Old 11-05-2017, 06:46 PM   #1
Ford 2.7 ecoboost
Anyone toe with a Ford 2.7 ecoboost. My camper dry wt. is 4305 lbs, don't plan on anything heavier, any suggestions. Thanks
Ken Y is offline   Reply With Quote
Old 11-06-2017, 09:02 AM   #2
Lots of people have spoken on here of them in the past, most give it a pretty favorable rating. Do you already own the truck, or just planning to purchase?
It would be awesome with the weight your describing.
Ron and Kathy
2019 Cougar 369BHS 5'VR
2018 Cherokee Limited 304 BH (Traded)
Joyfully Towed with a 2018 RAM 3500 6.7 CTD
ronheater70 is offline   Reply With Quote
Old 11-06-2017, 11:13 AM   #3
Planning to buy, found a 2015 low milage, all features we are looking for at a decent price, just wasn't sure on how good the 2.7 would be for pulling the camper. Thanks for getting back to me.
Old 11-06-2017, 11:38 AM   #4
We have a 2013 F-150 Eco boost, crew cab, towing package. Our trailer has a published dry weight of about 5,000. We have had no issues at all pulling the trailer. We've gone as far west as the hill country of Texas, and as far north as Ontario. We really like the Eco boost.
dlwilliams48 is offline   Reply With Quote
Old 11-06-2017, 11:49 AM   #5
clarkbre's Avatar
Not sure the exact trailer you're pulling but it looks like possibly a small Surveyor from your other posts?
Regardless of that, if the dry weight is 4305, the loaded, wet weight is probably close to 5300 or so.
That being said, the 2.7L F150's are rated anywhere from 7600-8500 pounds towing capacity. Even if you left a 20% maximum trailer weight buffer, that would still leave you at about 6080 pounds.
https://www.ford.com/resources/ford/...0_r1_Jan12.pdf
With a properly set up WDH, that truck and trailer would likely be a very nice driving combination. And, while not towing, the truck will get very good fuel economy.
The one thing I would suggest more than anything with that truck is to make sure it has the integrated brake controller and tow package. If it doesn't, the brake controller is a much needed and worthwhile upgrade.
2017 Forest River Surveyor 247BHDS...
...Tugged by a 2016 F250 XLT FX4 SuperCrew, Shortbed 6.2L, 4wd, 3.73...
...Joined with a Husky Centerline TS 800-1200lbs WDH
clarkbre is online now   Reply With Quote
Old 11-06-2017, 12:15 PM   #6
Does you truck have a standard tow package or the max package ? Thanks
Old 11-06-2017, 01:46 PM   #7
clarkbre's Avatar
If you're refering to mine, it has the standard 535a tow package that includes the brake controller, 7 pin wiring harness, hitch, and transmission cooler.
Overall, the truck and trailer tow really well together. I wouldn't want anything bigger back there but the torque of the ecoboost really makes it feel more like a small diesel instead of the standard V8 that you'd have to rev high for power.
Old 11-06-2017, 06:25 PM   #8
chris1911's Avatar
2015 Ford F-150 2.7L EcoBoost: Ike Gauntlet Extreme Towing [Video] - The Fast Lane Truck
https://visitedstatesmap.com/image/ALARFLGAMONCSCTNsm.jpg
chris1911 is offline   Reply With Quote
Old 11-06-2017, 06:34 PM   #9
Steeljag's Avatar
Your 2013 is probably a 3.5, and not the 2.7 the OP is requesting info on ?
1930 lbs CCC
2014 Jeep Rubicon JK
Steeljag is offline   Reply With Quote
Old 11-06-2017, 06:45 PM   #10
Pretty sure my 2013 F-150 is a 3.5L engine. Standard tow package and rated to tow a max of 7900-8000 lbs. CCC is rated at 1610 lbs. Towing I get 9-11 mpg, on the highway not towing around 21-22. Again, very pleased with my truck both for towing and just ordinary driving around. Very comfortable ride.
Old 11-06-2017, 06:58 PM   #11
bikendan's Avatar
But the OP is asking about the 2.7, not the 3.5.
I also own a 3.5 but I didn't respond cause I don't have any experience with the 2.7
Don't think the 2.7 was available in 2013.
Old 11-07-2017, 12:10 AM   #12
I currently tow a 5200# dry weight trailer with my 2.7 , have done many trips with it including a 6000 km trip from Ontario to Newfoundland and back. Some of the hills in NFL were very steep grades and she did fine . Mileage was ok when towing but when not it is fantastic . I just found the rear suspension to be soft so I added Bilstoens and replaced the factory bump stops. Most important is to find the right WD set up .
eurojet is offline   Reply With Quote
Old 11-07-2017, 07:17 AM   #13
I have a 2016 F150 XLT with the 2.7 Ecoboost and tow package and tow a 6,800 TT with no problems at all (that's gross weight, not manufacturer's fantasy weight). We have been all through NC and Tennessee mountains and it handles the load with ease. Make sure the cargo capacity is adequate and that you have a properly installed and adjusted WDH and brake controller.
What I really like about this truck is that when I'm not towing I get @20 mpg around town and 24 on the highway.
TallyBeach is offline   Reply With Quote
Old 11-07-2017, 07:18 AM   #14
Yep, I understand... that's why I followed up my first post with the second, stating I have the 3.5. Initially I just saw "Ecoboost" and posted. Should not have responded to original post. Apologies to OP.
Old 11-07-2017, 08:58 AM   #15
I have a 3.5 EB 2013 and my father-in-law has a 2015 EB with the 2.7. I have tested both trucks with the same camper and the 2.7 seemed the same for me. I have the max tow package so my gearing is slightly different. I would say the 2.7 towed just as good with really no complaints what so ever. The 2.7 seemed to have more pep with no trailer attached and it sounds like a V-8 when getting on it. My truck's turbos seemed to whistle louder than his 2.7 but sure if they are the same size diameter turbo or not. Comparing the 2 when towing a #6500 camper the 2.7 did perfectly fine. Both trucks are babied and have about 40k miles on them
2017 FR Wildwood 201BHXL
2013 Ford F-150 King Ranch Ecoboost
zorky is offline   Reply With Quote
Old 11-07-2017, 04:35 PM   #16
thebrakeman's Avatar
Yep, 2.7L EB in the F150 light-duty (aka P552L) became available in 2015 model year.
Different gearing between 2.7L and 3.5L trucks could leave them "feeling" similar with a trailer behind, although you would certainly see a different on the tach once cruising. But with max tow being on the 3.5L (and assuming the 2.7L does not), I would think your truck would be the towing monster in comparison. Does Max Tow include a axle upgrade, or is that a separate, standalone option?
thebrakeman is offline   Reply With Quote
Old 11-07-2017, 05:40 PM   #17
clarkbre's Avatar
Originally Posted by thebrakeman View Post
...Different gearing between 2.7L and 3.5L trucks could leave them "feeling" similar with a trailer behind, although you would certainly see a different on the tach once cruising...
If the axle ratio is the same between the 2.7 and 3.5, the motor RPM would be identical. The 2.7 would just have slightly less HP and Torque (about 11%) to move the truck and trailer.
...But with max tow being on the 3.5L (and assuming the 2.7L does not), I would think your truck would be the towing monster in comparison. Does Max Tow include a axle upgrade, or is that a separate, standalone option?
The 2015 F150 Tech Specs show that the 3.5 is available with the 3.15, 3.31 & 3.55 axle ratios whereas the 2.7 (& 5.0) is available with 3.31, 3.55 and 3.73 axles.
Both the 3.5 and 2.7 Ecoboost motors are impressive in that they pack that much HP and Torque into such small packages. Compared to the standard V8 offered by Ford, they have much more HP and Torque per cylinder than the 5.0:
Liter.....HP......Torque......Per Cylinder HP/Torque
3.5.......365.....420............60.8/70
2.7.......325.....375............54.2/62.5
5.0.......385.....387............48.1/48.4
Given that the OP's trailer is well within the towing capacity on any of the above listed truck/motor/axle combinations, they should all tow it with relative ease.
Old 11-08-2017, 10:11 AM   #18
Clarkbre,
I wasn't talking about same axle ratios. I clearly said, "Different gearing between 2.7L and 3.5L trucks...".
Thank you for the list of available ratios for each version. Do you know if the HD towing package, or the Max Towing package (or any other package), automatically includes a certain axle ratio, or is the axle choice completely independent.
Old 11-08-2017, 11:42 AM   #19
The fast lane truck comparision even with the 3.55 gears thought the 2.7 felt quicker than the 3.5. Towing the gauntlet with the 2.7 the were limited by the speed limit all the way up although with only 7200 pounds in tow. The 6.4 Hemi Ram With 4.11 gearing slowed to 26 mph for 5 minutes although towing a 12,500 pound trailer. There was something in the computer pulling power on that Ram for some reason, but it happened repeatedly on 2 different trucks in two different tests. So big difference in the weights, but if your trailer is 8000 or under it should be golden with a 2.7. It leaves a bunch of payload as well as that is the lightest motor, in the lightest full size truck. I saw a used 2015 crew cab 4x4 With 50k on it for $26,000 locally which makes me consider trading the Cummins in on.
Hersbird is offline   Reply With Quote
Old 11-08-2017, 08:33 PM   #20
Safety feature:
"Ram came back with the following explanation.
“Ram Truck ‘invented’ the first gear hold feature – and calibrated it – to avoid gear hunting and driving at excessively high rpm’s. Ike Gauntlet is a variable grade and we worked hard to develop a calibration that appropriately manages torque on this run and other grades. We don’t want the truck to rev high for extended periods of time and purposely hold 4,200 rpm.”
2006 Honda Goldwing
2012 Toyota Tundra DC s(sold)
2015 Cherokee Grey wolf 19RR Limited
2017 F150 Super Crew 3.5eb 5.5
bluewoo is offline   Reply With Quote
ecoboost, ford
