Old 12-19-2019, 07:02 AM   #1
frank4711's Avatar
Exhaust Brake On/Off/Auto/Full?
How do you set your exhaust brake when just driving vs towing .... options are off or auto or full .... clearly on in the mountains .... Thanks
Frank & Cindy--- (SOB) 5th Wheel ---2019 Ram 3500 Cummins 6.7 SRW 4x4 8' bed--- Payload 4394------Remi & Sage camping pups---TST 507 TPMS ... B&W Patriot 18K---3.73 axle ... Predator 3500---2019 48 days ---2020 28 days Camping
frank4711 is offline   Reply With Quote
Old 12-19-2019, 07:11 AM   #2
BandJCarm's Avatar
Don't have a "Full". Not sure what that is.
Exhaust brake always ON when towing. So is Tow-Haul Mode.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 12-19-2019, 07:18 AM   #3
on my 2018 Ram 3500, I run it on full when I am able to get some open road. In traffic running it on full is kinda jerky because I have the manual transmission. So If Im gonna be in stoplight traffic for a bit I have it on Auto so it only comes on when touching the brakes.
I have Off/On(full)/Auto
Full comes on anytime I release the gas, Auto only works by applying the brakes.
Ron and Kathy
2019 Cougar 369BHS 5'VR
2018 Cherokee Limited 304 BH (Traded)
Joyfully Towed with a 2018 RAM 3500 6.7 CTD
ronheater70 is offline   Reply With Quote
Old 12-19-2019, 07:21 AM   #4
lesptr's Avatar
Hmm. On mine (F350) the option is on, or off. Iíve gotten to the point of turning it on whether towing or not.
2017 Coachman Chaparral 336TSIK
2015 F350 6.7
lesptr is offline   Reply With Quote
Old 12-19-2019, 07:28 AM   #5
Ejs4029's Avatar
Frank, Check out this thread.
http://www.forestriverforums.com/for...ke-194614.html
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30C
Ejs4029 is offline   Reply With Quote
Old 12-19-2019, 09:08 AM   #6
frank4711's Avatar
Originally Posted by Ejs4029 View Post
Thanks .... good info
Old 12-19-2019, 10:07 AM   #7
I run with EB on full all the time. With all the stop and go traffic in town, I run with tow/haul as well. Open road I turn it off. And of course, when pulling the trailer it's in tow/haul.
Jen Solomon
Retired with not enough time on my hands
2013 Crusader 260RLD, towed by 2014 Ram Laramie 3500
JSolomon is offline   Reply With Quote
Old 12-19-2019, 10:30 AM   #8
Ram forum chatter seems to suggest the EB also helps engine warm up.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 12-19-2019, 10:32 AM   #9
Lins's Avatar
It's also in the manual. I can confirm it helps significantly at very low temps - it gives the engine a (small) load.
And I prefer using full exhaust brake.
2007 Rockwood 2701SS
1953 GMC 9314
1982 GoldWing Interstate
Lins is offline   Reply With Quote
Old 12-19-2019, 11:35 AM   #10
X2.. Big help on cold days. I go out, start it, put EB on, after afew seconds it goes into fast idle. I have the manual tranny so if its really cold, I also put transfer case in Neutral and put tranny in gear and let out clutch and get the fluid moving and warmed a lil also.. helps solve the cold notchy shifting a lil.
Ron and Kathy
Old 12-19-2019, 11:39 AM   #11
Jim34RL's Avatar
For Non-RAM users the exhaust brakes on these trucks (RAM), I believe operate differently than Ford and GM.
When I was at the TDR rally for the new 2013.5, 6.7L Cummins that was introduced that year. The exhaust braking was explained to us there. I am going by memory from 2013 so, if I get something wrong don't flame me to bad.
“The new exhaust braking feature will be a two-stage exhaust brake instead of the single stage as on the earlier 6.7L engines 2007.5 to 2102 trucks. The smart exhaust brake feature (Ram’s name) will have a full mode to slow the truck/trailer fully. The next stage is a lighter application mode to maintain the set speed with the cruise control.” Either will work but the full mode will be harsher if you do not have a trailer attached.
This should all be explained on how to operate in the O/M guide for your year of truck. I know my exhaust brake was explained in my O/M manual for my year of truck!
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 135K+miles
Old 12-19-2019, 12:10 PM   #12
Broken Toe
Cowracer's Avatar
Auto. Only use full as a sort of "Force it on" situation, or under high-traffic, stop-and-go situations.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016
Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
Cowracer is offline   Reply With Quote
Old 12-19-2019, 11:17 PM   #13
KSH
I use auto for the most part. It switches to full with tow/haul turned on.
KSH is offline   Reply With Quote
