Old 08-28-2019, 10:00 AM   #1
WoodLark-SC's Avatar
F-250 or F-350
I have been thinking of upgrading from my Ram 1500 to a 3/4 ton even though the Ram pulls my Rockwood 2503s just fine.
I had specifically been looking at Ford F-250s with the 6.2l gas engine. I ran across a fantastic deal on an F-350 SRW equipped exactly as I would like. It is at a far better price than any F-250 I have found.
What are the pros and cons of going to the F-350? (I know it is way overkill for my trailer.)
2013 Ram 1500 CC 4WD
2019 Rockwood 2503s
WoodLark-SC is offline   Reply With Quote
Old 08-28-2019, 10:07 AM   #2
Cons: It's a Ford, and you have a Dodge. LOL. Just kidding here...
Some states classify a F-350 as commercial, and there may be a fuel or
heavy duty tax on that truck.
Pros: You have a truck then that would be more than capable of pulling
anything you have now, or might get in the future.
You are getting a deal on a heavier truck, which may end up holding its
value better, especially if not putting the wear and tear of pulling an RV,
like you would with a half ton truck.
Me, the wife, & 2 daughters (12 & 7yrs old)
2019 Palomino Puma QBSS
2015 Silverado LTZ / Z71 w/ many upgrades
GXPWeasel1 is offline   Reply With Quote
Old 08-28-2019, 10:08 AM   #3
007matman's Avatar
Con: A little rougher ride when unloaded.
Pro: more capacity, future proof of you decide to go larger, for me insurance was cheaper, lower price, etc.
The trucks will be virtually identical for maintenance costs, engine options, etc.
I'd go for the 1-ton any day.
007matman is offline   Reply With Quote
Old 08-28-2019, 10:16 AM   #4
Ejs4029's Avatar
I'd go for the one ton.....When I bought my 2015 RAM 2500 after my Chevy 2500HD was stolen back in 2015 I was living in CA and it was cheaper yearly to register a 3/4 ton so I went that route...Fast forward to 2017 and due to unforeseen circumstances we moved to NC luckly for me my 3/4 is still good for my needs but I would have preferred a one ton if I had to do it all over again.
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30X
Ejs4029 is offline   Reply With Quote
Old 08-28-2019, 10:34 AM   #5
My Ram 2500 has been awesome. But, like others state, going to a 350/3500 will give you plenty of room to grown. Don't know what year of vehicle you are looking at, but the 2500 suspension gives a much better ride than the 3500 due being coil vs leaf spring.
2019 Forester 3011 DS
2015 Jayflight 28BHBE (sold)
2015 Ram 2500 Megacab 4x4 6.4 L Hemi 4.10 gearing
"Is this a game show?"
sugarray40 is offline   Reply With Quote
Old 08-28-2019, 11:21 AM   #6
clarkbre's Avatar
The F350 over the F250:
Pros:
Payload. The F250 will likely have a 10,000 GVWR whereas the F350 will have closer to 11,000 to 11,500 GVWR. If the trucks are identical, they will weigh about the same but the F350 will have an additional 1,000 to 1,500 carrying capacity.
Cons:
A little rougher ride in the F350
Equal:
Tow ratings
No matter what, stepping up from a 1/2 to a 3/4 or 1 ton will be the biggest jump.
In searching for my Super Duty, the "2" or "3" on the fender really was the least concern. The upgrade from the F150 was seeking a higher payload and the 6.2 for simplicity and longevity. So far, I've been extremely happy with the truck. My payload increased from 1529 to 2766. Fully loaded with all occupants, firewood, bikes and the trailer hitched, there's still 900 left of payload....the F150 was over by about 300 lbs. A F350 would have netted me even more capacity.
2017 Forest River Surveyor 247BHDS...
...Tugged by a 2016 F250 XLT FX4 SuperCrew, Shortbed 6.2L, 4wd, 3.73...
...Joined with a Husky Centerline TS 800-1200lbs WDH
clarkbre is offline   Reply With Quote
Old 08-28-2019, 11:52 AM   #7
Chuck_S's Avatar
Why a pickup truck at all if all you want is a tow vehicle? The 2503 has a GVWR of roughly 6600 pounds and something like my Expedition with the 3.5 EcoBoost engine will handle 9200 and not breathe hard towing this trailer.
If you need a pickup truck a F150 Supercrew (assuming you need the seats) EcoBoost can be factory equipped to tow at least 11,200. And no embarrassment in driving a diesel or Dodge.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 08-28-2019, 12:08 PM   #8
Grammar Pedant
67L48's Avatar
1 tons riding rougher than 3/4 tons is largely outdated conventional wisdom ... akin to outdated beliefs on 1/2 ton capability. Most likely, the ride will be within suspension tolerance stacks of one another. The 1 ton will likely have an extra leaf in the rear spring pack which most people would be hard-pressed to detect.
In fact, the eerie similarity in the 3/4 ton and 1 ton builds these days form the foundation for many 3/4 ton drivers to consciously ignore their payloads. The argument states that frame, axles, suspension (other than 1 leaf), and other stuff is all the same ... thus my 10,000 GVWR 3/4 ton is really a 11,500 GVWR truck. OK, but that also means that it's going to ride the same! Can't have it both ways. It can't be the same truck but then drive more smoothly than a 1 ton.
3/4 ton is a Class II truck at 10,000 GVWR. 1 ton is a Class III truck at >10,000 GVWR. Depending on where you live, how your truck is registered, and how your insurance responds, there can financial penalties to the 1 ton you may want to avoid.
In my case, there are no penalties. My 1 ton cost $40 more than the identically equipped 3/4 ton. My 1 ton cost $30/year more to insure. Easy choice. 1 ton.
Because of outdated conventional wisdom, 3/4 tons may actually be easier to sell in the aftermarket. 1 ton is too much truck. 1 ton is a bigger truck and more difficult to drive. 1 ton rides rougher. 1 ton is more commercial. And, so on. None of those things are true any more, but people think in those terms a lot.
To me, it's a very short list of pros and cons associated with a 1 ton:
Pro: Highest rated capabilities all around
Con: Potential pitfalls with a Class III truck
Former RV: 2018 Rockwood Mini Lite 2504S
67L48 is offline   Reply With Quote
Old 08-28-2019, 12:10 PM   #9
Sham183
mopwr4me2003's Avatar
Just do it! Little rough riding like some have said but if the price is right might as well. If you ever upgrade your TT in the future you will not have to really worry about much as far as pulling and your weights. So might as well get it [emoji16]
mopwr4me2003 is offline   Reply With Quote
Old 08-28-2019, 12:18 PM   #10
SlowrideHD's Avatar
-- Chuck
I'll see you in the mountains....then we'll see who is embarrassed!!!! Ha!
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
USS Pyro AE-24 WestPac MM2 '71-'75
SlowrideHD is offline   Reply With Quote
Old 08-28-2019, 12:19 PM   #11
Think ahead to the future. I went F150 to a Chevy 1500, to a GMC 2500HD Duramax..............and now I'm driving a 2019 Chevy Colorado. We kept thinking..."we'll go bigger and bigger and bigger. NOPE. selling the TT, already sold the GMC and ended up going smaller.
TheWolfPaq82 is offline   Reply With Quote
Old 08-28-2019, 12:31 PM   #12
Gsykora's Avatar
I had a 2014 F350 SRW Platinum edition Powerstroke and it was an awesome truck. Surprisingly smooth, actually as smooth or smoother than the Ram 1500 Hemi I traded in. Unfortunately it was totalled and I upgraded to an F350 dually Platinum edition Powerstroke. It too is an awesome truck but it does ride rougher than the single rear wheel truck.
George & Nancy, Allen, Texas
2015 F350 CC, DRW, LB, Platinum Edition
2018 Cedar Creek 36CK2
Gsykora is offline   Reply With Quote
Old 08-28-2019, 12:45 PM   #13
007matman's Avatar
-- Chuck
Embarrassment of driving a Diesel? On what planet?
Old 08-28-2019, 01:49 PM   #14
Brake is on left
The Evil Twin's Avatar
My $0.01 (the other penny got taken in taxes ):
I looked at both trucks before I bought. I own a 250 PSD with the plow package now. The deal was better on the 250, and after a little research I discovered that the only difference between my 250 and the 350 I was looking at was the contact spring on the rear leaf packs. The front springs are the same as the 350 w/o a plow package. Had I found a 250 with the camper package (slide in, not tow) the rear springs would have been the 350 leaves but my GVWR would still be 10k. So.... with that, the higher price tag on the 350, higher registration fee on the 350 and Hydroboost steering on the 350 I opted for the 250. With that said, I will likely be spending $600 on some air bags soon enough to take out some squat on my 250 when loaded to near GVWR.
My point in all this: the difference between the 2 trucks in nominal and with a few optional accessories, negligible unless towing commercial where you will get weighed.
The Evil Twin is offline   Reply With Quote
Old 08-28-2019, 02:52 PM   #15
jrk341's Avatar
This is exactly why I bought a 1 ton. After the first tow with it I am very happy with my decision.
TV:2019 F350 6.7L Diesel
RV: 2018 Coachmen Apex 249RBS
jrk341 is offline   Reply With Quote
Old 08-28-2019, 03:26 PM   #16
I will have to check into the tax differences, but I think 3/4 ton and 1 ton are treated the same in South Carolina if they are not used as commercial vehicles.
I see no embarrassment in driving either diesel or Dodge, but I want gas, and I simply prefer the Ford over Ram.
Right now, it looks like the only real drawback to the F-350 I found is distance; it is about 1,000 miles from my home. I'll have to look at some others to see if I can find one closer to home that is as good a deal.
2019 Rockwood 2503s
Old 08-28-2019, 03:41 PM   #17
Sham183
If you have a local dealer that you trust or deal with they can do a dealer locate and a dealer trade. Let the dealer do the work. If you know exactly what you want and are firm in your price of what you will pay they will get it for you.
Old 08-28-2019, 04:00 PM   #18
mjbenedict's Avatar
My current 2015 Ford F150 has spent more time at the garage than the last three Dodges I owned. I’m going back but others that have switched to Dodge may tell you same. As far as going to any 1 ton, the heavy duty part will be great for towing but you may be doing overkill and could be hit with more costs in yearly registration fees and much higher replacement part costs. It should wear slower but brakes, etc are much more cost.
2020 Dynamax Isata 5 36DS 4X4 (Super C)
2020 Ram 1500 Limited
Sold: 2015 Rockwood Ultralite 2604WS
No longer mine: 2006 Rockwood Roo 23SS
All pop-up and tent camping before...
mjbenedict is offline   Reply With Quote
Old 08-28-2019, 06:01 PM   #19
I have now had two Ram 1500s, a 2008 and the 2013. As far as the engine and transmission, both have been totally reliable. It's the "little things" that drive me nuts:
The 2008 would spray gas back at me every time I tried to fill it (finally fixed after multiple dealer visits.
On Both trucks, the center brake light leaked into the cab creating puddles under the back seat (again, finally fixed).
On the 2013, the door locks randomly go crazy. The electric locks will lock only the driver door and the tailgate. ($900 to fix and not guaranteed to solve the problem).
I am just hoping Ford will be better.
2019 Rockwood 2503s
Old 08-28-2019, 07:58 PM   #20
Retired JSO's Avatar
Our old 2016 6.2 with 3:73 rear likes to shift down and scream on much of any incline including Florida panhandle hills with 8500 low profile Work and Play while turning out 8 mpg at 65 mph.
Retired JSO is offline   Reply With Quote
f-350
