Originally Posted by KMRVing1
Anyone towing Geo Pro 19FD with 2019 Acadia Denali.
Dry TT = 3220 lbs
TV Max = 4000 lbs
TV Hitch max = 500 lbs
Wonder about any towing issues with this set up. Will have WDH and keep cargo < 400 lbs of “Stuff”.
any advice?
Are you sure on those numbers?
Usually the max hitch weight weight is 10% of the max tow weight. If you're using a number on the hitch receiver itself, that's the rating for the receiver itself, not what your Acadia is rated for.
Plus the 4000lbs towing capacity is ONLY if it has the V92 Max Trailering package. The 2019 GMC Towing guide says the max tongue can only be 10-15% of the trailer's loaded weight.
Also you're making a common newbie mistake by using fictional dry weight numbers.
Once you add the weight of batteries, factory options, water and cargo to the fictional dry tongue weight of 418lbs, you'll easily be over the Acadia's max capacity.
https://forestriverinc.com/rvs/trave...pro/G19FD/3574
