Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 01-10-2022, 01:32 PM   #1
Gear Ratio Change?
Was looking to upgrade the camper and found that my 18 silverado with stock 3.08 gears will allow me to tow up to 6100lb. If I had 3.43 gears, then I could tow up to 9100lbs. Has anyone done this? I often see people with 1500/F150 trucks towing campers that seem to be way outside the limits.
CodeMan is offline   Reply With Quote
Old 01-10-2022, 02:14 PM   #2
camper_Lucy's Avatar
If it looks like they are towing outside the limits, they probably are
But for your original question, you can swap out your gears but I would ask at a GM shop as you may need a carrier too. Also note, generally the 3.08 setup only comes with a 9.5 axle not the 9.75 so you will not get the full upper weight limit you see from a stock setup.
2019 Chevy 3500 4x4 Crew Duramax
2021 Gray Wolf Toy Hauler
2019 Street Glide
camper_Lucy is online now   Reply With Quote
Old 01-10-2022, 03:24 PM   #3
Mods dont change the sticker inside your trucks door. Take what you would spend on the upgrade and get the right truck with the right number on the plate on the door.
Kimber45 is offline   Reply With Quote
Old 01-10-2022, 04:02 PM   #4
Broken Toe
Cowracer's Avatar
The "sticker on the door" on 3/4 ton trucks is artificially held to under 10K GVWR to keep them in Class 2 and has no real correlation to real world capabilities.
Mods do in fact increase those capabilities, if done correctly.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016
Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
Cowracer is offline   Reply With Quote
Old 01-10-2022, 05:20 PM   #5
Tim
You can get a 3/4 ton truck with a higher GVWR than that. I've seen them plenty of times. Not all states have stupid regs in regard to that. You can get a 2021 Chevy Silverado 2500 with a GVWR as high as 11,550 lbs. 3500 models are capped at 14,000 lbs.
2019 Silverado LTZ 1500 6.2L 10 Speed 3.42 Max Trailering Package
2018 Freedom Express 192RBS
2016 Silverado LTZ 1500 5.3L 6 Speed 3.42
2020 KZ 130RBSE
AlaskaErik is offline   Reply With Quote
Old 01-10-2022, 05:22 PM   #6
D W
D W's Avatar
With GM trucks you have to do your homework. RPO's for certain gear ratios often call for additional RPO's such as axles, and deletions of other RPO's.
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 01-10-2022, 05:58 PM   #7
BigH's Avatar
Tim
This is something that gets repeated by folks who don't know what they are talking about. Complete hogwash sir...
There is no 10k limit on 250/2500 series trucks. Both Ford and GM offer that class vehicle above 10k. If you look at the different configurations Ford has above 10k in that class, it looks like Ford would disagree with your last sentence as well.
21 Ram 2500 crew cab long box. 6.4 gasser 50 gallon tank.
18 Vengeance 28V
BigH is offline   Reply With Quote
Old 01-10-2022, 06:32 PM   #8
AKC
Yeah my F250 is rated up to 12.5k pounds with a WD hitch.
AKC is online now   Reply With Quote
Old 01-10-2022, 07:41 PM   #9
precisely, this is what I was referring to when I stated that the OP would not get the same limits as the stock setup. Not that the OP shouldn't make mods to improve the TV, just that there is more to it then just changing out some gears to increase the tow limit levels.
2019 Street Glide
Old 01-10-2022, 07:53 PM   #10
gas or diesel 2018. ? i have the 2018 6.6 ltz. silverado. 30 ft. t- hauler,1000 lb. trike in box, and a boat in tow . its a breeze towing anywhere.
Thomas ho is offline   Reply With Quote
Old 01-10-2022, 08:34 PM   #11
Sounds like you have an HD truck. Looks like OP has a 1/2 ton.
Old 01-10-2022, 11:32 PM   #12
Camping the Natural State
Sure and I wouldn't do it unless at east 2 steps lower ratio but keep in mind, it doesn't increase the CCC of your particular pickup.
2021 Rockwood Ultra Lite 2614 BS
ARhappycamper is offline   Reply With Quote
Old 01-10-2022, 11:34 PM   #13
Tim
Wrong. You cannot increase the CCC (payload) of any vehicle by modding.
Old 01-10-2022, 11:36 PM   #14
OP has a halfton pickup !
Old 01-10-2022, 11:45 PM   #15
WD hitch has nothing to do with F250’s GVWR
IvoryHemi is offline   Reply With Quote
Old 01-11-2022, 02:48 AM   #16
Nevermind GVWR. You will hit the CCC limit first.
Old 01-11-2022, 10:53 AM   #17
Broken Toe
Cowracer's Avatar
Yes they do. And they also offer the EXACT SAME truck with a 10K GVWR. The reason is, commercial users (landscapers, construction, etc) would fall under DOT regs with a 10,001 and above GVWR and they usually don't want to have to mess with everything that goes with that.
Order a GM 2500 with the C7A RPO code and it comes with a 10K sticker (rating). Check the C7G box, and you get 10,600. Exact same truck. Not a single washer has been changed.
Its all bureaucratic, not engineering.
Tim
"Camper" 2016
Old 01-11-2022, 11:33 AM   #18
Tim
Yes and No,
Agree not a single washer difference, but
CA7 kicks in California Emissions(YF5). C7G does not require Cali emissions testing, but "DEPENDING" on your state may require commercial plates and DOT registration. In Ohio we can put passenger and or non commercial plates and avoid the DOT registration, but you need to check with your state prior to ordering a C7G code as the dealer will report it on the paperwork. Cali will not register a non YF5 RPO as non commercial.
2019 Street Glide
Old 01-11-2022, 11:37 AM   #19
3.08:1 is terrible for towing.
I had a 1/2 ton Chevy 40 years ago with a 3.07:1 rear end. It went through clutches if I tried to tow anything, even a two horse trailer.
I like a 3.73:1 in a Ford for towing.
Changing out the rear end gears is not cheap, but probably cheaper than finding a different truck.
ppine is offline   Reply With Quote
Old 01-11-2022, 12:21 PM   #20
SailorSam20500's Avatar
You REALLY need to check the truck specifications as provided by the manufacturer. I can't control if YOU don't believe them or "feel" the numbers are too high.
With that said, my F150 has a max trailer weight of 12,700 - specified by Ford. So, I consider my 7k lb trailer well under the limit. FWIW, based on actual weighing, I am also comfortably under my CCC and GAWR numbers.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
