Old 04-05-2020, 12:59 PM   #21
KSH
Checking in, any update?
KSH is offline   Reply With Quote
Old 04-05-2020, 02:32 PM   #22
The new one is being delivered tomorrow by 3
AF_VET is offline   Reply With Quote
Old 04-05-2020, 03:20 PM   #23
robbiels7's Avatar
Thats why i love my goosbox!
Originally Posted by pilotpip View Post
What is the advantage to switching? Not having a huge hitch assembly in your bed?
robbiels7 is offline   Reply With Quote
Old 04-06-2020, 09:22 PM   #24
KSH
Old 04-09-2020, 06:25 PM   #25
Good New!!! It Works Perfectly. Its riding a little nose high but has done that no matter what hitch I've used. I have 6 1/2" between truck bed and the bottom of the RV. I can only get about 85 percent but I've never had to get my truck and trailer at this severe of a angle.
2019 Ram 3500 stock height. B&W 1" high rise ball. I had to remove my Retrax tonneau cover. From what I can tell I should be able to use the Bakflip Mx4 tonneau cover.
ID:	226591   Click image for larger version
ID:	226592   Click image for larger version
ID:	226593   Click image for larger version
ID:	226594   Click image for larger version
Old 04-09-2020, 06:27 PM   #26
more pictures
ID:	226596   Click image for larger version
ID:	226597   Click image for larger version
ID:	226598   Click image for larger version
ID:	226599   Click image for larger version
Old 04-09-2020, 09:34 PM   #27
KSH
Geez! That is close! I have rails for my tonneau cover that makes me a bit narrower. How close is that, can you take a few close up pictures with a tape measure on a sharp turn?
Old 04-09-2020, 10:41 PM   #28
KSH
I have the bak revolver x4 tonneau cover. Was your issue the rails?
Old 04-09-2020, 11:04 PM   #29
I had the Retrax pro and the rails would make it impossible to make tight turns. These are the pictures I took Monday. b4 I put the B&W 1" high rise ball on and with the cover on Even with the high rise ball the railswere in the way. Any cover with extended rails wouldn't work.
ID:	226608   Click image for larger version
ID:	226609   Click image for larger version
ID:	226610   Click image for larger version
Old 04-09-2020, 11:09 PM   #30
I'll be switching to the Bakflip Mx4 - no extended rails
https://youtu.be/lAIu9LceQLs
Old 04-11-2020, 06:39 PM   #31
Seems awfully nose high to me. Those rear tires on the trailer are going to be working a lot harder than the front ones.
corn18 is offline   Reply With Quote
Old 04-11-2020, 07:05 PM   #32
robbiels7's Avatar
Judging by post #31 i really don't think it's that nose high. You are very close to the bed rail though. My goosbox kisses my bed cover rail on extremely tight backings. Bot to worried about that though. I have only had to do that one time.Click image for larger version
Old 04-11-2020, 07:07 PM   #33
robbiels7's Avatar
Sorry i got a little sideways
Originally Posted by robbiels7 View Post
Judging by post #31 i really don't think it's that nose high. You are very close to the bed rail though. My goosbox kisses my bed cover rail on extremely tight backings. Bot to worried about that though. I have only had to do that one time.Attachment 226698
