02-20-2020, 12:21 AM
F250 question
This question is for Ford F-250 owners - where did you mount your backup camera monitor, gps screen, and possibly a cell phone. I am looking for ideas on where to mount my electronics.
Pat, WW9R
2020 Rockwood Ultra Lite 2614BS
2019 Ford F-250 Superduty XLT, Crew cab, long box, 6.7L Diesel, 3.55 Gears
ProPride P3 Hitch with 1400 lbs bars
Haloview rear and side view cameras
02-20-2020, 12:27 AM
I mount my camera monitor to my mirror by using 2 rubber bands and slip it over the left side of the mirror. I still have half my motor left to monitor my 5th wheel. I mounted it to the mirror because that is where one would normally look to see what is behind them.
02-20-2020, 09:02 AM
What about your TPMS screen and dashcam? .
Maybe think about combining devices as much as possible with your MyFord Touch/Sync system.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
02-20-2020, 09:11 AM
F250
Yes, I also have a TPMS monitor that I need to mount to my dash. It is going to get very cluttered. I haven’t found a way to direct those items to ford sync. Has anyone done that successfully?
Pat
Pat, WW9R
02-20-2020, 09:12 AM
For device mounts on your dash, check Proclip.
High quality and the fit is perfect without drilling holes.
https://www.proclipusa.com/
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
02-20-2020, 09:21 AM
Now a "Top Member"
So far, I don't believe there is any one solution to get all that integrated into the Sync system via third party connections. Except with the Ford camera/TPMS. I do not have the TPMS (but plan to add it some day), but do have the camera, and I think it's a fine camera. I'm sure there is better out there, but to have it all go through the Sync screen is huge for me. I hate things hanging off of my mirror, windshield, stuck on my dash, wires hanging all over the place, etc. Mine is nice and clean. If I use my iPhone for anything, it sits in the pocket in front of the cup holders where the USB ports are. So, I am an advocate for a clean install. The more you get integrated into what you already have, the cleaner the install!
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Retired AF MSgt
02-20-2020, 09:24 AM
Brake is on left
You can get a cheap used tablet and use that for the cameras, and GPS. Just hot spot your phone for Wayz or whatever you use. That combines 2 devices.
Rand McNally makes a trucker GPS that integrates cameras as well. Just a thought.
02-20-2020, 09:51 AM
2017 F-250 Super Duty
Phone goes in a holder in the center console and connects to Sync 3 via Bluetooth.
No GPS as we have found Waze and/or Google Maps MUCH better.
They connect via the phone's USB cord and display on the center Sync 3 screen and allow hands free, voice navigation.
TPMS monitor sits in the center dash compartment along with other things like the transponder for paying tolls and a hand held radio (walkie-talkie type) for communicating with the rest of our traveling gang.
That leaves another compartment in the center console open for odd & ends and also allows both center console cup holders open and available as well.
02-20-2020, 10:26 AM
I haven't seen a Ford Dash in recent years but are there any cubbyholes in the DASH? This is how I have mounted my GPS in my Dodge Dash that has some cubbyholes in it.
I fabricated a block of wood to fit the opening tightly. I then mounted part of the support bracket for the GPS unit in the block of wood using a cross screw and nut counter sunk in the wood block. See attached photo for what I am discussing.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
02-20-2020, 10:50 PM
I haven't done this yet but looks like a good solution: https://www.builtrightind.com/produc...015-ford-f-150.
Mark Wilson
No trees were harmed while sending this message;
however, a rather large number of electrons were terribly inconvenienced.
TT: 2018 Surveyor 243RBS TV:2019 F-250 XLT 6.2L 4x4 Crew Cab
02-20-2020, 11:21 PM
This is from my F150 but my F350 setup is the same.
I call it the command center.
I did buy a navtv with extra inputs for the F350 but I have not installed it yet. I wanted to hook the camera up to the display so I could see it in the dash. It will mean replacing the camera on the trailer to use it properly and likely hard wiring it as well.
