06-20-2021, 10:25 PM
#21
Originally Posted by NJKris
The ford manual specifically states run 91 octane when towing. There are some posts i read prior to trip and although some debate the consensus seemed to be to go with the manual. It was more expensive and i am really not sure if it made sense but why would they call it out in the ford manual?
06-20-2021, 10:41 PM
#22
Not sure what year model you have, but my 2013 states to use 87. It is a 5.0 and not the 3.5 EB.
2019 Wolf Pup 16FQ - bought new 3/2020
2013 F150 5.0 STX SCab 4x4 SB/3.55 rear/tow pkg./36 gal. tank/1695 Payload/7350 GVWR
Andersen Hitch
06-20-2021, 10:50 PM
#23
2018 EB
06-20-2021, 10:54 PM
#24
Originally Posted by Plan Man
2018 EB
Ok. Well you would have different requirements than me.
I would certainly follow the manual recommendations.
Andersen Hitch
06-20-2021, 11:04 PM
#25
Many truck manufacturers suggest higher octane when towing.
2022 Chevy 3500 Diesel SWD
2022 Columbus 329 DVC
06-20-2021, 11:18 PM
#26
I drive my 2017 Ford Expedition XLT EL 4x4, 3.5 Ecoboost V6 towing our 2021 Grey Wolf 23MK with a full tank of water I think max it’s 7600+ pounds. My truck gets 8.5 to 10 MPG.
Past Tow vehicle but still own: 2017 Ford Expedition XLT EL factory tow package. Added towing mirrors, 10 ply tires on separate rims, sumo springs, larger rear sway bar.
Current tow vehicle: 2020 Ford F350 Lariat supercab
4x4. 7.3 gas. 4,400+lb payload capacity.
2021 Cherokee Greywolf 23MK
Equalizer 1,000lb WDH
06-21-2021, 04:10 AM
#27
Defender of America
Haven't done a lot of long distance travel with my 2020 and trailer but getting right around 10 mpg in tow/haul mode. Never go over 65 with it attached. Not real excited about pulling into a random gas station pulling a trailer. But assume I'll have to do sometime.
Retired USAF
2021 Freedom Express 192RBS
2020 F150 STX 4X4 w/Coyote V8
Centerline TS WDH
06-21-2021, 07:37 AM
#28
I averaged just under 9 on average days, windy days 6.5. Unless tailwind then maybe I get 10 if I was REALLY lucky. I had 2014 Platinum 4x4 with eco 3:55 rear. Towed a almost 10k fully loaded Trailer 35”10 inches from rear bumper to hitch. I understand gas station concerns
06-21-2021, 08:41 AM
#29
Originally Posted by moose074
windy days 6.5. I had 2014 Platinum 4x4 with eco 3:55 rear. Towed a almost 10k fully loaded Trailer 35”10 inches from rear bumper to hitch.
Nice to hear of real time experiences towing long and heavy with a 1/2 ton. To many armchair quarterbacks repeating what they "heard" about 1/2ton limits although they themselves have no personal experience.
2019 F150 4X4 7050 GVWR 1903 payload
2018 Avenger 21RBS 7700 GVWR
06-22-2021, 10:10 AM
#30
Retired Panpsychist
For FHU camping, we're in the 10,000-11,000 lb range for our GCVWR and have been averaging around 12-mpg (+/- 0.5-mpg) in tow/haul mode. All our mpg data are calculated based on miles traveled and gallons consumed. Being retired, we travel at a relaxed pace and never exceed 60-65-mph. Truck specs are in the signature below.
Last summer we dry camped for a week and weighed our rig at the Cat Scales on the way to the campsite (see below). TV weighed in at 6,820 lbs (with WDH) and the TT weighed 6,000 lbs. This was, by far, the heaviest configuration we have ever towed! During that trip, we faced a headwind on the way out (9.8-mpg) and a tailwind on the way back (12.4-mpg).
I was actually quite pleasantly surprised at the mpg numbers during that trip!
Theo & Carol
2007 GoldenDoodle ("Cooper") R.I.P.
2020 Rockwood Roo 23IKSS
2015 F-150 4WD XLT SCab, 5.0L, 3.73, 36gal, HD Towing Pkg (53A), 1,980lb Payload
06-22-2021, 10:29 AM
#31
Trailer Park Supervisor
Consistently getting 11-12 mpg towing with 2015 F150 V8. I am gentle accelerating, but do try to keep up with traffic on highways, generally in high 60 mph range when limit is 65, and when speed limit was 70, tried to maintain it at that. I'm lucky my trailer does not stick up as incredibly high as others. Trailer loaded is probably between 4 and 5k.
Yes, I drink the water!
06-24-2021, 07:50 AM
#32
I'm curious on just how much difference pulling an 8 foot wide camper effects MPG vs pulling a 7 foot wide camper. There's a lot of real estate hanging off the sides and catching winds on the wider trailers while the 7 footers more closely match the pickups profile.
I'm guessing there is a significant difference, but don't know any real numbers. Any Geo Pro, E Pro owners care to post their MPG's?
06-24-2021, 08:10 AM
#33
I actually believe the difference is negligible especially as speed increases.
I used to have a Tacoma and seen no MPG difference between a 6x10 V-nose cargo trailer and a FSX 180RT toy hauler.
2021 Wolfpack 315Pack12
2014 Ford F350 6.7L Diesel
2019 Indian Chieftain Dark Horse
06-24-2021, 08:41 AM
#34
I just did above your post.
06-24-2021, 08:52 AM
#35
You certainly did, thanks!
06-24-2021, 09:40 AM
#36
RV There Yet?
we tow with a 2009 4x4 super crew king ranch with 5.4L and 3.73 gears and max tow and have a 7 foot wide 21 foot long camper in the 4-5K lbs range. we see a low of 9 mpg with a strong headwind and average 12 mpg. this is towing only and not a combined trip (driving unhooked). speeds are always around 60-62 mph and engine cruises around 1500-1700 RPM in tow/haul mode. unhooked highway mpg is around 20 average.
2018 17RP
2009 Crew Cab King Ranch F150 "Goose"
06-24-2021, 11:15 AM
#37
Retired Panpsychist
I'm curious on just how much difference pulling an 8 foot wide camper effects MPG vs pulling a 7 foot wide camper...{snip}
IMO, the difference would show up due to the increase in frontal area and its role in creating drag on the powertrain. Assuming that both TTs are 10' tall, the 8' wide TT would be exposing an additional 10 sq/ft of frontal area to air resistance in the air stream, increasing the drag coefficient (Cd).
Remember, most TTs are one of the LEAST aerodynamically-shaped objects one could drag through the air (see graphic below). Airstream decided on a (close to) half-spherical shaped frontal area to attempt to reduce the Cd by about 50% compared to a rectangular design. Perpendicularly increasing frontal area in the air stream of a rectangular design only makes the Cd increase. Increasing the Cd will usually affect gas mileage. However, the degree to which it will be affected will vary based on the TV's powertrain, the TV's/TT's aerodynamics, the increased weight of an 8' wide TT, etc.
I'm not sure your question can be answered with any degree of accuracy through anecdotal evidence. One would need a scientific inquiry using controlled test conditions including: the same TV with exactly the same weight, the same trailer weight, the same environmental conditions, etc. Safe to say that there would be some difference.
From Wikipedia:
Theo & Carol
06-24-2021, 12:56 PM
#38
Difference is negligible. I towed a 7ft wide 24ft TT and now tow a 8ft wide 26ft TT. No noticeable difference in mpg.
06-27-2021, 10:51 AM
#39
Guitar G
Sounds a little low, but winds make a big difference
I have a 2019 F-150 with the 3.5 EcoBoost, max towing package, 36-gal. tank, towing a Flagstaff 26RBWS, with a dry weight of about 6400#, probably towing about 8000# total. Just completed a trip between PA and Asheville, NC, averaging 9.5 mpg for the 1500+ miles round-trip. I have noticed on other trips that headwinds can make a big difference, sometimes dropping my mpg down to 8.5 or so. My experiments with premium vs. regular are consistent with what others on the forum have stated: very little improvement with higher octane, and certainly not worth the price difference. With the larger fuel tank and the above stated mpg, I start looking for gas at about 200 miles driven so I have lots of leeway. In the East, availability is not a big issue, but finding a station where we can comfortably get our 29-foot trailer plus truck can be a challenge. We mostly use Pilot/Flying J (their app helps in locating them) and then check on Google maps satellite view to see how much room is available and where the pumps are located. The locations with separate RV pumps are great, but there aren't that many. Hope that helps.
06-27-2021, 03:00 PM
#40
Those headwinds really make a difference! If you are doing 65 mph into a 20 mph headwind, your relative speed is 85 mph. Imagine the mileage loss of towing at 85 mph if you were safely able to do so.
