01-20-2018, 08:30 PM
Grammar Pedant
Equalizer Spring Arm Very Difficult to Move
I have a new Equalizer (Equal-i-zer) WDH. The dealership set it up and it seems to be done correctly. Level stance when loaded and it works great ... super stable in windy conditions. Really love the performance.
It's super noisy, even though I got the polymer pads, but this is a common issue that I've read about (and I haven't lubricated it at all, yet).
The problem I'm having is swinging the spring arm (as they are called) in and out. This has nothing to do with clearance. I have raised up the hitch assembly far enough. But, just swinging them out or pushing them in is a near impossible task. One side is stiff and the other side is stiff x10. As luck happens, I only played with one side at the dealership.
If I'm not describing this properly, please check 2:33 (pulling arm out) and 5:20 (pushing it into place) of the official instructional video:
He moves the arm back and forth with some resistance, but it's not so bad.
He even states that it shouldn't be that difficult. If it is, raise it up a bit. But, as stated, I'm already plenty high enough ... it's not catching on anything. The friction (at the head, not the L-bracket) is simply way too much. The one side, in particular, takes 2 men and a boy to move it into position.
I read the manual, but found nothing in it that would suggest a means to make this easier (or harder).
Is there anything I can do, or do I just have to man-up, live with it, and hope it loosens up a bit with use?
Thanks.
Former RV: 2018 Rockwood Mini Lite 2504S
01-20-2018, 09:03 PM
DW's 401(k) Plan
I used my Equal-I-zer hitch for over 8 years on 2 different tow vehicles/2 different trailers. Had to re-adjust everything when I bought the 2nd tv/tt.
Never had an issue after everything was torqued to specifications for either setups. Could it be the one side is over-torqued? Is there any rust between the bar end and head at the pivot point?
As far as noise, I kept everything tight and painted. If the bars or L-brackets started showing signs of wear and/or rust, I would re-coat with black paint. And if a pivot point called for lube, it was lubed.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
01-20-2018, 09:19 PM
I had the exact same problem. Got my dealer to replace the hitch.
cliffy49
2018 Catalina Trail Blazer 26TH
2021 Chevy Silverado Custom 2500HD
01-20-2018, 09:26 PM
Grease the hitch head at the arm pivot points every trip. Also a light coat on the ball. If the old grease get cruddy, clean it off and reapply.
2015 F-250 FX4
01-20-2018, 09:37 PM
I had very tight bar sockets when I got my first equalizer. Their tech support said the nut could be loosened some to make it easier to move them. The main thing I was told is that the lock washer stays compressed and that they are torqued evenly. All it took for me was less than an eighth of a turn to get them to where I could move them readily (but still be tight).
01-20-2018, 10:15 PM
Failure is my business
The vertical bolts that the arms pivot on set the anti sway tension. Try loosening them and see if it frees up.
Current vehicle list: 17 RAM 3500 4x4 Cummins Aisin 4.10, 24 Cedar Creek 40CBK
01-20-2018, 10:38 PM
Our spring bars were very hard to move when new. They loosened up with time. Did not have to do anything to them.
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Gill" 2022 RAM 2500
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
01-21-2018, 01:20 AM
Dealer may have over torqued the bolts.
01-21-2018, 08:13 AM
Loosen the socket bolt nut. The resistance from the sockets provide the sway control so keep that in mind. I torque mine to 55 ft lbs. Every 500 miles I also loosen the nuts so the sockets turn freely, wipe down and then lube the top and bottom of the sockets, then retorque.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
01-21-2018, 04:03 PM
There should be a sticker on the head showing the proper torque for the socket bolts. Make sure they are torqued the proper amount. The sticker on my current 1000/10000 hitch says 65 ft-lbs. On my prior 600/6000 hitch, the sticker said 45 ft-lbs. Equal-i-zer also recommends in the owner's manual to lubricate the friction surfaces in the hitch head and sockets. There is a diagram in the manual showing where to lubricate.
2018 Grand Design Imagine 2600RB
2019 Chevy Silverado 2500HD 4x4 LT Crew Cab, Vortec 6L V8, 4.10 Rear Axle
Equal-i-zer 1,200/12,000# Hitch
01-21-2018, 04:07 PM
Grammar Pedant
Thanks for the responses. From what I can tell, those vertical "socket" bolts are not part of the setup and installation. There is no reference to them that I saw in the manual and there shouldn't be a point at which the dealer or anyone else touched those things. They don't even show up in the parts diagram on pg 4 of the manual -- they're physically represented in the diagram, but they're not given a call-out number, part number, or name.
However, I will be taking a hard look at them when I next play with the trailer.
Again, I appreciate everyone taking the time to offer ideas on how to adjust this.
01-21-2018, 04:14 PM
Yes. I was told not to touch those bolts when I asked about it when I had this same issue. Was told the brackets holding the spring bars will start moving easier as they get used and they have.
01-21-2018, 05:44 PM
If you have the E4 hitch the pivot bolts are a maintenance item. That should be oiled lightly and torqued. On my 12k hitch the spec is 50 to 60 ft pounds. This is covered in the manual.
The excessive noise is most likely the tension bars not being pararell to the frame members. Adjust this by raising or lowering the L brackets. If not pararell the bar slides on one edge of the L bracket and screeches when it moves, like a bow on a violin string. Very loud! Once this is adjusted then adjust the pressure by adding or removing washers.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
01-21-2018, 05:48 PM
The older equalizer hitches had a torque spec for the bar pivot bolts. The current ones do not. I have the 12,000 version and have absolutely no noise and the arms pivot easily. I grease the head where the arms pivot every trip,that is the key. I used to have a 10,000 lb version that was very noisy; I never greased that one. That one also had a torque spec for the pivot bolts. I used that same spec to torque the pivot bolts on my new one. I’d say to do two things- grease the head and see if the noise subsides and the movement of the bars gets easier. If not, then loosen, then retorque the pivot bolts, but keep greasing.
Good Luck
Rick
01-22-2018, 04:39 PM
If you are not sure you want to take advice here, call Equal-I-zer tech support. They are fantastic.
If you want to take advise here, loosen the bolts, grease, and re-torque. I betting the are over-tightened, and it seems unevenly as well. You are correct that whoever setup probably did not touch those bolts, but were like that from the factory. Then again, maybe the dealer did touch them.
Personally, I loosen them as part of annual maintenance. I completely remove them, wipe off any grimy grease, apply new grease, and reinstall. Is this required? No. It is required to grease them periodically, and if you have not, that's probably where the noise is coming from.
This being a new unit, they will free up some. But you absolutely should not need 2½ men to move them. That's too tight, and you should adjust.
01-22-2018, 04:49 PM
When I had my Equalizer on our former Work & Play, I switched trucks so I had to make some adjustments to the hitch set-up. I got pretty good at it. Had it set up much better than the dealership did.
If you want to, swing by the house and we'll get it right. Its only about 1700 miles.
01-23-2018, 07:12 PM
The 'sockets' are on the hitch head, not the L brackets. The socket is what the bar goes into and these are the bolts being discussed that you need to adjust.
03-20-2024, 03:08 PM
Mike C.
I just bought a new Rockwood TT and have the dealer installed Equal-i-zer. I am having the same issue. It takes 2-3 people or 1 person using a 6 foot pry bar to move the bar sockets into the proper position before inserting the spring bars. I spoke with tech support and they said it would loosen up over time. This thread is a few years old. Does anyone have updated info on how to resolve this issue?
Thx!
03-20-2024, 03:53 PM
Enjoying Life
Thx!
Put the bars in before moving. They will be your leverage to move into position.(check torgue of socket bolts if above 65, loosen) Use your tongue lack to raise the trailer so the bars are just below or above the L bracket shelf and move in to the shelf. If you are slightly below use the lift bar to bring it up. Grease the sockets on the contact points(a light amount works fine). Check torgue again, 1k/10k unit should be close to 65 ft/lbs. Get the L bracket pads to help with noise.
2022 Rockwood 2109S
Previous: Rockwood 2608WS, 2608BSD
2006 Durango HEMI
