02-09-2021, 10:27 AM
Flat towing
Ball Park, what should I spend to have a flat towing system hooked up to my Class C RV that will tow a jeep Cherokee, base plate included?
02-09-2021, 10:31 AM
Kanadian Kamper
What about the price of a braking system for your Jeep....or are you taking the chance and towing without one?
Ken and Terry
02-09-2021, 10:35 AM
I would want everything on that system and yes safety is the most important!
02-09-2021, 10:51 AM
Go to etrailer.com You can prices for everything that you need. Then do it yourself or ask your local mechanic about labor.
02-09-2021, 10:55 AM
My costs.
I bought a Jeep Wrangler that already had tow base plate and taillight connection installed.
I bought tow bar, about $1000, got nice lighted expensive one but came with safety cables and wires with unit.
RVI tow brake controller around $1200, wanted easy set up.
did have to buy base plate to tow bar brackets $150. Not with the Jeep.
did install work myself $0. Mostly Break away device.
Jeeps do not require much expense to flat tow vs other vehicles.
2018 Coachmen Concord 300DSF
2018 Jeep Wrangler JK Toad
02-09-2021, 12:12 PM
Or, you can get a combined tow bar/braking system. Uses surge brakes like those on boat trailers and is significantly cheaper than a tow bar and electronic braking system.
READY BRUTE
The base plate install can be a little daunting on the Cherokee as the entire front end has to be removed, but it is doable.
AL
2016 Coachmen Mirada 35KB
2016 Jeep Cherokee 75th Ann. Ed.
2007 Corvette Convertible
1997 F-350 CC PSD
02-09-2021, 01:05 PM
When we purchased our 2010 Jayco Melbourne in 2016 I had the dealer where we purchased the motorhome set up our Jeep Wrangler.
Dempco Commander tow hitch and baseplate, RVI brake unit, wiring - $2,700.
Rick & Phy + Sammi our mini labradoodle
2020 Forest River FR3 30DS
2016 Jeep Wrangler Sport
“Don’t take life too seriously...Nobody gets out alive anyway”
02-09-2021, 03:58 PM
flat towing
2010 was a little while ago, I have been quoted $5,200 incl. labor
02-09-2021, 05:27 PM
Here's the quote I went with for my GMC Acadia Denali (baseplates) and motorhime.last fall The whole front end fascia has to come off on the car.
People have been shocked at what I paid. You can save 30% or more on parts if you buy them on etrailer, etc
I let my rv dealer do the whole thing
2006 Sunseeker 2860DS Ford V10 5 speed with Tow/Haul
Winegard T4 In Motion Satellite Dish
Furion Rear Camera, RecPro 70" Recliners
Mohawk Luxury Vinyl Plank Flooring
2013 AWD Acadia Denali, Blue Ox Equipped
02-09-2021, 05:42 PM
Correction. On post #9 above I didn't need the drop receiver so cost was about $5200 said and done.
02-09-2021, 06:25 PM
I paid around $4000.00 for a complete roadmaster install with sterling tow bar and invisibrake system on my Jeep GC.
2017 Sunseeker GTS 2800 QS
2017 Jeep Grand Cherokee toad
1987 Sunstream (sold)
Retired BTC USN
Chesapeake, Virginia
03-03-2021, 08:34 PM
I am currently getting quotes on my for base plate, braking system, tow bar set ups for a 2020 Nissan Versa. The quotes so far are between $4,600 and $5,500.
IrishCampers
2022 East to West Alta 2100MBH
2019 Ram 1500
03-03-2021, 08:47 PM
I don't know about the Jeep, but I did the labor myself and set up a Ford Fiesta for flat towing for around $2000. The auxiliary brake system was the single most expensive part.
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
03-03-2021, 09:12 PM
Wanderluster
The right answer is...it depends - on what types, configurations, makes/models, options, etc. But, for a ballpark figure - for a tow bar, baseplate, braking system, wiring harnesses, and labor - figure around $4,000.
Here's the approximate breakdown of costs for the system I use:
Blue Ox Avail tow bar - $900
Blue Ox baseplate for Jeep - $500
OEM Jeep wiring harness - $150
SMI Stay-N-Play braking system - $1,050
Miscellaneous connectors/hardware - $150
Total (for parts only): $2,750
And, if you can't or won't do the installation yourself, you can add another $1,000 - $2,000 in labor/installation costs.
