Old 08-20-2017, 07:54 AM   #1
tugboat369's Avatar
Gooseneck or 5th wheel
I have been listening to the pros and cons of a 5th wheel hitch or a gooseneck he had a goose and it took a lot longer to unhook because it had to be raised higher then the ball if the batteries would of shorted out he could have lost his truck. I was on the fence no more pull the pin on a 5th wheel and let it hit the tail gate to the ground.
Camping from 2008, Life member Good Sam / KOA / iRV2
2014 Columbus 320RS
2011 Ford, F250, 6.7D, SRW
tugboat369 is offline   Reply With Quote
Old 08-22-2017, 05:20 AM   #2
2007 WildCat 32QBBS
18CrewDually's Avatar
Good point really for whatever reason, all you do is chock the trailer tires, block up the landing gear and pull out from under it & your done. Not happening with a ball hitch.
18CrewDually is offline   Reply With Quote
5th wheel, wheel
