Old 10-09-2020, 12:32 PM   #1
DavidBo's Avatar
GM Factory TPMS for Trailers
I have a 2020 Silverado that has the option for trailer TPMS. I need to install the sensors in the wheels of my Mini-Lite, and I was wondering if anyone has tried doing it themselves. I'm mechanically capable of such work and I would like to avoid a trip to the tire shop if possible.
I've seen a few videos of the process, but I would like to know if any of you fine folks have had any experience in the matter.
Thanks as always.
DavidBo is offline   Reply With Quote
Old 10-09-2020, 01:22 PM   #2
I just spent the $60 and had it done at the tire shop. I've seen the YouTube videos on how to do it, but for $60 it was done in an hour.
2019 Silverado LTZ 1500 6.2L 3.42 Max Trailering Package
2018 Freedom Express 192RBS
2016 Silverado LTZ 1500 5.3L 3.42
2015 Jeep Wrangler Rubicon 3.6L 4.10
2020 KZ 130RBSE
AlaskaErik is online now   Reply With Quote
Old 10-10-2020, 10:27 AM   #3
DavidBo's Avatar
I'm still keeping that option open of course, but for me the hassle of either towing my whole trailer to the shop or jacking it up and taking just the wheels is something I'd rather avoid. I know it sounds contradictory, but it's easier for me to remove one wheel at a time and do it myself at an easy pace.
Old 10-18-2020, 10:07 AM   #4
My tire shop couldn't get the sensors to program. I bought a $15 tpms tool on Amazon and it works great
cpttimerstraint is offline   Reply With Quote
Old 10-18-2020, 02:52 PM   #5
I didn't even give my tire shop the chance to try and program my sensors. While the tech was putting his equipment away I programmed my sensors in less than two minutes using the same Amazon relearn tool that you have. And since GM tires have to be reprogrammed every time you rotate tires, I'll get plenty of use from that relearn tool. I'm guessing most people with GM vehicles don't even know that and are running around with rotated tires that have never been reprogrammed.
2020 KZ 130RBSE
Old 10-19-2020, 12:10 PM   #6
DavidBo's Avatar
Yep, already got the relearn tool, should pay for itself pretty quickly.
Old 10-19-2020, 12:45 PM   #7
wmtire's Avatar
Ha, I just relearned a GM truck awhile ago. I do many in a week's time.
It's bad enough that I don't just take a customers word for which tire is leaking as they go by their tpms display. I physically check the tire to make sure it's low as they seem to get upset with me if I charge them for my wasted time when they tell me the wrong tire to pull off.
2011 Flagstaff 831 RLBSS
I often say to myself, "I can't believe that cloning machine worked."
Old 10-19-2020, 01:33 PM   #8
Hclarkx's Avatar
I would have done it myself had I not been due for new tires. I programmed them when I got home.
I've replaced valve stems but on a heavier/sturdier tire, it's not easy and can be a bit hazardous to the digits. An E load range tire could be problematic. I have an auto lift and can use it as a giant press. It breaks beads easily with a properly shaped piece of 2x4. Without that I'm not sure I would try it.
2020 GMC Denali 2500HD Crew 4X4 Gas 6.6L
2015 8280WS Rockwood Ultra Lite - lifted 3"
1000W solar, 322AH LFP battery, 12V fridge
Hclarkx is offline   Reply With Quote
Old 10-19-2020, 09:04 PM   #9
I make it easy for my tire shop. I bring the tire in with an X marking the puncture and an arrow pointing to the valve stem so the tire remains in balance when it's remounted.
2020 KZ 130RBSE
factory, tpms, trailer
