01-04-2021, 09:06 PM
How do you know what hitch to buy?
I bought a 33' 273 qbxl. 6,000 UVW, 750 hitch weight, 1,724 ccc. Will be towed with a 2015 Silverado 2500 w/ tow package. I'm having a tough time trying to pick the right hitch for this setup. I really don't won't to spend $3k either. Any suggestions or guidance on how to buy the correct hitch would be appreciated. The dealer recommended a blue ox sway pro.
01-04-2021, 09:24 PM
Georgia Rally Coordinator
Go with the 4 point equal-lizer hitch. I use the 1400 # one and worked great. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
01-04-2021, 09:57 PM
Should I get the 1,000 or 1,200 # ?
01-04-2021, 10:01 PM
I would go 1000, other than for sway I doubt you will need a WD
2022 Chevy 3500 Diesel SWD
2022 Columbus 329 DVC
01-05-2021, 10:15 AM
We have the equalizer as well and it does well. Learn where to apply grease per the manual to keep it quiet.
2007 Rockwood 2701SS
1953 GMC 9314
1982 GoldWing Interstate
01-05-2021, 01:47 PM
Another vote for Equalizer. I have the 1400# version pulling a toy hauler with 11400GVW and a tongue weight of around 1200#. Would buy again for sure.
01-05-2021, 01:55 PM
I like the Blue Ox sway pro.
Since you won't need to return much weight to the front an Anderson hitch might be worth looking at, I have no experience with it but it is an interesting design and has good reviews.
2024 Artic Wolf 3018 Suite 5th Wheel
Prior TT Grand Design 2800BH TT 2021 - sold 4/24
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW Lariat Ultimate
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload - sold 4/24
01-05-2021, 02:00 PM
Since you mentioned $3000, you seem to be at least intrigued by a Propride or Hensley. You don't have to buy new - check for used ones. I just did a quick web search and saw several up for sale for around half off, on in Allentown, one in Indiana and one in Colorado.
Just something to think about.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
01-05-2021, 02:26 PM
Here is another vote for the equalizer. So simple to use and very effective.
01-05-2021, 02:31 PM
What he said.
2019 Hemisphere 272RL
2015 Ford F250 6.2L
2005 Jayco Bantam Flier
Hensley Hitch
01-05-2021, 02:54 PM
Take a look at the Husky Center Line TS Hitches 800-1200lb TW or the 1k-1,400lb TW models. I can't comment on the Equalizer Hitches I have never tried one but they are popular along with the Blue Ox hitches. I don't think you will go wrong with any of those.
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30X
I had a Blue Ox and wasn't that impressed with it. I'd listen to the Equalizer crowd. I've heard a lot of good things about this hitch.
01-05-2021, 03:21 PM
My recommendation too!
01-05-2021, 03:35 PM
Your vehicle was tested for handling issues with tongue weight (SAE J2807)...check the owners manual for your truck.
Mines a '17 and they made a few changes in those two years (so it may not be the same). My truck doesn't require a wdh for 2000lbs on the tongue and I pull my trailer with 1500lbs on the tongue with no issues. One handed driving across the windy plains and I do the speed limit when conditions allow.
Skip the wdh hitch (if your manual says you don't need one). Buy a decent height adjustable hitch. Load the trailer so the weight is forward (tongue heavy), keep from adding any weight behind the trailers axles and test it out. Why spend the money if you don't need too?
24 Ram 3500 CC/SRW/LB/50 gal tank/CTD
2024 XLR 31A LE
01-05-2021, 07:48 PM
I like my Equalizer a LOT. Get the (optional from Equalizer) rubber pads that fit under the sway bars at the trailer end. The anti-sway properties are not affected, but all of your camping neighbors will much appreciate the substantial noise reduction they provide when you need to sneak out of a campground at 5 AM.
2015 Wildcat Maxx 28' pushing a 2020 F350 6.7L
01-05-2021, 08:23 PM
Yet another vote for 1000 equalizer. You have a 3/4T truck certainly don't need a propride at $3K, likely don't need any WDH.
2019 F150 4X4 7050 GVWR 1903 payload
2018 Avenger 21RBS 7700 GVWR
01-05-2021, 10:48 PM
One more for Blue Ox sway pro. Set up easy. Tows great. The chains allow to shift more or less weight depending on how I'm loaded and water water. My fresh water is in front close to tongue while the gray and black tanks are behind the axles.
01-05-2021, 11:41 PM
I agree that most likely you won't need the WDH. But I would get it as there will come a time that you wish you had it. When you decide that you need it, you will be out the money of the non-WDH.
When I bring my 6155# UVW (8180# GVW) TT home from storage, I just drop in on my 2500 HD TV's WDH but without the bars. But after l load it up for travel, I add the equalizer bars and sway control bar.
Your TT will be slightly lighter at 6028# UVW and 7752# GVW than mine, but it is roughly 5 feet longer. Do you want to just use a non-WDH hitch and leave your trailer rolling down the road by itself. Will you be using the brakes on the trailer or just use the TV brakes? I don't think you'll regret getting a WDH w/sway control.
Good luck and be safe.
2018 Cedar Creek 36CK2 (40.5ft)
TST Cap System (Tire Monitoring)
2021 Chevy 3500HD Crew Cab 4X4 DRW Duramax (replaced 2015 Chevy 2500HD Crew Cab 4X4 Duramax)
Curt A25 5th Wheel Hitch (replaced Demco 18K Auto-slide)
01-06-2021, 06:10 AM
ysidive
I have a 2018 Chevy Silverado 2500 Duramax and I use the Equalizer hitch... Buy it once and don't look back... You may not need the equalizer, but the anti sway and the control are worth it. Great support from the company and an excellent product made in the Good old USA...Don't worry about the ones that say it is noisy. You only hear it while moving very slow with windows down.
2018 Duramax 2500 LTZ
Freedom Express 281rlds
Days Camping 2021 46 Days
Days Camping 2022 Not Enough
01-06-2021, 08:20 AM
I'll jump on the don't bother with it boat. Try it out before you buy. Most likely you do not need it on your truck. If you do not have sway issues why bother. It's just one more thing you need to buy and set up when loading/unloading. If you decide that you need sway control and you want a WDH I am very pleased with the Andersen. My situation is different than yours but the hitch is very easy to set up, quiet, has excellent customer support, and is about half the weight of the equalizer and other anti-sway WDH's. That wil not matter for your payload, but will make it easier to put in your hitch.
Hobienick
2022 Grand Design Imagine 2800BH
2020 Rockwood Roo 19 (Sold Jul 2022)
2012 F150 SuperCrew Ecoboost
