Thanks again all. Learning lots of options from all of you and I appreciate it.
I finally pulled the trigger on the Husky 3000. The remote idea on the 4500 sounded nice - but I think the 3000 is a good balance of extra sturdiness, cost, amp usage, and a nice buffer of lift capability (if following the 1/2 trailer weight rule). And it comes with a hand crank if needed.
Sounds like the majority prefer to wire direct to the trailer battery setup so that is the route I'm planning. I'm also adding a battery cutoff switch to help reduce any trickle drain when we leave the camp ground for the day, etc. I noticed things like the carbon monoxide detector pull a decent current.
I've only had to use the hand jack on my trailer once the day I took delivery... and I must say I'm looking forward to not doing that again... lol.
