Old 09-10-2020, 08:05 PM   #1
Fifth Wheel Hitch Recommendations Needed
(Moderators...feel free to move if I've missed a forum that answers this)
I just bought my first fifth wheel trailer, a 33' Flagstaff Super Lite. It has the Turning Point Pin Box. I'll be towing with a Silverado 2500 HD Crew Cab with the standard box. My question is:
What is the best hitch for this set-up? I've spoken to 2 dealers and they offered 2 different recommendations so I wanted to hear from the "community" since you ladies/gentleman have real road experience. Thanks!
koribustard is offline   Reply With Quote
Old 09-10-2020, 09:06 PM   #2
Now a "Top Member"
EdJunior's Avatar
What were the two dealer recommendations? I don't think I can help much since I don't know much about that pinbox, but it would be good to know the two recommendations by the different dealers
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Old 09-10-2020, 09:10 PM   #3
Mr. Dan's Avatar
I'd hate to make a recommendation without knowing anything about that pin box, either.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 94; booked = 14
Old 09-10-2020, 09:32 PM   #4
badger5301's Avatar
From what I have read, the turning point pin box is similar to the sidewinder and the revolution. I have the revolution and have had it activated using the wedge since we have owned our Rockwood. We use a Curt A16 hitch with the proper wedge and it works great. Have made some very tight turns both forward and in reverse with no issues of contact between the fifth wheel and the cab on our Ram 2500.
badger5301 is offline   Reply With Quote
Old 09-10-2020, 09:35 PM   #5
How long is the box in your Ram?
Old 09-10-2020, 09:37 PM   #6
Also, the Curt you mentioned is a slider hitch. I've been told that a slider hitch is not needed with the Turning Point pin box. This is why I'm confused and asking the question.
Old 09-10-2020, 09:37 PM   #7
badger5301's Avatar
We have the Bighorn crew cab with the short box.
Old 09-10-2020, 09:40 PM   #8
badger5301's Avatar
Sorry, still forgot the length. It is 6'4".
Old 09-10-2020, 09:42 PM   #9
badger5301's Avatar
Our Curt hitch is not a slider hitch and it works great.
Old 09-10-2020, 09:48 PM   #10
badger5301's Avatar
This is our second hitch with the Reece Revolution. I sold the old hitch we had due to it having the slide bar mechanism instead of the jaws that the Curt has to lock around the pin. We have experienced a lot less play using the jaw type versus the slide bar.
Old 09-10-2020, 09:55 PM   #11
Thank you for the info. I looked up the Curt model you listed and the website said "slider hitch (see: https://www.etrailer.com/Fifth-Wheel...hoCU_cQAvD_BwE)
In any case, that's good to know you have good luck with it and I think the base of my question is really do I need a slider hitch or not....sounds like not.
Old 09-11-2020, 07:03 AM   #12
badger5301's Avatar
Sorry for the confusion, our hitch model is C16120. It's not the most expensive one out there but it has worked great for us for the past two years. When we took delivery of our fifth wheel the revolution was not activated. After watching many you tube videos and reading about the revolution I decided to get the wedge and give it a try. Have not changed it back to a regular pin box since.
Congrats on your new rig. Enjoy the adventures to come and be safe.
Old 09-11-2020, 01:22 PM   #13
We have the Anderson Ultimate hitch mostly because the dealer sweetened the deal with it. I have to say, it is real easy to use and it weighs just 35 lbs. It I s also so easy to remove so that I can use the whole bed. Many happy trail to you in your new 5th wheel.
Grouch is offline   Reply With Quote
Old 09-11-2020, 01:31 PM   #14
I've had both the B&W Turnover Ball with the Companion 5th wheel and now a Reese puck system. And frankly....I don't like the Reese system and hope to one day save coins to replace the Reese with a B&W puck system. B&W is much heavier/solid.
2019 Cedar Creek Silverback 37MBH
TV: 2017 Ford F350 CC DRW King Ranch
jd4010 is offline   Reply With Quote
Old 09-11-2020, 01:44 PM   #15
Tundra 2014
5th Wheel hitch
B&W Companion, US made and breaks down into 2-75 lb. pieces. Solid and well made. Easier to latch and disconnect from previous Curt. I like the puck version.
Tundra 2014 is offline   Reply With Quote
Old 09-11-2020, 02:05 PM   #16
TNVJONES's Avatar
The forum is a great way to get educated. I saw the Andersen Ultimate recommended by Grouch and agree it is a great hitch. Just a word of caution. If you go with the Andersen you will need to lock the Turning Point Pin box. There can only be one pivot point with a 5th wheel. If you look in the manual on the turning point instructions are provided on how to lock the hitch. My F-250 bed length is 6'9' and I have plenty of clearance with the Andersen. The biggest advantage to the Andersen is the ease of removal as I use my truck for other applications and need to be able to easily remove the hitch. There is also no chucking like you can get with some 5th wheel hitches.
But, at the end of the day, I would say research as you are doing, review the recommendations and pick what you think is right for you.
Safe Travels
PS My signature line has incorrect info as I now have a SOB 5th wheel but
have stayed on the FR Forum
Tim & Vanessa Jones
2017 F-250 6.2
2019 Flagstaff Microlite BRDS25
TNVJONES is offline   Reply With Quote
Old 09-11-2020, 04:41 PM   #17
Canadian Member
B&W. Get the Companion if you have the puck system. Get the 18K Patriot if you have to use rails.
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
Old 09-11-2020, 04:48 PM   #18
Gwiggels's Avatar
I also am using the curt a16 hitch. And the "custom" wedge sold by curt for use with a reese revolution or turning point hitch. I purchased it for 3 reasons. 1st being the dual locking jaws, second was the price, and third was the ability to articulate not only front to back, but side to side. I am using it on a 2016 F250 with the "short bed" towing a 8299bs. I have made extremely tight turns. Without ever having to worry about the trailer contacting the cab of the truck. I have nothing but good things to say about it. I would recommend it.
Gwiggels is offline   Reply With Quote
Old 09-11-2020, 05:53 PM   #19
X2 on the Andersen Ultimate Hitch.
Mickey Alberto
2016 Forest River Georgetown XL 350TS
Ford V-10 (5-Star Tuned)
cmalberto is offline   Reply With Quote
Old 09-11-2020, 06:27 PM   #20
frank4711's Avatar
B&W 18K great hitch, worked perfect when I had my Ram 1500 and Rockwood with the Turning Point. Still using it with my Ram 3500, https://www.etrailer.com/Fifth-Wheel...BWRVK3255.html ... I still have the matching wedge I will let go 1/2 price....
Frank & Cindy--- (SOB) 5th Wheel ---2019 Ram 3500 Cummins 6.7 SRW 4x4 8' bed--- Payload 4394------Remi & Sage camping pups---TST 507 TPMS ... B&W Patriot 18K---3.73 axle ... Predator 3500---2019 48 days ---2020 28 days Camping
frank4711 is offline   Reply With Quote
fifth wheel, hitch, wheel
