07-28-2017, 10:32 AM
#21
Originally Posted by spock123
About 1/2 to a quart. It's only when pulling the camper that I have noticed it
Trade it.
You know you're looking for a reason to. Just go do it. I wouldn't!!! But you are Jonesing for it, so just go do it. Don't leave all that pile of cash to those kids!!
FROG AR-0019-242
07-28-2017, 10:54 AM
#22
This bulletin reflects what I've read on every diesel forum, acceptable oil use is 1 quart for every 100 gallons of fuel. I think most of us use far less than that. And every diesel engine consumes some amount of oil, I don't care who makes it. Read your manual and manufacturer's bulletins.
https://gm.oemdtc.com/2603/02-06-01-...h-6-6l-duramax
The only time I notice any oil consumption is on a 1000+ mile trip while pulling the fiver. I don't use synthetic (didn't like the extra engine clatter we heard), so we change oil every 3000 while pulling, every 5000 if not.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
07-28-2017, 12:19 PM
#23
Originally Posted by RB19RR
True....Never measured it, but just about fills the two jugs plus a bit of a quart the new oil came in.
Rotella synthetic every 10-12k miles.
It's like having a 30 gal drum strapped under your engine. I'm sure there is loss, but I'm not taking time to measure it.
07-28-2017, 01:05 PM
#24
Originally Posted by Crusadernoob
Wait a minute, it's a 2012 3500HD SRW? Yeah, those things are known for oil consumption, where did you say you would trade it in? I'll meet you there!
By the way, what color is it?
3500HD SRW LT extended cab with B&W hitch, with a 100gal fuel tank and truck is RED
07-28-2017, 01:17 PM
#25
How often should the air filter be changed?
Spock, get a K&N cleanable filter. I've had mine for about 8 years. I clean it about every 6 months or so, depending on use. Works out cheaper than replacing with OEM filters over the years. And it's a better filter all the way around.
07-28-2017, 01:33 PM
#26
Now you did it. Get those guys that swear a K&N ruined their engine! I have one on all 5 of my vehicles, two of which are cold air kits! They are full of you know what!
07-28-2017, 02:00 PM
#27
Woohoo...off to the filter and oil type/brand races!!
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
07-28-2017, 02:06 PM
#28
I have a 2006 Duramax with 137,xxx miles and noticed at my oil change interval around 8,000 miles it's a tad low on dipstick. Never concerned me.
Just got my last oil sample test back and engine oil is within specs at 8,000 miles and engine is healthy.
2018 Refection 311BHS
2011 Wildcat 32QBT (SOLD)
2006 GMC 2500, Airsafe 20K hitch, Air Lift Loadlifter 5000 air bags with Air Lift WirelessONE compressor, EFI Live
Jack of all trades, Master on none
07-28-2017, 02:11 PM
#29
K&N burnt down my house, made my wife leave me, caused a 10 hour traffic jam, ruined the economy, raised gas prices. I could go on....
BTW...I've never tried one.
07-28-2017, 02:47 PM
#30
I would still bang it out on a bench.
Actually that's is a very big no no wix filiter put out a bulletin not to tap an air filter in any type of manner, it can cause damage to the filter u able to be seen by the naked eye, if you want to try and clean use air at 5psi and blow from clean to dirty side.
K&N recomend to clean thier air filters every 50k or annually
I have to add approximately 1/2gal between oil changes every 10000 miles
2016 wildwood x-lite 241qbxl
being jurked down the road by the beast 2007 Dodge ram 2500
5.9 cummins g56 Trans southbend clutch and a smarty
07-28-2017, 04:19 PM
#31
Well I guess my Silverado is alright, I thought maybe something was wrong on the trip to Alaska. It's good to know everything is alright with the oil. Truck pulls camper great. I usually change the oil myself. Thanks to all
07-29-2017, 06:25 AM
#32
115,000 miles is nothing on a diesel engine and 1 quart of oil between changes is nothing to worry about. Give it clean air and monitor it for increased oil usage.
07-29-2017, 04:31 PM
#33
I get tired of reading that also. I've had one on my Cummins for 7 years. Clean it once or twice a year. I use the k&n cleaner/oil and do it exactly the way the directions say. Everytime I clean it, I wipe the intake tube with a white paper towel and look and my turbo impeller ....always spotless.
Jason and Billie
2018 F-250, 6.2L
2011 Prime Time Crusader 320RLT
07-29-2017, 05:17 PM
#34
I have one on my Hot Rod, over two hundred thousand miles on that filter.
07-30-2017, 06:41 PM
#35
I've got 101,000 on my 2011 Ford 6.7. I use 5w40 synthetic. I base the oil change interval on the recommendation from Blackstone Labs. As of the last test report they recommended 6500. That could change but right now that's my oil change interval.
I send a sample to Blackstone each time I change oil. 80% of the hours on this engine are towing. It uses about 8-12oz between oil changes. I keep the level on the top line of the stick up to a time I get ready to change the oil. Blackstone asks for your oil consumption when you submit the test report. I use the Archoil additive. I'm not pushing it on anyone. Blackstone can see the Archoil additives in the oil sample.
I've never owned that particular engine but I've owned a couple of other trucks with diesel engines. Some use a little more oil than others. I see you have a lot of good advice from other Duramax owners.
I seriously doubt you have a problem. That's low mileage for a gas engine these days and really low for a diesel. Send a sample to Blackstone Labs. I am always impressed with the detail of their test reports. They keep track of the previous tests on your engine and look for trends that indicate something is going wrong.
https://www.blackstone-labs.com/free-test-kits.php
I would not be afraid to buy a 'well cared for diesel' with 100K miles. In fact I did once and it was a great truck.
Kenh
08-02-2017, 01:32 PM
#36
Retired
I wouldn't hesitate for a second to put one on any carbureted engine... They're a great filter...
Problem I have is I possibly will be one of those guys who will over oil the filter and end up with a gummed up MAF.... so it's a dry filter for any FI engine for me.
2014 Chevrolet Silverado 3500 LTZ CCLB DRW D/A - Rancher Grille Guard - Transfer flow 40 gallon Toolbox/Tank Combo - Line X - Edge Insight
2015 Palomino Sabre 33CKTS - Platinum Edition - Progressive Industries EMS HW50C - JT Strong Arm Stabilizers - Ground Control 3.0 - 320 Watt Solar with 2000 Watt Inverter
08-02-2017, 01:45 PM
#37
Retired
What climate are you primarily driving in with 5w40 year round?
I'm gathering by the slight consumption your oil sample doesn't have any fuel dilution?
If my memory is correct and I don't know about Fords but that era of Duramax's (LMM) didn't have a ninth injector when it regen'd so there was some dilution. Because of that Amsoil recommended changing the oil sooner than their specs said???
08-02-2017, 04:13 PM
#38
Not over oiling is the key. More is not better. Just enough to evenly coat. 75k w/ k&n (150k total) on a turbo diesel engine and not one indication that oil has made it past the filter.
Jason and Billie
2018 F-250, 6.2L
08-02-2017, 04:17 PM
#39
On my 05 5.9 cummins, I change oil at 10k. I have never added oil between changes but I do use about a qt or 2 between changes comparing what I drain to what I add.
Jason and Billie
2018 F-250, 6.2L
08-02-2017, 04:32 PM
#40
The problem with the K&N filter is people over oil them and its ruins the MAF sensor . Sometimes a simple cleaning will fix the sensor sometimes it needs to be replaced . Also a K&N lets a lot of dirt through . I run a AC Delco for that simple reason . On off road stuff like my Toyota I love my K&N's but never in my super sophisticated Diesel engine . If you look at the latest CAI systems most of them use a dry filter now .
TV:GMC 2500HD Duramax
TT: 2015 Wildwood 21rbs
