Old 11-20-2020, 08:02 PM   #1
JMike.VA's Avatar
Help: Need Toyota 4 Runner Extendable Mirrors
I know most of you will say “go buy a real truck”, but for now this is all we have, so it’s what it is.
We have a Forest River Vibe 18RB and will be pulling it with our 4 Runner.
The issue is I can’t see around it and have not been able to find good solid mirror extensions.
We now have a rear camera on the back of the trailer, but would like to see along the side of the trailer.
If Anyone out there knows of a solution, press share.
Thanks,
JMike.VA is offline   Reply With Quote
Old 11-21-2020, 12:26 AM   #2
dbledan's Avatar
E trailer has a whole bunch based on vehicle year. Most strap to the existing mirror. Maybe you can find one that clips on.
https://www.etrailer.com/tm-2016_Toy...tm?&Redirect=8
Change the year for the right match.
Good luck!
dbledan is offline   Reply With Quote
Old 11-21-2020, 09:21 AM   #3
Not a 4-runner, but I’ve been very happy with the flip-on mirrors from e-trailer that I bought for my F-150.
Jfkmk is offline   Reply With Quote
Old 11-23-2020, 07:39 AM   #4
Mopar Guy
when i tow with jeeps, i use milenco grand aero mirrors, solid, dont vibrate and lots of adjustment.
Dave
2019 Grey Wolf 24JS- sold
1998 Holiday Rambler Imperial 41wds
Cost4133 is offline   Reply With Quote
Old 11-23-2020, 08:40 AM   #5
Furrion makes side mounted cameras that are built into running lights for the trailer. Also allows you to see what is on the opposite side of a turn when backing that isn’t visible in a mirror.
Old 11-23-2020, 10:36 AM   #6
JMike.VA's Avatar
I purchased the rear camera model that I could upgrade to those side cameras. You are right as this being a good option, but not excited about the cost.
Thanks for the reply.
Old 11-23-2020, 11:35 AM   #7
rsdata's Avatar
CIPA brand of add on mirrors have been good for me. Look on amazon for your particular style
2014 Shamrock 183
Old 11-23-2020, 01:46 PM   #8
Fivebuccs's Avatar
Tow Mirrors for 4 Runner
We tow a Mini-lite 1905 and use these Dometic DM-2912 Milenco Grand Aero3 Towing Mirror - Twin Pack on Amazon on these from CIPA https://www.amazon.com/CIPA-11980-Un...%2C231&sr=8-19 also on amazon and while the 4Runner may struggle on some hills we have found it does the job and at some point if the DW allows we will get a pickup truck
And from another Chiefs Fan 35-31 great win
Fivebuccs
BBQ and chili cook
Retired Railroader
2017 Mini-lite 1905
2020 RAM 1500 Bighorn 5.7 Hemi
Fivebuccs is offline   Reply With Quote
Old 11-23-2020, 02:03 PM   #9
I have one of these for my '17 Tacoma TRD Off Road. It has worked fine for me
https://www.etrailer.com/Towing-Mirr...ID=20164083838
I also use one type that I can not find now which straps on to the existing mirror with two ratcheting straps. It is more difficult to hook up, but does not threaten to crack the mirror housing. I agree - seeing down the side(s) is important.
Greg 'n Deb
2020 R-POD 195 HRE
'17 Tacoma 3.5L,'07 Tundra 5.7L w/ tow pkgs.
Dirt Sifter is offline   Reply With Quote
Old 11-23-2020, 02:19 PM   #10
You will not find any 'custom made' mirrors for the 4runner...I've looked. The best you can do is buy the universal ones.
Garek is offline   Reply With Quote
Old 11-23-2020, 02:47 PM   #11
Check carid.com and look for towing mirrors.
WanderMore is offline   Reply With Quote
Old 11-23-2020, 04:05 PM   #12
CharlieP
I had a 4Runner and I liked and used McKesh mirrors. There is both a flat mirror and a convex that lets you see the dead spots. Easy to use and work well.
CharlieP
2018 Silverado 1500 Z71
2018 WS24 Roo
2018 upgrade from Popup
Charliep is offline   Reply With Quote
Old 11-23-2020, 09:26 PM   #13
CIPA mirrors
We tried a few mirrors that clipped on to the existing mirrors but none of them would stay in position. We found the CIPA deluxe door mount mirror on etrailer.
https://www.etrailer.com/Mirrors/CIPA/11650.html
They work great on our 4runner. They hang between the door and the window glass, have a brace half way down the door and hook onto the bottom of the door. (Be sure to twist the strap one time around at the bottom to prevent wind vibration)
Here's a you tube:
Mike
2020 No Boundries 19.2
2020 Toyota 4Runner
mltennis is offline   Reply With Quote
Old 11-24-2020, 08:05 AM   #14
bedubya's Avatar
What year is your 4Runner? I believe the front half of a 4Runner is the same as a Tacoma. I got the perfect fit for my 2017 Tacoma from 1A Auto. It was about a 2 hour install for this 2017 Toyota Tacoma Driver & Passenger Side Power Heated Turn Signal Blind Spot Detection Chrome Flip-Up Towing 2 Piece Mirror Set. They look like Dodge Ram mirrors. They flip up to extend.
https://www.1aauto.com/2016-19-toyot...6/1172315/2017
'19 Chevy Colorado Z71 4x4 Crew Cab
'17 Salem Cruise Lite 232RBXL
Mickey the Rescue Project Schnauzer
Days Camped: '17-39, '18-61, '19-64, '20-38
bedubya is offline   Reply With Quote
Old 11-25-2020, 08:30 AM   #15
DouglasReid's Avatar
Since you don't want to upgrade to a "Real Truck" the cost of upgrading to a good set of mirrors is the only option, isn't it?
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 11-25-2020, 08:52 AM   #16
Tapex's Avatar
X2...^^^This^^^
When I was towing with my Tacoma, I went on Amazon and found these towing mirrors as well, manufactured by a company called "Trail Ridge"
Here's my review....
Verified Purchase
These fit (2005 - 2015) Tacoma trucks. The functionality is Awesome!! I installed on my 2011 Tacoma Prerunner Dbl Cab V6. My truck already had power mirrors, so "PLUG & PLAY" made for an easy installment. Everything I was expecting is found in these tow mirrors. I ordered the power tow mirrors for towing our TT, and boy these are the ticket! We're now being able to tow safely without any seeing limitations or vibration when towing or just town driving. I highly recommend this product from 1A Auto. Better yet, I no longer have to use the ratchet straps style tow mirrors. Easy installation, made it a breeze with a great price and very well made product. I HIGHLY recommend this for anyone else who might be looking for a great tow mirror specifically for Tacoma trucks!! Thanks again 1A Auto and Amazon!!
https://www.amazon.com/dp/B0733JKM79..._blMVFb7Z202S4
2016 Coachmen Apex 250RLS Ultra Light
2023 Ram 2500 Big Horn Sport 3.73
Tapex is offline   Reply With Quote
Old 11-28-2020, 12:34 PM   #17
bedubya's Avatar
Originally Posted by tapex View Post
X2...^^^This^^^
Verified Purchase
I love mine, too! My Taco is a '17 with mirrors that are heated, have a turn signal, and blind spot detection. The mirrors I got have all that. A minor detraction is that the mirrors that have all those bells and whistles only come in chrome and I had been hoping to paint them to match. When I was using strap-on mirror extensions, meeting a semi on a two-lane road sometimes caused the mirror to fold in. These mirrors stay put, but still fold in when you want them to.
But the OP will need to make sure they will fit his 4Runner. The OEM mirrors look the same, but 1A Auto Parts does not show them fitting a 4Runner.
Old 11-28-2020, 01:40 PM   #18
JMike.VA's Avatar
Our 4 Runner is a 2013.
Those really look fantastic and are so functional looking.
I would think they would work too, so I called the company and they said they would Not fit.
That is crazy because I’m like you, I thought the Tacoma and 4 Runner were the same on the front too?
JMike.VA
Camper: Forest River Vibe 18RB
Towed by: Toyota Tundra
Old 11-28-2020, 01:42 PM   #19
JMike.VA's Avatar
The company said they wouldn’t fit.
I am just not convinced that is correct, because I thought the Tacoma and 4 Runner were alike on the front part.
JMike.VA
Old 11-28-2020, 02:34 PM   #20
Tapex's Avatar
I sold my '11 Tacoma with the those mirrors still installed on it. Not sure what the buyer thought, since I traded it in for a New Ram. Which tows way more safer.
toyota
