Originally Posted by Outdoorliving
So have taken our wolf pup out twice now hooked up to a fastway E2 WDH hitch with the two stabilization bars. Noticed it was noisy after the first trip. REALLY noticed it during the second trip as the campground was smaller and required a number of tighter turns. Has anyone else noticed a lot of scary noises coming from this set up at slower speeds while turning? Had meant to really grease the stabilization bars up good before he last trip to see if it would make a difference but forgot. Understand the bars are under a lot of tension but not sure that this noise is “normal”. No noise without the bars attached so have to imagine it’s coming from where the bars go into the receiver ports on the hitc. Thanks all
We recently changed tow vehicles, which ended up angling the bars (E2 600/6000) upward instead of parallel to camper frame and ground. The bars now make a lot more noise and "pop" instead of sliding across the L-brackets. I have to readjust the L-bracket height to make it get rid of the pop and restore the relative quiet. When adjusted properly, the hitch did groan in low speed turns.
just our experiences
Fred W
2019 Flagstaff T21TBHW A-frame
