05-23-2022, 12:51 PM
Ford Pro Backup issue-only works straight back
Never had one but when my 12 F250 was totaled I got a 22 F250 with the Backup package. I have a 22RR toyhauler and placed the "sticker" as far back on the left side as possible. The gas tank bracket prevents it from being more than 10" centered which is supposed to be in spec. Anyway, it calibrated fine but when I back up and turn the knob it loses detection and fails. Any ideas with the experts? I'll just back up as normal this weekend but I paid over a grand for this feature. I'm letting my dealer know but I thought I'd ask here in the "real" world.
John in Michigan
05-23-2022, 01:06 PM
Does the trailer jack block the view of the sticker? It did on my Flagstaff, haven't tried on my Grand Design yet. I have thought about setting it up twice on the trailer, one sticker on each side of the jack, then setting up 2 trailers in the PTBA and cover one sticker and select the "other trailer" when backing.
I really like it on my small utility trailer.
TT 2021 Grand Design 2800BH
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload
prior TV 2014 Silverado 2500 HD
05-23-2022, 01:10 PM
Let us know if you figure it out. I haven't bothered setting mine up yet but was curious how to get the sticker far enough back to be effective.
22 Freedom Express 257BHS
19 F-150 3.5 Max-Tow
05-23-2022, 03:18 PM
It may be the jack. I thought of that. I don’t know what you mean about selecting the other trailer? 2 stickers? Interesting if it works. Maybe explain in more detail?
05-23-2022, 03:21 PM
fixed
It’s supposed to be 7-20 inches. I could barely get 7 and then the specs say minimum of 9.5 inches to the center when the camera reads it. Mine was 10 inches to the center. I wonder if my power Jack blocks the view when I turn?
05-23-2022, 03:22 PM
I sure hope I can solve this as this is my only trailer and it’s an expensive option not to work.
05-23-2022, 06:08 PM
I've read numerous posts from folks who just gave up. I've also read that using the physical yaw sensor that was included for a while is more reliable. Maybe you can get your dealer to give you one.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
05-23-2022, 07:02 PM
Back Up Assist
I've has no luck with the Back Up Assist on my Expedition. It is fine for backing straight in.
05-23-2022, 08:43 PM
John in Michigan
I had this feature on my 2017 f150. (I no longer have this truck.) I found that it worked great in very simple situations where you probably didn't need it in the first place. However, in any situation that was the least bit complicated, it totally failed. I eventually gave up and stopped using it altogether. It's more marketing hype than anything else.
2018 Grand Design Imagine 2600RB
2019 Chevy Silverado 2500HD 4x4 LT Crew Cab, Vortec 6L V8, 4.10 Rear Axle
Equal-i-zer 1,200/12,000# Hitch
05-24-2022, 08:50 AM
I love my back up assist. Use it on several trailers. I have a roo 233s.
I have added a metal plate on one of my trailers so the sensor can be read at tighter angles etc. most likely the issue you are having is the sticker goes out of range when you are at an angle. The only solution is to find a more direct path. That is when I played around with a metal plate and just through trial and error found the right place.
05-24-2022, 08:52 AM
Also. Making sure the sticker is clean and the camera lense is clean helps.
05-24-2022, 08:57 AM
Can you upload a picture of the metal plate solution? I would be interested in seeing how that worked.
05-24-2022, 09:42 AM
Sorry. Don’t have that trailer anymore. I bought a thin metal plate about 4 by 4 attached the sticker and then screwed it onto the trailer just off center of where the triangle meets.
05-24-2022, 08:13 PM
I use the backup assist on my '21 F-150 with the yaw sensor (bought on e-bay) and feel that it works GREAT! I know it is an expensive option, $300+change, but this option is worth considering if the dealer won't give you one as SailorSam20500 suggested and the stickers never work to your satisfaction.
05-25-2022, 05:05 PM
How does that work, I mean with the installed package? Can you show a pic and how you set it up?
05-25-2022, 05:10 PM
I'm pretty sure it's the power jack obstructing the view plus the propane cylinder bracket makes it so you have to put the sticker close to the ball but still within spec. I'll try anything after this weekend, lol. Even if I have to remove the jack each time I tow (3 bolts, 1 zip tie, and unscrew the fuse holder). But if this yaw thing works maybe that?
I made a separate post about my power jack falling apart.
05-25-2022, 05:30 PM
Please look at this video and let me know if you'd like more info on my setup which is not a tow behind and, officially, not supported:
06-02-2022, 06:27 PM
Gimmicks, gotta love them. Left is right an right is left, free and never failed me backing up everything from a 60’ trailer down to a 6’ utility trailer, that and driving a RAM
06-02-2022, 07:45 PM
I agree with Mark Ulmer. It's marketing hype. The feature came with my F150 Max Towing Package. Its just as easy to back up as usual, hand on the bottom of the wheel and move in the direction you want the trailer to go.
06-02-2022, 07:48 PM
Back up works great
Have a 2016 F150 with a 25ft TT. Placed sticker on "port" side of tongue just next too and slightly forward of jack. Part of the sticker is on the plate that bolts jack to trailer. Did all the measurements and data entry. Only rarely does it not pick up sticker. I then pull forward a bit to straighten trailer and then it reconnects. It works very reliably. However, if I am backing trailer to starboard and "jackknifed" (sharp angle between truck and trailer) sticker can become blocked by tongue jack. Same fix-pull ahead to straighten a bit. I'm not sure the distance from tailgate camera to sticker maybe 21/2 t0 3 ft. From ball center to sticker on frame-maybe 10-11 inches.
