Old 09-05-2019, 01:54 PM   #1
I'm unable to delete this thread. Sorry!
I'm sure I should be able to delete this thread, but I can't figure it out. Ignore me.
Mrs. Shockley
2017 Rockwood Mini Lite 2503s
2016 Ford F 150 3.5 L Ecoboost
Mrs.Shockley is offline   Reply With Quote
Old 09-05-2019, 02:14 PM   #2
bikendan's Avatar
You only have a 2 hour window to edit or delete a post.
After that, you have to contact a moderator to have it done.
Old 09-05-2019, 02:25 PM   #3
Ejs4029's Avatar
I use a Husky Centerline and my bars are tight but not extremely tight....When hooking up I just push the bars over with my foot until I can use the loading and unloading tool and when unhooking I just grab the bar by hand and pull it over enough to remove it after using the tool....I would check with Husky and see what they recommend they have great customer support Oh and I only move the bars enough to get them unhooked from the hitch no need to swing them out so that they are so far away from the brackets.
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30C
Ejs4029 is offline   Reply With Quote
Old 09-05-2019, 02:59 PM   #4
I edited but never found the way to delete.
Mrs. Shockley
Old 09-05-2019, 03:09 PM   #5
Look around the edit page. At the bottom right it says: Save, Go Advanced, Delete, Cancel.
Old 09-05-2019, 03:19 PM   #6
Not on mine it doesn't. It loves me and doesn't want me to go away.
Mrs. Shockley
Old 09-05-2019, 05:53 PM   #7
wmtire's Avatar
You cannot delete after there are other member replies. Only a moderator can do such, and they will only do so under certain criteria.
2011 Flagstaff 831 RLBSS
I'm trying to keep up with the Joneses, but every time I catch up, they refinance.
