06-17-2023, 04:06 AM
#21
The stickers do ok. The problem pops up when the sun is shining directly on them the truck camera can’t see it so it says something like trailer not detected. It’s usually not a big deal but can be a pain.
I got my yaw sensor off of eBay for $150.
Try here: https://www.ebay.com/sch/i.html?_nkw...l1311&_sacat=0
Stuart
06-17-2023, 07:52 PM
#22
I had a bid in for one on eBay, but the auction ended early. Managed to get one for just over $200 (CAD) including shipping. I’ll take that as a win
10-09-2023, 04:26 PM
#23
Ford F 150 Trailer Camera
Hey guy lots of good info on here and thanks for the help. So I a 2021 that I had to put the new harness on from the connector above the tire to go from the 2 wire to the 12 pin for the camera and the TPMS. After installing and making sure all is in the right place,I turned on the camera and all I get is a blue screen then it goes to a kinda of night vision looking screen.Any help will be appreciated.
10-09-2023, 04:36 PM
#24
10-09-2023, 04:47 PM
#25
Some of the software features / options require a trip to the Ford dealer to be enabled. Adding the new cable may have confused the system. I'd start by unplugging the new cable and see if the problem goes away.
2024 Sunseeker 2150SLEF on a 2025 Ford E-350 chassis with "Godzilla" 7.3L and 6 speed automatic transmission. "Trekker" Cap, Solar, Suburban IW-60 On-Demand Water Heater, All MaxxAir Fans, Progressive EMS-HW30C, Pacific Dually "Hub Caps".
TOAD: 2024 Ford Bronco Badlands, 2 Door, 2.7L EcoBoost, 10 Speed Automatic, 334A Luxury Package, Leather, Blue Ox and RVi Flat Tow Equipment.
10-09-2023, 05:19 PM
#26
Ok so just so I’m clear the camera does come on and that’s what you get in the picture. I just talked to the dealer ship and there telling me that the camera and TPMS kit is for a 2022!!! And one person tells me that it will work and the other says not so much. Ill try your suggestion, I also believe that the camera my be bad also.
10-09-2023, 06:21 PM
#27
I would try another camera if possible. I don’t think there would be any difference between cameras from 2020 to now. Also check your connections to make sure there’s no corrosion or bent pins.
Stuart
10-10-2023, 08:54 AM
#28
So this is what I did this morning after reading more post from here and other places. Made sure all was connected properly. Turn the camera on and this is what I got. It’s works looks great call dealership to inform them that the 22 kit will work on the the 21. Thanks for all the help.
10-10-2023, 10:11 AM
#29
Glad it worked out. I really like the convenience of having all that information displayed on the truck’s screens as opposed to having to use your phone or other device.
Stuart
10-10-2023, 12:16 PM
#30
That's good news. My 2021 has the 2 wire harness and I've been debating upgrading to see if I can add some functionality.
10-10-2023, 06:15 PM
#31
I have the harness #ML3Z-13A576-P to make it the 12 pin/only really use 4-5 pins.
10-11-2023, 04:01 PM
#32
Thanks...
