Originally Posted by thebrakeman
Madmaxmutt:
You said it transferred "plenty of weight". Please confirm that you either measured front axle weights (before and after attaching/engaging), or measured front wheel well height (before and after).
Yes, weighed several times and measured a hundred times with the F150. My seat-o-the-pants feeling is that it worked better after applying the 2" welds to the trailer frame.
Most have found that when you are pulling a trailer much more than half the capacity of the truck (or more specifically, pushing significantly into the rear GAWR), the Andersen runs out of ability to return lost weight to the front wheels.
I feel like this is an over assertion. "Most" have probably not found anything. "Most" owners I have met love theirs. I cannot speak for the smaller SUV, but it always moved the required weight and leveled the F150 with a max of 6500 lbs trailer. That is way above 1/2 the capacity of my old truck.
The F350 needs no help at all, but it also puts the wheel wells back where they belong on Super Duty
No it doesn't work like an equalizer, but it also doesn't weigh 150 lbs, which was the point to the OP. I think analogies and comparisons don't work well because the technology is simply different. Compare coil springs to leafs to bags . . .
This hitch still uses a twisting motion from pulling instead of a twisting motion from lifting. Both types twist the head to lift the truck. In the Andersen case, the chains pull the bottom of the head back, forcing the top of the ball forward. That twist is what lifts the hitch.
