Old 09-24-2014, 01:29 AM   #1
Leveling kit
I was just wondering, if the 2 inch leveling kit I put on the front of my F350 DRW has any adverse effects on my towing or set up, especially if I decide to get a weight distribution hitch.
rblack22 is offline   Reply With Quote
Old 09-24-2014, 06:11 AM   #2
TURBS's Avatar
I put a 2" torsion lift key on my silverado and all is well.
Now I put the 2" lift in so my truck "looked" level NOT towing so when my 5er is hooked up the truck looks slightly nose high.
I'll be putting my air bags on this winter to level truck when towing.
I only tow trailer about 2% of the time so I wanted the level look the other 98%.
Turbs
Old 09-24-2014, 12:20 PM   #3
With a 350 DRW I doubt your Tw is enough to drop the rear much. What's the TW of the TT? Bags would bring it back to level if the WD won't. Problem is if you're using a WD with built in sway control then you'll be relieving the sway control properties if you hook up the WD and then inflate the bags to level.
goduc is offline   Reply With Quote
Old 09-24-2014, 08:04 PM   #4
Hmm that's a conundrum fur sure
Old 09-24-2014, 08:08 PM   #5
Actually without even airing up the bags my truck sits level hooked up and I don't have a WDH.
Old 09-24-2014, 08:31 PM   #6
I run the 2 inch level kit in the front of my 350 and have no issues with my 8k tag or 16k 5er. and I tow probably 5+ days a week.
2007 Cardinal 362bhle 5er
2006 f350 Diesel CC LB 4x4 4.10 locker lariat
1966 Mustang coupe...under construction
2004 Explorer 4.6 awd (16 year old daughters car)
2009 Mazda 6 (wife's ride)
Bunkfamily is offline   Reply With Quote
Old 09-24-2014, 08:43 PM   #7
Groovy thanks
leveling
