Old 12-28-2019, 10:25 AM   #1
Installing stealth brake buddy
Hello, I am planning to install a stealth brake buddy. I received it from the individual that I bought my sunseeker from. It is missing the vacuum teeís and check valves for the vacuum pump.
1st question, is the vacuum pump required for towing a Jeep Wrangler?
2nd question, Iíve done some initial searches on amazon, but limited luck. Anyone located the vacuum parts from an alternate source? Trying to install over the holiday so not sure can get it from the manufacturer.
Cblount is offline   Reply With Quote
Old 12-28-2019, 11:06 AM   #2
Lots of auto parts stores have vacuum tees and check valves. You need to install the vacuum pump for any TOAD with the unit.
2015 335DS
ScottBrownstein is offline   Reply With Quote
