Old 04-10-2020, 02:58 PM   #1
equilizer vs Curt true trac
I have narrowed it down to 2 weight distribution hitches. The equalizer 4 or the Curt True trac. What is the opinion of RV'ers out there in regards to these 2 systems. I am towing a 2018 Shasta revere 32ds with a 2015 Chevy 2500HD.
Thanks for the feedback.
firetom is offline   Reply With Quote
Old 04-10-2020, 05:59 PM   #2
Lins's Avatar
I didn’t have the True Trac, but I did have a simpler Curt system and did not like the quality of it. I currently have an equalizer which does fine, you just need to clean and grease the moving parts occasionally. Also retorque the socket bolts occasionally.
2007 Rockwood 2701SS
1953 GMC 9314
1982 GoldWing Interstate
Lins is online now   Reply With Quote
Old 04-11-2020, 08:17 AM   #3
Thanks for replying. I had a change of mind in the time I posted and buying hitch system.
I ended up buying Reese Steadi-Flex. The price was reduced substantially and it was similar to the Curt True Trac. I will every one know how it works out.
Old 04-11-2020, 04:52 PM   #4
I see that you went a different direction already, but for those reading I went with an E4. It's made in the USA which was important to me, I've sent a couple emails to the company which were responded to within an hour which is excellent customer service in my opinion.
Simple, no chain links to count. All it needs is some grease and a retorque as Lins said.
2019 Rockwood Mini Lite 2509S
2018 F-150 XLT FX4 Crew Cab 3.5EB 3.55
Equal-i-zer E4 hitch 1,000lb bars
nights camped 2019: 42. Miles towed: 4500.
2020: 2 300
pilotpip is offline   Reply With Quote
Old 04-12-2020, 12:46 PM   #5
Can you run 3800 fps?
I agree about the Equalizer 4 point... Easy to use, Easy to Setup, Easy to maintain and the Factory Customer Service has been fantastic compared to others in the RV industry. I would buy another if I needed one.
SniperDroid is offline   Reply With Quote
