05-07-2020, 08:03 PM
Excessive DEF fluid use in 2020 Silverado 3500
I recently took a 2,000 mile round trip. 500 miles into the trip light comes on and says I have 900 miles left on def, at 1,0000 miles light comes on and says I have 200 miles left. The check engine light came on before I got home. OnStar ran a diagnostic and found a injector problem. My 2012 Silverado 3500 could go 5,000 miles before needing def. Truck is in the shop now. I’m calling GM customer support tomorrow. Has anyone else had this problem
05-07-2020, 08:27 PM
My neighbour had new injectors installed. They dumped it and bought a Ford after a year. He had a 2018.
05-08-2020, 04:20 PM
DEF or fuel injector? It’s a bit early to see if many 2020 owners are having the same problem. Some 2019+ Rams had excessive DEF usage and there’s an update for it. Relax, it’s under warranty.
2007 Rockwood 2701SS
1953 GMC 9314
1982 GoldWing Interstate
05-09-2020, 05:42 AM
I feel your pain. I have a 2019 Chevy 3500 w/ Duramax and it uses a lot more than the 2015 that I had before this one. With the 2015 I could pull our 42’ Cedar Creek 2000 miles and put on another 4000 miles and never have to add DEF. With our 2019 we pulled the Cedar Creek 1700 mile and get a low DEF warning and dumped in 5 gallons of DEF and it still wasn’t full. I have talked to others with the similar problem. 2 dealers have looked at it and have said that it’s a different motor and it uses more DEF. If feel that this is not right, but don’t know what else I can do. 2015 got over 1200 mpg of DEF, 2019 gets 338 mpg in my same trip from Wisconsin to Arizona in combined driving with and without trailer.
05-09-2020, 06:37 AM
Our Ram Diesel, 2016, virtually burns no def driving without the fifth wheel. Likely 1000 miles per gallon.
However, towing a #15,000 fifth wheel it burns a gallon per 200 miles.
Def at truck stops is inexpensive and convenient.
05-09-2020, 01:38 PM
My 19 Silverado 3500 had a recall for excessive regens. Def usage seems to have normalized similar to my 17 ram. But it was using lots before the reflash without towing.
2023 Rockwood 2911BS | 2023 Silverado 3500 SRW Duramax
05-09-2020, 02:03 PM
I had the same problem while heading to California. Started putting diesel additive in every fill up and my def usage dropped 75 %
05-09-2020, 02:11 PM
Just curious. Why do you suppose putting diesel additive in every fill up reduced your DEF usage by 75%? What kind / brand of diesel additive are you using?
My 2020 GMC 3500 diesel barely uses DEF when I'm NOT PULLING our 19,000 lb Riverstone. But,.... when I am PULLING the 5th Wheel is uses a LOT of DEF! Our friends who have a 2018 RAM with the Cummins Diesel say the same thing. "Sips" DEF when NOT pulling. "Gulps" DEF when pulling. Wonder why?
Greg W. Johnson
West Des Moines, IA
2020 Riverstone 39RKFB
2022 GMC 3500 HD Denali Dually
05-09-2020, 03:52 PM
Neighbors had the same problem with a 2019 GMC 3500. 3 weeks at the dealer waiting on parts and all is fine now.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
05-09-2020, 03:57 PM
So you know "what parts" were involved, what was the cause and what was fixed? Thanks.
Greg W. Johnson
West Des Moines, IA
05-09-2020, 04:17 PM
def
X2 on the Ram, we get very close to the same distance for def.
RockinH Bill
2019 Silverback 37RTH
2014 Shadow LQ 3 horse select
2015 Ram Laramie DRW
2012 Kaw Concours
05-09-2020, 08:27 PM
Just a thought:
Maybe the US Truck Makers are afraid of the EPA doing a Dieselgate job on them (like VW) and changed the metering profile for more DEF at higher engine loads.
05-09-2020, 11:48 PM
I pull a Riverstone 34 sle with a Ford F 350 and I surmise that the diesel fuel out west is maybe a lower grade and does not burn as clean as in the more populated areas of the states! So when I started using more fuel additive my def usage went down. Like everyone else, my def usage goes down when not pulling.
05-10-2020, 06:02 AM
Keep in mind that DEF usage is proportional to fuel usage. I have never done the math to be able to give numbers, but I DO know my DEF usage goes up significantly when I'm towing. Also, I was shocked to find my new 2018 3500 was doing regens every 260 miles compared to my 2014 that did regens every 500 miles or so. I've been told that the latest DMax generation was programmed to do shorter duration regens more frequently. Don't know if that's true. I recently got a recall notice relating to regens and DEF usage but don't know if the reflash will change things. I'm in the Keys working, and the nearest Chevy dealer is 60 miles away. A visit to the dealer will have to wait a bit.
05-10-2020, 07:01 AM
Wow after listening to you people I will hang on to my pre DEF diesel.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
05-10-2020, 09:00 AM
This forum just makes things sound complicated. Cummins says DEF use is about 2% of fuel consumed, so obviously you will use more while towing. I do not use nearly as much pulling as others are stating on here. We’ll leave home on a full DEF tank and need to put one 2.5 gallon jug in on an ~8,000km trip. The tank will be low-ish when we get home. DEF is also available almost anywhere and you get plenty of warnings (note: plural) as it gets too low, at least on the Ram. I personally like the clean exhaust smell - I get enough diesel exhaust smell working around helicopters everyday.
1953 GMC 9314
05-10-2020, 09:21 AM
2013 GEORGETOWN 351 DS
It is very sad they have managed to take a great product (Diesel Engines) and make them junk. I will never purchase any new Diesel powered vehicles.
GRV
We love to Roam
2013 Georgetown 351 DSF
2017 Honda Civic
05-10-2020, 09:58 AM
Regens and DEF consumption are unrelated as DEF isn’t needed for regens, sounds like the update may have had multiple fixes or changes with it but whatever the case glad it helped.
2017 GMC Canyon - CCLB, 4x4, 2.8L Duramax, ARE Z-series shell
2013 Shamrock 21SS
05-10-2020, 10:04 AM
Two separate systems but DEF usage should increase if the engine is using more fuel to perform a regen.
1953 GMC 9314
05-10-2020, 10:15 AM
Not really because regens on GMs use a fuel injector in the exhaust to raise EGTs. DEF/SCR is used to reduce NOx that is created under high cylinder temps and pressures. Injecting fuel into the exhaust for regens doesn’t create the same condition, as such there shouldn’t be an increase in DEF consumption during regens.
It’s not just pure fuel consumption that determines DEF consumption. The exhaust will have NOx sensors that measure NOx before and after the SCR system to know if it’s working right and how much DEF is needed, much like O2 sensors are used to make sure gas engines aren’t running too rich or lean and to make sure the cat is working properly.
2013 Shamrock 21SS
