03-26-2020, 12:05 PM
#41
Originally Posted by AlaskaErik
Blind spot warning does not work with a trailer on the 2019 Silverado/Sierra 1500. When you plug in the 7 pin, you get messages in the DIC indicating that blind spot warning and rear cross traffic alert are disabled.
Amazing how GM got so far behind RAM and Ford on the electronic tech side. The 2008 debacle put them behind in my opinion.
03-26-2020, 10:07 PM
#42
Herschel
Originally Posted by SailorSam20500
As far as I know, GCWR is NOT individual truck specific. GCWR is NOT printed on my door stickers. GCWR is relatively clearly listed in the appropriate model year tow guides. FWIW, my 2019 SC 145WB with 3.5 EB and 3.55 gearing is 18,200lbs. What WILL be different for each truck is the Cargo Capacity (payload) printed on the yellow door sticker. CC is VERY dependent on trim level and specific added options.
Ford Trailer Tow Guides starting with MY 2004 are available for download here (quick find with Bing or Google):
https://www.fleet.ford.com/towing-guides/
I am not familiar with the abbreviations for your 2019: "SC 145WB". Could you translate for me? Your GCWR of 18,200 is impressive. This is a F-150 model? But, I am wondering how GCWR could not be truck specific. Could you explain that for me? Each truck has it listed in the towing guides, don't they? I got interested in GCWR when I realized that figure was a little less than the total for truck, plus cargo plus towing totals. I was left with the impression that you can carry a lot of stuff and you can tow a hunk of stuff, but when you try to carry and tow, you got to trim it back a little for the total weight. Hence the GCWR. I am wrong about this? I know I am drifting off topic, but you got me wondering about this stuff.
Puma 26-RLSS travel trailer
27,000 miles towing, 61 weeks camping, 2010-2019
2007 Ram first ten years; 2020 F-150 Lariat >>>>
03-26-2020, 10:27 PM
#43
Not my place to answer on behalf of the other poster, but what I think it means is "Super Cab, 145" Wheel Base"
-Qwkynuf
2003 F150 Supercab 4x4, tow pkg, 3.55 gears
2020 Flagstaff Micro Lite 21DS
03-27-2020, 12:51 AM
#44
Or Super Crew.
03-27-2020, 12:52 AM
#45
Originally Posted by babock
Or Super Crew.
You're right. I was thinking Super Crew, but typed Super Cab - probably because that's what my truck is, so it's habit...
-Qwkynuf
03-27-2020, 01:08 AM
#46
Could be either. Both are made in a 145" wheelbase.
03-27-2020, 01:31 AM
#47
145 inch wheel base = 5.5' short bed.
2019 Silverado LTZ 1500 6.2L 10 Speed 3.42 Max Trailering Package
2018 Freedom Express 192RBS
2022 Highland Ridge Open Air Lite Range 17BH
03-27-2020, 12:22 PM
#48
That's with the Super Crew. With a Super Cab it's 6.5' long
03-27-2020, 09:28 PM
#49
Herschel
So, it looks like I will be waiting for a 2018 Ford F-150 Lariat with 3.5 Eco boost equipped with BLIS and a trailering package, which will give me a GCWR well over my current 13,000 (2007 RAM 5.7 Hemi), to come within my price range. Thanks fellows. This has been very helpful. I'll keep watching the prices; if it looks doubtful, I may give an after market system (with its limitations for trailering) a try, but we'll just have to see.
03-30-2020, 07:40 PM
#50
Not everyone uses their turn signal when changing lanes.
Well, sorry if I'm missing your sarcasm, but they sure as hell should. I find it really selfish when people don't signal because THEY know where they're going. It's not like you only need to signal if you're going to cut someone off. If people don't signal when changing lanes (BEFORE you start) then they do not have a right to complain about a feature that relies on the fact that you are supposed to signal lane changes. [/rant]
Travel Trailer: 2004 Flagstaff 25LB
New Tow Vehicle: 2017 F-150 3.5 Ecoboost, supercrew short bed FX4 Lariat
Old Tow Vehicle: 2009 Silverado 2500HD 4x4 Ext. Cab Short Bed
Travel Pooch:Sophie the Sato - Cats: Rhody and Hazy
2018:22nights / 2019:31Nights / 2020:18Nights
03-30-2020, 07:47 PM
#51
ram 1500
I have a 2019 ram 1500 crew long box with a GCWR of 17000lbs and trailer blind spot and as soon as you plug the trailer in its learning its length on the first turn either than setting your brake pressure is the only thing you have to adjust.
03-30-2020, 08:35 PM
#52
Other posters pretty much nailed my truck. 2019 F-150 Super Crew 145" wheel base (short bed), 10 speed transmission. 3.5L Ecoboost engine. Platinum level trim, 20" wheels, 3.55 rear differential, Max Tow package (not max payload), 36 gallon fuel tank.
GCWR and GVWR are both design numbers. All manufacturers and now posting thiese numbers based on the industry standard requirements that have been published. Influencing both numbers are the frame desgin, power train design, what axles, brakes, etc are used. Subtracting from how much trailer you can pull are the options put on the truck - increasing the trucks weight.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
