09-19-2019, 09:59 AM
Hitch Tightener
I bought the hitch tightener and the nuts dont want to stay tight when using on my husky center line hitch.
Iam thinking maybe too much movement/weight. I am using the supplied nuts, washers, and lock washer.
When I get to my destination, the nuts are loose and it is not doing it job anymore. And I make them really tight, even to the point of bending it a little. Any ideas? or is there others that your using that stay tight and work. Thanks.
https://www.amazon.com/Mission-Autom...NsaWNrPXRydWU=
09-19-2019, 10:04 AM
Try loctight on the nuts.
09-19-2019, 01:50 PM
I tried that hitch tightener and found that it was just not heavy duty enough. It would probably be ok if you were just using a hitch carrier, but not a travel trailer.
Try this one instead:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I just installed it on my hitch, and I'm heading out for 2,000 miles tomorrow. I'll report back at the end of my trip.
2013 Ram 1500 CC 4WD
2019 Rockwood 2503s
09-19-2019, 02:31 PM
Since you have already spent the money try adding lock nuts-a second set of nuts that are tightened against the others. You will need two wrenches to do this.
2019 Cedar Creek 29RE
2017 Silverado Duramax 3500
09-19-2019, 02:38 PM
Just curious what’s the point of this?
09-19-2019, 03:53 PM
Let me know how that one works out. It looks like the idea Rocco52 had by using the two lock nuts. Thanks
09-19-2019, 03:55 PM
When you put your hitch into your receiver there is play and it moves/rattles. This just keeps it all tight and no play in receiver. Its not really a must, just a preference.
09-19-2019, 03:56 PM
I thought of that, but I need to take it off/on every time I use the hitch.
09-19-2019, 04:31 PM
Blue Loctight does not require heat to remove. I use it on anything that a lockout won't hold. Read the package label to get the right one. Only,use the RED if you don't want to take apart all the time.
09-19-2019, 04:34 PM
Blue loctite, good to know. Thank you.
09-20-2019, 03:13 PM
Or replace original nuts with "Nylock" nuts.
The added nylon material staked into one side will keep the nuts from loosening on their own. Double nuts work too but require two wrenches of the same size.
09-20-2019, 03:26 PM
I have that one currently and have to torque the poo out of it to keep the nuts on. I had one similar to the other posted a while back but it bent under the weight of the camper.
09-20-2019, 04:24 PM
I will give them a try, thanks. Lots of idea's here. I will try and use what works.
09-20-2019, 04:25 PM
Okay, so I am not alone here. I will try some options given. Thanks
09-20-2019, 04:51 PM
I've got one that's 200% better than either of those, I'll look at it tonight and post the brand, think I found it on ebay. Really locks down the shank.
Found it:
https://www.ebay.com/itm/Hitch-Vise-...wAAOSw4e1dTF0U
09-20-2019, 05:27 PM
I'm going to get some flak for this but here goes, most people using hitch tighteners with a WDH are mounting them upside down. This stretches the bolts every time the hitch bounces up and down which loosens the nuts. The shank needs to be pulled upwards, not down.
When the WDH spring bars are 'loaded', the shank pivots vertically on the hitch pin, lifting the rear of the shank and forcing the forward portion of the shank downward. The majority of the tongue weight is applied to the hitch pin but the remainder of the load is applied to the nose of the shank where it contacts the floor of the hitch tube forward of the hitch pin. That's how the load is able to be transferred to the front of the TV.
09-23-2019, 09:54 AM
Originally Posted by nayther
Thanks, I will give it a try if all else fails. Thank you for the post.
09-23-2019, 09:57 AM
Thanks, I install mine the same as in your pic. I see that the one in pic uses two nuts. Maybe there is something to be said about that. Thanks for the post and info.
09-23-2019, 10:02 AM
I was using one similar to the OP's and was having the same problem with the bolts loosening up unless I really cranked down on them. The problem I found out yesterday when I got back from a short trip was that by cranking them down too much it ended up breaking the U bolt so you need to be careful with overtightening it I guess.
09-23-2019, 10:31 AM
My solution for this issue is "Heavy-duty Die Springs " placed around the U bolt studs and then install the nuts! Tighten until the movement is eliminated! I have a very long Hensley stinger bar plus Rock tamer flaps, so I know about "Movement "! Youroo!!
