i use anderson ranch hitch , about 450.00 you can install it your self, remote cable lock, . i took mine off a while back took 1/2 hour , it screws on a threaded piece that clamps to standard f/ wheel head. you need to spot weld rim of goose head to hitch , they come unscrewed if you dont. bolting is also a option but it is a lot of drilling. i am on my second trailer with this set up. some bucking on rough roads, but not bad. if you go ranch hitch, make sure locker is on driver side , not rear of hitch. dall beats up locker slot and causes a locking burr to form , grind slot it fixes it easily.
