02-05-2020, 11:11 AM
#21
Originally Posted by mzbrandi
No key and can’t put in drive or unlock steering wheel. Use mine all the time.
Ok, so the steering and gearshift remain locked but you might lose a window before the thief figures that out.
Lots of driveway warm up thefts here in the Reno area.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
02-05-2020, 11:18 AM
#22
Do not go to a WALMART to have your batteries tested. Either go to a major repair shop, auto parts store such as NAPA or a major retailer that will load test the batteries. Have them each load tested individual. Even if just one battery test bad or has very low on voltage replace them both.
Also check your cross over cables and wiring for the battery plus all of the grounds on your truck for corrosion. Clean as necessary.
Let us know what you find out!
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
02-05-2020, 11:23 AM
#23
I love my remote start for my 2007 Duramax. I just send my Grandson out to start it on cold mornings And yes, it gets cold enough to use glow plugs here. This was between Hatch and Las Cruces NM, along the river at 6:30am:
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
02-05-2020, 11:26 AM
#24
Living up north I am curious about whether or not you use the block heater.
The DW plugs in most nights here in Ohio. With a timer, cost is about $.25 a night. No start up delay to preheat.
Additionally, the truck produces heat very quickly for the ride to work.
If you have the original batteries, it is likely time to change.
02-05-2020, 12:36 PM
#25
Originally Posted by Electra glide
I own a 2015 Duramax and live in Iowa. I use remote start every day in the winter. I've never had an issue even on the extreme cold days. I don't plug in the block heater either. Fires right up.
X2 from northern Illinois, and on my third Dmax.
02-05-2020, 01:08 PM
#26
I would never buy a battery at Walmart. Buy a name brand battery.
For .25 cents a night plug it in. Its much easier on a diesel to start them with a little heat.
2020 Wolf Pack 23GOLD15
1998 Dodge Ram 3500 Cummins Diesel Dually
02-05-2020, 02:17 PM
#27
I have started my Duramax with the glow plug light on, using the key, but as stated before the factory remote will not start until the glow plugs have done their thing. I will be replacing my 5 year old batteries soon even though they still work fine. You never know where you'll be when they stop working.
Using the block heater is definitely beneficial : batteries and starter don't work as hard, engine oil gets to it's optimal temperature faster (less wear on internal engine components), and the cab warms up faster.
2015 Solaire 201SS
2015 GMC 2500HD Duramax
02-05-2020, 03:40 PM
#28
Battery
X4-check batteries 1st. I have had very good luck w/ the Battery Plus Duracell-mid grade. They will check batteries in the truck for you and also use a power box when changing, so you do not lose any of your settings. I upgrade to group 31 batteries, if they fit-1/2" taller.
On my factory remote start, if you do not get in the truck and hit the "start" button w/in 5 minutes, it turns the truck off. Probably programable for longer time. Truck "lock" button has to hit 1st before remote start works. Steering and truck remained locked until you hit "Start" inside truck. Remote may delay several seconds if cold on diesel.
02-05-2020, 03:42 PM
#29
Thieves know about remote starts around here. They don't typically need to wait for a vehicle to be running to smash a window.
2007 Rockwood 2701SS
1953 GMC 9314
1982 GoldWing Interstate
02-05-2020, 03:49 PM
#30
Truck is a 2015. It's now 2020. Battery probably is original and it's time to replace it (them). Auto starting batteries should be replaced every 5 years even if you don't have problems with them.
02-05-2020, 03:56 PM
#31
Batteries
If it is like my car, if the programed key is not in the car, it will shut down after about 8 minutes. DW has gotten me on this, leaving me w/ a dead car in the parking lot after she walked in the store w/ the key. It gives a 2 minute warning and then shuts the car down. Not sure if it is same on my Ford, I do not let her have the keys.
02-05-2020, 04:06 PM
#32
Originally Posted by Brother Les
'New to us diesel'. You will absolutely LOVE your diesel. As you know this is a camping forum. I also belong to a Super Duty Ford Diesel forum. I go to the camping forum to 'talk' camping' and the Diesel forum to 'talk' Diesels. 'We' can offer you many suggestions, but the 'people' that you really need to talk to are 2015 Duramax owners that start their truck in the cold with a remote starter. Gassers and Diesels are two different animals. Diesels do not have 'spark plugs' and needs a higher heat source to start the ignition process. With a cold engine and cold fuel does not or never make a good fast start. What does your owners manual say about 'cold starts' (with a remote starter)? Join a Duramax forum and learn about your truck, top to bottom... front to back.
My suggestions (as I own a Diesel), do not use the remote start...(engine and fuel are 'cold'). Have fully charged and good batteries (have them 'load' tested). Cycle through the 'glow plug' sequence twice when weather is lower than 35-40 degrees and only cycle once when warmer.
Let us know what you find...
You will love your Diesel.
Not all diesels use glow plugs.
02-05-2020, 04:07 PM
#33
You will need the Glow Plugs in the cold weather. After a few years the Glow Plug Relays will burn out. The Glow Plug Relay is easy to change on the 7.3s.
A number of friends with the Dmax, including myself, have had no problems with glow plugs, and several have over 300K miles with the original glow plugs. If one of the plugs goes bad, it will throw a code letting you know. Even then, you can start it.
02-05-2020, 04:32 PM
#34
But the Duramax does, which is the subject of this thread.........
02-05-2020, 05:06 PM
#35
True but it was a quote to that person. Right ?
One should also note that batteries was not part of his question either. No one really answered his question, since you are one with the knowledge you should answer his actual question.
02-05-2020, 05:17 PM
#36
We are mostly thinking batteries is his problem. You having a bad day?
02-05-2020, 05:18 PM
#37
Do you have any codes tripped?
Brother Les
02-05-2020, 05:32 PM
#38
Thank-you for adding your trivia knowledge to the thread, any more cummins?
Brother Les
02-05-2020, 06:25 PM
#39
Duramax has a history of cracked fuel filter housings. The pump sucks air, no fuel to the pump, resulting in no start or long cranking. The fuel lubricates the pump so cranking with no lubrication destroys the pump. Big $$$$$
2011 Sabre Palomino
2006 Chevy 2500 Duramax 4x4
Camp Verde, AZ
02-05-2020, 06:34 PM
#40
Well brother les rambled on about everything except answering his question. He also said a higher heat source is needed for Diesels. None of which apply to the question. I was just trying say that the statement is incorrect.
Just seems odd that no one complained about being off topic on what was said in that statement which rambled on about about loving a Diesel and so on. But never addressed his question.
The battery idea should only come into play once the OP has provided some voltage or other information. He said the truck was new to him, maybe the batteries were replaced previously.
My knowledge is more than trivia, I have owned a truck and car repair shop for 50 plus years. Sorry if I spoke improperly. I will just leave it to the forum experts and keep to myself.
By the way if you really want to test batteries try a Midtronics MDX-600. That is what I like in my shop.
