Old 01-22-2020, 08:58 PM   #1
Hitch recommendation for Geo Pro
I am going to buy a 2020 Forest River Rockwood Geo Pro G19FBS. The trailer weighs 3075# empty with a carrying capacity of 1338#. I will be towing it with a 2004 Toyota Tundra with a towing capacity of 7200#. I would like some recommendations for a weight distribution hitch and sway control. The dealer is is pushing a Husky hitch with add on sway control.
tempestdriver is offline   Reply With Quote
Old 01-22-2020, 09:09 PM   #2
Scoundrel
HangDiver's Avatar
I'm sure its the old style Husky with chains and friction sway control. That's what I use and honestly I would not recommend it. Will it work on your Tundra/Geo Pro? Yes. But there are better hitches available such as the Equalizer 4pt or even the Husky Centerline with integrated sway control (among others), and are likely easier to use.
I will be getting a new WDH to replace the old-style Husky with chains.
Good luck with your new TT
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
HangDiver is offline   Reply With Quote
Old 01-26-2020, 07:02 PM   #3
cherokeebill's Avatar
We have a E pro 19fd and tow it with a Jeep Cherokee. We use a Fastway E2 WD hitch with sway control. No chains and you can choose trunion bars or bent bars. We have the bent bars. We are very happy with the set up. Ecellent WD when set up right and the sway control must be good because we have experienced zero issues with the system. Highly recommend it and reasonably priced too.
2018 E-Pro towed by 2019 Jeep Cherokee Limited
cherokeebill is offline   Reply With Quote
Old 01-27-2020, 02:25 PM   #4
Head Rambler
I would also recommend the E2 for that setup. You can decide if you want bent or trunion bars. I prefer the trunion bars, but six of one half dozen of the other.
Gotta go campin!
Old 01-27-2020, 02:32 PM   #5
Chief T's Avatar
x2
2012 GMC Sierra 1500 SLT Z71 6.2l aka "Luci"
2020 Grand Design Imagine XLS 22 MLE aka "Desi"
Past: 2017 Prime Time Tracer Air 206
Days camped 2017: 7
Days camped 2018: 15
Days camped 2019: 17
Chief T is offline   Reply With Quote
Old 01-27-2020, 04:11 PM   #6
bikendan's Avatar
E2!
Equalizer WDH
Old 02-13-2020, 04:54 PM   #7
What capacity Fastway E2 WD are you using with the 19fd?
Don B. is offline   Reply With Quote
Old 02-13-2020, 05:57 PM   #8
Don, the hitch we are using is the one rated for a max of 600 pound tongue weight. We bought it through hitchweb.com and the partnumber is; 94-00-0600. I like it in that the sway control is built in and it does not use chains. Overall I am pleased with it and it came at a competitive cost.
Old 02-13-2020, 09:28 PM   #9
Trailer Park Supervisor
NJKris's Avatar
I have a similar sized single axle trailer and am happy with the Fastway e2 trunnion bar style with 800 lb bars. Our trailers, loaded, have a very heavy tongue weight, could be pushing 700 lbs. The 800 lb bars accommodate this without being too high of a capacity, which is not desirable. Got from etrailer for 350 bucks, price has gone up a bit since then. Probably steel tariffs.
NJKris is offline   Reply With Quote
Old 02-13-2020, 09:35 PM   #10
Multi-Slacker
We swapped out a Husky Centerline for an Andersen. The whole Andersen setup weighs around 50 lbs and has effective sway control. Easier on and off.
2017 Forest River Sonoma 280RKS
2018 Silverado 2500 HD 6.0L, 4:10 rear
CurtPutnam is offline   Reply With Quote
Old 02-13-2020, 10:11 PM   #11
A short follow up to my previous post. As you can see from my signature we tow with a Jeep Cherokee that has a factory tow package. When we bought the trailer our dealer helped us set up the WD hitch. After set up and when hooked up the front of the Jeep rises less then one inch. That demonstrates that the set up is correct I believe. Unlike some other users, I know our tongue weight is not to high, in fact I scaled it when loaded. The loaded tongue weight was about 450 pounds, the trailer scaled at 3500 pounds. Hope this helps.
Old 02-13-2020, 11:29 PM   #12
Go West's Avatar
I use a Husky Centerline with 600-800 lb bars; but my trailer is a little heavier than yours (5,200 lbs on the road, tow vehicle is a half-ton Titan). If you keep your trailer to 4,000 lbs, go with the Husky Centerline model 32216 (400-600 lb bars, 6,000 lbs gross trailer weight). I've towed thousands of miles with this hitch and have never experienced trailer sway. Easy to adjust for very precise weight distribution. You can get this hitch for a little less through E-trailer.
https://www.huskytow.com/husky-towin...ribution-hitch
Name:	Husky Centerline TS_LI (3).jpg
________________________
2017 Cherokee Grey Wolf 25RL
2017 Nissan Titan SV 4x4
Husky Centerline TS
Go West is offline   Reply With Quote
Old 02-13-2020, 11:38 PM   #13
Whatever hitch you decide on, shop for it online and it will be about 50% of what the dealer charges for it.
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
GOTTOYS is offline   Reply With Quote
Old 02-14-2020, 07:34 AM   #14
NJKris's Avatar
Surprised your tongue weight was so low. Do you have dual batteries? I plan on bringing bikes more often down the road, so the rack plus two bikes will add at least 50 lb. Also, if you store anything in your TV behind the rear axle, that is to be considered part of the tongue weight as well.
Old 02-14-2020, 08:21 AM   #15
jcr59's Avatar
Fastway E2.
There are a lot of good hitches out there. Most of them perform pretty well. They vary in design, price , and weight. I chose the E2 due to the design(integrated sway control) and price. For now the weight is not an issue for me. That could change as the years go by and I may change my mind.
John & Cheryl
2016 Ram 1500 Big Horn
2019 Palomino Solaire 202RB
"Why yes, this is my circus and these are my monkeys!"
jcr59 is offline   Reply With Quote
geo pro, hitch
