Old 04-28-2020, 05:46 PM   #1
Have you checked your toad breakaway lately?
I recently tested my toad auxiliary braking system, a Blue Ox Patriot, in our toad. After setting it up I activated it with the wireless remote controller, then returned it to its normal position. Then I pulled the plunger out of the breakaway switch to test the breakaway. To my dismay, nothing happened. After a little troubleshooting, I decided the breakaway switch was bad.
I ordered and installed a new breakaway switch and the system works correctly. I tested it by operating it normally with an external battery, feeding through the motorhome cable, to be sure everything worked. Then I disconnected the external battery and pulled the breakaway switch plunger, causing it to activate with its internal battery, which is the way it is designed to operate.
So, when was the last time you checked your breakaway?
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
Old 04-29-2020, 07:08 AM   #2
Lins's Avatar
We have a TT, so no toad, but after reading a thread or two the last couple years about a trailer coming loose I’ve started checking it once or twice a year. Probably not enough, but better than nothing. I bought a used 22’ gooseneck before Christmas and it didn’t have one installed. It now has one.
2007 Rockwood 2701SS
1953 GMC 9314
1982 GoldWing Interstate
Lins is offline   Reply With Quote
Old 05-10-2020, 04:20 AM   #3
Mr. October's Avatar
I check mine every time we hook up by pulling the pin from the breakaway switch. It not only ensures the breakaway is working but that I remembered to turn the brake switch on (Stay-in-Play system) and I can visually check the "braking" LED light.
One tip I've found in the past is that that breakaway switch the pin goes in to is just two steel plates that the pin holds apart. When the pin is yanked, the plates connect, close the circuit, and the brake comes on. If it stops working it is usually due to rust, dirt, or corrosion. You can slip a fine file between the plates (with a bit of effort), clean them up and apply a bit of WD-40 to keep the contacts good. Also, be sure to keep the extra pin plugged in when not towing.
Pete Githens
Reading, PA
2019 Georgetown GT5 31R5
2018 Chevy Spark
Formerly - 2007 Itasca Navion (Sold and gone)
Mr. October is offline   Reply With Quote
Old 05-10-2020, 06:04 AM   #4
Good practice. I'll check mine more often, too, when we can actually go somewhere.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
breakaway, check, toad
