04-20-2021, 04:13 PM
#81
07 ram info
yellow sticker shows 5 persons plus cargo at 2476 pounds. Truck has a 8510 GVW
04-20-2021, 04:23 PM
#82
07 ram
See attached
04-20-2021, 04:33 PM
#83
Originally Posted by tucson
See attached
E rated tires. 2,476 CCC. That must be some sort of unicorn Ram 1500.
2015 Chevy 2500HD 6.0 4x4 CC SB
2021 Salem Heritage Glen 290RL GenY
1600W solar > 618 Ah LiFePO4 > Victron MultiPlus II > Cerbo GX
04-20-2021, 04:34 PM
#84
ram
1500 megacab
04-20-2021, 04:48 PM
#85
And this is on a Ram 1500?!? Wow, I would think a Mega Cab would have even lower payload. How is this possible? Did they used to have higher payloads 10-15 years ago?
04-20-2021, 04:54 PM
#86
04-20-2021, 04:58 PM
#87
Wow, that is crazy! Then I guess I'd have to say to the OP, if you can find a used 1500 with that kind of payload, go for it! Otherwise, you are probably going to have to find a 3/4 to get that type of payload now.
04-21-2021, 03:31 PM
#88
Originally Posted by Half Ton Heavy
What does the yellow door jamb payload sticker say the payload is?
This truck has a Max Payload rating of 3,142 lbs.
2021 Flagstaff 528RWS
2020 GMC 2500HD Diesel
2019 Labrador Retriever
1983 Wife
04-21-2021, 05:22 PM
#89
Your only regret going with a bigger truck is all the new friends you'll have...
with stuff to move.
04-21-2021, 06:03 PM
#90
with stuff to move.
As "the guy" with the pickup for many years, I know this situation well!
1983 Wife
04-21-2021, 08:01 PM
#91
with stuff to move.
Or wanting to borrow your truck.
04-22-2021, 02:01 PM
#92
I'm amazed at all the help your getting. The weight range you are talking about is within the range of well equiped 1/2 tons. Some are better, like the F-150 with the 3.5 Ecoboost, it will tow 12,500 lbs vs a F-250 with a 6.2 V8 at 15,000 lbs. Tongue weight with a weight distributing hitch doesn't come into play, that's what WDH's do distribute the toung weight between the trailer axles and the truck axles of the hitch. Others talk about brakes, you should have electric brakes on the trailer that will stop you faster than the truck alone. If your going to a rig over 12,000 lbs get a 3/4 ton diesel, a gas won't get it. My F-150 with 3.5 EcoBoost pulled much better than the 2004 F-25 gas I had in all respects.
04-22-2021, 06:25 PM
#93
It's never the weight of the trailer that's the issue. You run out of payload well before you get anywhere near the towing capacity.
04-22-2021, 06:28 PM
#94
In the decades of owning/driving pickups I've NEVER encountered such.
The word "NO" makes it clear
04-22-2021, 06:42 PM
#95
I am no expert on this so I am sure others who have towed more will comment on this, but it is my understanding that WDH's distribute the weight evenly between the front and rear axles of the truck, but do not take away the actual tongue weight. If you have 800 pounds of tongue weight, it will still be 800 pounds of weight on the tongue whether you have a WDH or not. In fact, it will be closer to 900 pounds since a WDH weighs close to 100 pounds.
04-22-2021, 07:25 PM
#96
If you are buying a new truck and trailer definitely go with a 5th wheel. Much easier and safer to tow. I would go with 3/4 ton at a minimum and a 1 ton is not much more in cost. A diesel should be reconsidered.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
04-22-2021, 07:38 PM
#97
Winnebago make a nice full size 5th wheel that can be pulled by a 1/2 ton. It only has a pin weight of 825lbs.
04-22-2021, 07:45 PM
#98
That's probably not happening!
1983 Wife
04-22-2021, 07:48 PM
#99
Excuse me sir, but this is a Forest River forum.
1983 Wife
04-22-2021, 08:30 PM
#100
He's going to tow it with a FR.
Not sure how, but we do want to see it happen!
