Most 3/4 ton diesel trucks are going to be 2,100 - 2,500 lbs of payload. They are severely payload limited. You can make good arguments about the artificial nature of this, but the numbers are the numbers.
9,500+ lb 5er is probably putting 1,900 on your pin. Add 100 lbs for the hitch. That’s 2,000 lbs. Add in your 700 lbs of in-the-cab weight. 2,700 lbs without so much as a stick of wood in your bed. Highly likely you’re over payload/GVWR for that truck. I’m sure it pulls great; you’re over specified weight ratings.
Former RV: 2018 Rockwood Mini Lite 2504S
