02-05-2019, 05:43 PM
#201
Thanks doc, I figured you would chime in and clarify that for us!
Larry
2014 Ram 3500 Dually 4x4 6.7 Cummins
2017 Sandpiper 378FB
02-05-2019, 06:37 PM
#202
The place my brother bought his trailer from almost didn’t let him leave because the GVWR of the trailer exceeded his car’s towing capacity, even though the UVW was well below it.
02-06-2019, 12:12 AM
#203
I appreciate the response I know my dually and my 1500 weights posted on registration are very low not from manufacturers be curious how they came up with numbers
2022 Chevy 3500 Diesel SWD
2022 Columbus 329 DVC
02-06-2019, 04:17 PM
#204
At some point the dealers are going to be held liable for insuring that the trailer does not exceed the vehicles compacity when I leaves their lot. They will have no one to blame but themselves as they regularly tell people that the vehicle they own will pull that trailer with no problem.
When I bought my first TT years ago, the first question the dealer asked was the GVWR and GCVWR on my truck. He then calculated my GVWR minus 20% and said this is the heaviest trailer you should tow. You can buy a heavier trailer then that but not from me!!! They checked the numbers on the truck again when I came to pick it up. Salesman told me that several times the customer showed up with a insufficient rated truck and the owner would not let them take the trailer.
Larry
02-06-2019, 05:04 PM
#205
2007 WildCat 32QBBS
Sorry but I have to disagree here. It is always driver's responsibility when it comes to a motor vehicle violation. It's the operators responsibility to make sure they have the proper registration, insurance, exterior lights are in working order, tires are safe, ect.... Expecting a dealer to do the work for you, the operator, is just pushing blame. Plus where does it end?
Folks need to educate themselves and be responsible.
02-06-2019, 05:13 PM
#206
2007 WildCat 32QBBS
Originally Posted by doc73
Yes the sections apply to all vehicles, but obviously, most single trucks owned by us are not ever going to hit the numbers listed... But you'd be surprised what people will come up with.
As for GVWR enforcement.. We do not have a section to technically prohibit the exceeding of a GVWR. We have nothing for payload, that falls under the GVWR. If you can follow, while we do not have a specific violations for GVWR it falls under our section for exceeding Registrations weights. All vehicles driven in PA cannot be registered beyond the max capacity (GVWR) as set by the manufacturer.. SO as silly as that sounds it means you cannot technically exceed the GVWR. It is a goofy way to word it but it is what it is.
So how does PA DMV know what a vehicles GVWR is with all the variables and different ratings for similar trucks? Or do they have a generic top rating that they use.
In NJ you tell them what you want to register it for. Theres knuckle heads running around in DRW crew cabs with a registered GVWR of 5500lbs. when the truck alone weighs 8500. I never heard anyone getting turned away for increasing the registered weight but I'm sure they must have a max GVWR number for a pickup.
My point is DMV doesn't know what your derated GVWR door sticker reads. So as long as I register it for the max for that truck class, then that is all that can be enforced (registered weight), the door sticker not coming into play.
02-06-2019, 05:22 PM
#207
Denver To Yuma In 90 Days
In NJ you tell them what you want to register it for. Theres knuckle heads running around in DRW crew cabs with a registered GVWR of 5500lbs. when the truck alone weighs 8500. I never heard anyone getting turned away for increasing it but I'm sure there is some based max number based on the max for a pickup.
Pretty sure the DMV can look all that up with your VIN# and a couple of key strokes...
02-06-2019, 05:23 PM
#208
2007 WildCat 32QBBS
Duplicate
02-06-2019, 05:32 PM
#209
2007 WildCat 32QBBS
I've run Ford breakdowns for VINs and it doesn't give a rating, that's why I ask.
But I have found charts like this which I believe is what they would go by. So I believe as long you register for a weight that is within the bracket for your truck class, you're good.
02-06-2019, 06:08 PM
#210
But I have found charts like this which I believe is what they would go by. So I believe as long you register for a weight that is within the bracket for your truck class, you're good. Attachment 196318
But do you work for the DMV?
I'm sure they have more access to information like that than we do.
And the popo probably has more access than any of us as well!
02-06-2019, 06:26 PM
#211
That’s funny but check this one!
https://youtu.be/56XL0TysIn0
Let’s go camping!
02-06-2019, 06:39 PM
#212
2007 WildCat 32QBBS
Lol! If you only knew.
I want to see how PA DMV does it. If he doesn't know maybe someone that goes there can ask to register their truck at a higher rating and see what happens.
02-06-2019, 07:29 PM
#213
Yes they do know what the GVWR on the door sticker is as the notaries in PA are REQUIRED to verify the VIN number and GVWR when submitting paperwork to create the PA title for the truck and its also included on the PA title. For your registration, you can request a lower weight class but they will not let you increase it above the GVWR on the title or the door sticker.
Larry
02-06-2019, 07:59 PM
#214
Who Dares, Wins
Yes I can run your Vin and I will get the gvwr of the vehicle. We use it for trucks as well when establishing weather a cdl is required and what gvwr are for trailers and such when they are "removed" from the sides. Your vehicle, along with all others has a sticker in the door that tells me what the gvwr is. It's one of those fed stickers on all vehicles since probably the early 2000.if it is missing we run the Vin through our Vin checkers.
2015 Chevy HD D-Max
2022 Impression 315MB
#215
Who Dares, Wins
Exactly
2015 Chevy HD D-Max
02-06-2019, 08:02 PM
#216
2007 WildCat 32QBBS
Are you sure your cad isn't showing you the REGISTERED gvw? In NJ it shows the registered GVW.
02-06-2019, 08:04 PM
#217
Who Dares, Wins
Some vehicle, like incomplete chasis ((think mack trucks and e450) that have been upfitted by someone who is authorized to do so will NOT return a GVWR but a range. So for example that mach truck will be a gvwr of 25,000 to 33,000lbs. This is because they do not now what the vehicle will be. With that we will use the door stickers, if they are gone the tie goes to the runner and we use the lowest weight for drivers license purpose and the highest for weight if that is the issue (overweight) but then we use the highest for the license if that makes sense.
2015 Chevy HD D-Max
02-06-2019, 08:11 PM
#218
Who Dares, Wins
let me back up... What are you asking? I must have misunderstood somewhere. Yes, if PA runs a tag in CAD then I get the registered weights IF the state put it on the tag, NJ, does not for us so we get nothing. If the VIN is put into our VIN checkers (not cad but a federal database) we get the whole break down including that vehicles GVWR (but as said somewhere, prob another thread, all these trucks typically follow a certain pattern for the GVWR's. SO depending on the need we will know what we have before we get there more than likely.
2015 Chevy HD D-Max
02-06-2019, 08:23 PM
#219
2007 WildCat 32QBBS
No misunderstanding. You answered it.
My point is if a truck is registered at the highest rating permitted by DMV, that is what you would enforce. Especially if no door sticker.
02-06-2019, 08:31 PM
#220
Who Dares, Wins
Yes if the gvwr could not be found, the max weight would be used the vehicle could be rated at for weight violations. But unless you drive an incomplete chassis vehicle I'd get your weight as it left the factory.
2015 Chevy HD D-Max
