Old 03-29-2018, 05:08 PM   #21
old40ford's Avatar
Originally Posted by MOODMAN View Post
This video was about using a hitch on a truck. But what about having airbags on a 5th wheel? Would that be an advantage?
That would be a YES
Retired Auto body teacher
2017 Puma 255RKS
2019 F-250 Lariat Super Crew 6.2
Having lots of Fun traveling with my wife
old40ford is offline   Reply With Quote
Old 03-29-2018, 06:17 PM   #22
Bene Gesserit Rule
Murbella7's Avatar
Originally Posted by old40ford View Post
That would be a YES
I am presuming that you mean an airbag at the pin box, right? I have a Trailair and have towed with it inflated and deflated (they do go flat after a while). With the (tiny tyre-like) airbag inflated to its correct height (it is inflated and measured according to a mark on the device, not according to air pressure) The ride in the truck is measurably improved. When I run with it flat, I feel every bump from the 5'er, with it inflated, these are smoothed out. It also reduces the amount of shock and bump on the trailer contents. Worth every penny.
Airbags on the axles of the trailer, never seen a good word (from experts).
Murbella7 is offline   Reply With Quote
Old 03-29-2018, 06:25 PM   #23
old40ford's Avatar
Air bags on the rear axle of the truck.
2017 Puma 255RKS
Old 03-29-2018, 06:56 PM   #24
Run airbags on the truck axles. They work. 9 years wouldn't be without them. Like anything if you are over loaded and not using them for the purpose they are designed, they will not be good for them or your vehicle. They smooth out the ride and allow for leveling of your rig. If you're towing an 11000 pound trailer with a 1/2 ton truck and expect the airbags to make up the difference your -----. ----- That means you're making a mistake.
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
Comanchecreek is offline   Reply With Quote
Old 03-29-2018, 08:07 PM   #25
Originally Posted by garbonz View Post
Then you ain't been towing much.
lol ok
guyster is offline   Reply With Quote
lift
