Frame issues and slide side sag
I had an issue with my Grey Wolf leaning towards to the slide side- both while towing and stationary. I replaced the springs(they were flat), equalizers, and used wet bolts. This didn’t fix the issue. My trailer still leans significantly to the slide side. The axles aren’t bent, but the frame near hanger on the slide side has some frame damage. The wheels are hitting the bottom of trailer and inside of wheel well. The wheels on slide side are further into the trailer than the other side. I noticed the cheap metal cross beams are broken, and the triangle shaped metal supports are either bent or damaged. What is the best way to fix this? Also how do I add pictures to this post?
