
Forget all the numbers, just get one!
Craig & Cath
2018 2902WS Rockwood Ultra Lite
2017 Ford F250 Lariat, 6.2 gas
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2016(retirement): 837
cboss is offline   Reply With Quote
Old 06-10-2020, 05:37 PM   #11
jrk341's Avatar
That AT4 package really eats into your payload.
TV:2019 F350 6.7L Diesel
RV: 2018 Coachmen Apex 249RBS
jrk341 is online now   Reply With Quote
Old 06-10-2020, 05:50 PM   #12
Multi-Slacker
I am in the WDH camp, for sway control if not also for weight distribution. Note that used WDHs are available albeit generally too heavy to ship.
2017 Forest River Sonoma 280RKS
2018 Silverado 2500 HD 6.0L, 4:10 rear
CurtPutnam is offline   Reply With Quote
Old 06-10-2020, 06:56 PM   #13
There is one other option. If you are truly within spec on your truck using real world numbers then try towing without the WDH. If you find it uncomfortable then get the WDH.
Hobienick
2020 Rockwood Roo 19
2012 F150 SuperCrew Ecoboost
hobienick is offline   Reply With Quote
Old 06-10-2020, 09:52 PM   #14
It sure does. My 2019 Silverado 1500 LTZ has a payload capacity of 1910 lbs.
2019 Silverado LTZ 1500 6.2L 3.42 Max Trailering Package
2018 Freedom Express 192RBS
2016 Silverado LTZ 1500 5.3L 3.42
2015 Jeep Wrangler Rubicon 3.6L 4.10
2020 KZ 130RBSE
AlaskaErik is offline   Reply With Quote
Old 06-10-2020, 10:05 PM   #15
X2 you are within specs take it out and see how it handles. My TT needed one regardless of the size truck I towed it with 150 thru a 350. For the Tundra and 150 I need the weight distribution or I would have dragged my bumper. For the 2500 and 350 it was for sway control.
moose074 is offline   Reply With Quote
Old 06-10-2020, 10:13 PM   #16
Cant deny you should try without and see, but hereís my experience.
I have a 2013 f150 ext cab.
Sold 172t rpod and bought a 2020 geopro 19fbs.
Towing it home (empty)from the dealer with a single group 24 battery - was a nice weight and tow for the truck.
Then for a test... I swapped out to dual 6v GC batteries, loaded my storage (front on this model) with my camp gear and put generator and another 50lbs at the rear of the truck bed.
I then hitched up and the front end of the truck rose 1 1/2Ē. This is still without water in the fresh tank and a real life load in the box.
Needless to say I picked up a fastway e2 with 800lb bars and now it rides nice loaded to go.
Those of you who should have WDH and donít, should also aim your headlights lower so others arenít blinded by your headlights.
darb is offline   Reply With Quote
Old 06-10-2020, 10:26 PM   #17
X3 You don't absolutely need it, but I would get one.
2205S Rockwood
F 150 Lariat 3.5 Ecoboost Fx4 Max Tow
Equalizer WDH
flyflotrtim is online now   Reply With Quote
Old 06-11-2020, 04:17 AM   #18
BigH's Avatar
You didn't have a choice...your owner's manual says a wdh is required at that tongue weight.
18 Vengeance 28V
Old 06-11-2020, 06:03 AM   #19
IchLiebeBier's Avatar
My first camper, a popup, weighed about that much. The camper manual specifically stated to NOT use a WDH. I was told at the time it was because the frame couldn't handle the stress. Make sure you check for that warning with the camper.
I'm surprised that your manual says 7K for WDH. My Ram 2500 says above 5K. Weird.
With that being said, if you get a Fastway E2 hitch you'll also get sway control built in. And with that hitch you could back up without having to get out and remove the sway bar (which you would have to do with a friction bar). I bent one once because I forgot to remove it.
2019 Heritage Glen LTZ 272RL
2018 Ram 2500 CTD
IchLiebeBier is online now   Reply With Quote
Old 06-11-2020, 06:21 AM   #20
hack522's Avatar
X2
hack522 is offline   Reply With Quote
hitch, weight, weight distribution hitch
