Old 11-19-2020, 09:13 PM   #1
How to haul my motorcycle?
I just bought a 2018 e pro e19fbs. I have a small motorcycle Yamaha tw200 that I would like to bring along. It weighs 275lbs.
I was hoping I could mount a hitch to the rear of the camper and haul my bike on my hauler that goes in the hitch. This camper has no rear bumper and it looks like it would be hard to get to the frame due to the black and grey water containers.
Anyone out there haul a small motorcycle on one of these? I also thought about taking the batteries and propane tanks off the tongue and hauling it there, but the tongue is too short.
I am open to thoughts.
Thanks again.
DjSS is offline   Reply With Quote
Old 11-19-2020, 09:18 PM   #2
TowPro's Avatar
Use a truck and put it in the bed.
2019 Forest River Forester MBS 2401R
TowPro is online now   Reply With Quote
Old 11-19-2020, 09:22 PM   #3
My wife does not like my old truck, she would rather tow it with her Yukon. The Yukon is much more comfortable.
Old 11-19-2020, 09:25 PM   #4
I think that if you can't find a way to carry it in your tow vehicle, it is probably going to need to stay at home.
I have a Flagstaff 21DS that comes with a rear bumper and a receiver rated at 300lbs. I would be *super* dubious about putting that much weight on the back - partly because it is so close to the limit, but mostly because of the weight it would be taking OFF of the hitch.
Depending on the relative distances of axle to motorcycle and axle to hitch ball, you are easily removing 175-200lbs of tongue weight.
-Qwkynuf
2003 F150 Supercab 4x4, tow pkg, 3.55 gears
2020 Flagstaff Micro Lite 21DS
Qwkynuf is online now   Reply With Quote
Old 11-19-2020, 09:30 PM   #5
I thought about it taking away tongue weight but with the batteries and full propane tanks it already has much more tongue weight than advertised.
I seen folks out of the highway with small motorcycles on the rear of campers. I have never looked at one up close.
Old 11-19-2020, 09:34 PM   #6
Virginian's Avatar
I agree. I'd be reluctant to put it anywhere on the trailer, even if you could find a place.
2019 Wolf Pup 16FQ - bought new 3/2020
2013 F150 5.0 STX SCab 4x4 SB/3.55 rear/tow pkg./36 gal. tank/1695 Payload/7350 GVWR
Andersen Hitch
Virginian is offline   Reply With Quote
Old 11-19-2020, 09:36 PM   #7
Virginian's Avatar
I would imagine that the single axle is probably already near the limit for the tires and axle by time you load the trailer with camping supplies.
Andersen Hitch
Old 11-19-2020, 10:01 PM   #8
Perhaps a welding shop could fabricate a carrier that attaches to the frame of your trailer rather than the bumper. I have a hitch on the back of my fifth wheel that is attached to the frame and I pull a small trailer with a Polaris RZR. I also added a camera to the back of the fifth wheel so I could watch for sway, blow-outs, etc. The camera has been great as it cuts out lots of stress from not being able to see what is behind me. Towing is almost like driving my car now.
comfun1 is offline   Reply With Quote
Old 11-20-2020, 08:36 AM   #9
I guess for now I will just have to use my pick-up and listen to the complaints.
Old 11-20-2020, 08:48 AM   #10
REL
Saw this on another site. Pretty sketchy.
REL is offline   Reply With Quote
Old 11-20-2020, 08:51 AM   #11
KyDan's Avatar
I hauled mine in my truck bed for many years. It's a bit larger/heavier bike than yours and mine scared the %^&*# out of me every time I put it in or out of the bed. Backing that 400+ LB bike down the ramp gave me a racing heart and cold sweats! Your bike is just the right size for carrying in the bed of a PU truck.
Answer is a new truck!!
Good luck and Happy Trails!
Edit-- Previous truck was a 2004 Silverado 2 wheel drive and the bed and tailgate was fairly low. Newer trucks (incl my Nissan) have higher bed and tail gate heights and my old 6 piece arched ramp is not long enough to work with my new truck.)
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32, 2020-41
Old 11-20-2020, 09:34 AM   #12
put a receiver hitch on front of truck. with a tray for cycle. make sure to watch temps. oil cooler temp if you dont have a oil cooler. they are a cheap add on.
Thomas ho is offline   Reply With Quote
Old 11-20-2020, 09:52 AM   #13
Putting that much weight on that light of a trailer, that far back, ignoring that the frame most likely can not support the loads that it would cause, will take most of the weight off the hitch, and towing it would be dangerous.
The only solutions would be in the bed of the truck, or on the front bumper as mentioned above.
Wileykid is offline   Reply With Quote
Old 11-20-2020, 01:31 PM   #14
Front hitch
Try this
pdqparalegal1 is online now   Reply With Quote
Old 11-20-2020, 01:39 PM   #15
Front hitch is the way to go.
2017 Chevy Silverado 1500 4wd
2019 Wildwood FSX 260 RT
2012 Harley Davidson Street Glide
2016 Yamaha Wolverine R Spec
atkbike is offline   Reply With Quote
Old 11-20-2020, 01:45 PM   #16
Front carrier, very common. We first started using them in 1976.
Rockwood Ultra Light 2304DS, towed by 2018 Ram Cummins Diesel 2500 4x4
RobbieH is offline   Reply With Quote
Old 11-20-2020, 01:47 PM   #17
TowPro's Avatar
I had a KTM300 (225 lbs) on the back of a 30' 5er once and it affected the package so bad the 5er started to sway like a normal tow behind trailer does when trucks pass you.
You could put it on a front hitch, it would not block too much air, but can the tow vehicle take the extra front weight? don't forget your Weight Equalizer hitch is also transferring weight onto front axle.
they do make front hitches for yukon, they all seem to have max weight 500 lbs.
Old 11-20-2020, 02:06 PM   #18
This is why you can buy a hybrid toy hauler, ramp and camper
New WolfPup 18RJBBL Toyhauler
98 Ford Ranger 4x4,4.0, 3.73 axle, Automatic, ATF Cooler, Perfect Launch Aluminum Differential Cover, Royal Purple, Engine oil, Filter, ATF Fluid, and gear oil.
Retired mechanic & OTR TruckDriver Owner Operator
20 yrs + 1 million miles
Newbie Pup Owner is offline   Reply With Quote
Old 11-20-2020, 02:22 PM   #19
Guess the wife could tow the trailer with the Yukon, while you drive the truck with the MC in the back.
KaptnKirk is offline   Reply With Quote
Old 11-20-2020, 02:23 PM   #20
KyDan's Avatar
You need to get your wife's RV weighed with the trailer attached.
Pay particular attention to the front axle weight.
Read your door sticker and/or owners manual to see what
your max front axle weight limit is.
Also first and THE MOST IMPORTANT- ask wife what she thinks about having a hitch installed on the front of her vehicle AND what she thinks about hanging your motorcycle on there!!
Good luck!
Peace!
Dan & Rita D
Blue Ox WD hitch
motorcycle
