Originally Posted by thebrakeman
cowracer,
I agree with you, that these discussions often lose sight of what the OP was asking for. However, you must admit that the same things happens when someone starts a discussion asking for advise on a WDH that won't break the bank. Hennesley (sp?) and Propride users come out of the woodwork to tell them they are silly to spend 10's of thousands of dollars on a truck and trailer, and not get the best WDH, regardless of cost. We all do this. It's part of discussion threads. As long as people aren't being nasty, it's OK.
For my parts, I was not so much pooh-poohing any hitch, as much as cautioning those reading about how any hitch might be used with negative tongue weight ("not that I/you would" ), and be assured of a flawless tow.
I don't tell anyone they are silly. If they mention price (As in "what's the best WDH for the money") then I'll recommend the Reese Dual Cam. Worked very well on my prior (smaller) camper. Got a tad overwhelmed with the new one (yes, yes, I know. Some people pull 8329's with regular WDH's just fine). But if they ask "What hitch controls sway the best" then I got to go with the high-dollar big dogs.
I will admit that owing one of these hitches does tend to make you a zealot for them. It's hard to keep that in check sometimes. Especially when people spout of with "Well, I've towed fully loaded warehouses down the road for 82 years with nothing but a straight up ball hitch and no WDH and I've never had a sway once with that. Not even thru hurricane Daisy. And if that's good enough for me, it's GOOD ENOUGH FOR YOU!!!"
well... maybe not in those
exact words.
Tim
P.s. The negative weight thing came from a video on youtube. We have all seen the model car/trailer on the treadmill, and the guy shows how nice it pulls with adequate tongue weight, and then moves a weight from the tongue to the back and it goes completely out of control. Right?
There is a similar video of a model car and trailer with a model Hensley hitch. And its waaaayyyy heavy on the back end (judging by the weight on it) and it still does not sway even a bit. Again, not that I would do it (or could even figure out how I could) , but I have 100% confidence that if I could get my tongue weight down to zero, or even just a few pounds negative, I still would have a smooth pull with no sway.
Of course start getting a couple hundred pounds negative weight (enough to unload the rear axle) and sway will be the least of your concerns.
Tim
