Old 10-08-2020, 06:27 AM   #1
DELI MAN
Long bed versus Short bed
Ordered a 2021 F350 DRW. Production start is November 1st. It is also my daily driver. Can't decide if I want Long or Short. I have a 6.75 box on my F250 and Pullrite Super Glide. Will be pulling a 40 foot 16,000 5th wheel
star52656 is offline   Reply With Quote
Old 10-08-2020, 08:28 AM   #2
007matman's Avatar
I'd go long bed.
007matman is offline   Reply With Quote
Old 10-08-2020, 08:30 AM   #3
Originally Posted by 007matman View Post
I'd go long bed.
X2
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 10-08-2020, 08:38 AM   #4
Jim34RL's Avatar
Since you already have the slider hitch, I would go with the short bed truck! Also you are use to the short bed truck and the limitations of the short bed truck!
To me the deciding factor is the wheel base on the new Ford truck, do you know what the wheel base is?
My current truck has a wheel base of 160.5" for my short bed truck. This is longer than a regular cab, long bed truck which has a 140.5" wheel base. So, for a better ride the wheel base is what matters to me.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 135K+miles
Old 10-08-2020, 08:45 AM   #5
llr
I don't believe the dually is available in a short bed
TT 2017 Flagstaff 831CLBSS Classic Ultra lite
TV 2017 F150 6.5' bed 3.5 Eco-boost
prior TV 2014 Silverado 2500 HD
llr is offline   Reply With Quote
Old 10-08-2020, 08:53 AM   #6
You have the best short bed auto sliding hitch. So a longer bed is not necessary.
The longer bed is harder to park always. Turning radius. Advantage to the 450. Different steering set up. If you drive it daily you will care.
All hd trucks ride rough. I doubt you would notice a difference.
Long bed is better for hauling lumber!
No bad answer. Both great.
tomkatb is offline   Reply With Quote
Old 10-08-2020, 09:30 AM   #7
Correct...DRW is only available on the 8' bed
2020 Flagstaff Micro Lite 25BRDS
2011 Ford F-150 XLT 5.0L
Kcoulter is offline   Reply With Quote
Old 10-08-2020, 01:37 PM   #8
Grammar Pedant
67L48's Avatar
As has been stated above, DRW = 8' box. Period.
If you're going with a Ford DRW, then I'd personally go with the F-450. Stance, ride, and dimensions will be about the same, but you get bigger tires (pros and cons), bigger brakes, and, most importantly, the wide-track front axle. It will have the turning radius of a mid-size SUV ... you'll be doing full turns where even a short bed truck will be doing 3-point+ turns. Plus, the wide-track has burly fender flares that complement the massive DRW fenders.
F-350 SRW or F-450 DRW would be my personal considerations for a large 5er.
Former RV: 2018 Rockwood Mini Lite 2504S
67L48 is offline   Reply With Quote
Old 10-08-2020, 01:56 PM   #9
X2. The long bed rides much better anyway. You'll get used to parking it.
boogiejack75 is offline   Reply With Quote
Old 10-08-2020, 02:11 PM   #10
Jack350's Avatar
Will the 2021 SD have the larger screen on the center dash?
Jack350 is offline   Reply With Quote
Old 10-08-2020, 03:38 PM   #11
Long Bed. My F350, Crew Cab, Long Bed is wonderful. Not problem carrying full sheets of dry wall, plywood, etc. Rides like a luxury car. Guess I don't understand the short bed craze.
2017 F.R. Vibe 251RKS
2018 Ford F-350 Power Stroke Diesel
1929 Ford Standard Roadster
1931 Ford Deluxe Roadster
1976 Triumph Spitfire 1500
Oregonian is offline   Reply With Quote
Old 10-08-2020, 04:20 PM   #12
The dually Ram 3500 Mega Cab has a 6'4" bed.
05 Cummins 2014 Blue Ridge 3025rl.
bucky53 is offline   Reply With Quote
Old 10-08-2020, 04:29 PM   #13
Grammar Pedant
67L48's Avatar
Cool story.
Old 10-08-2020, 04:33 PM   #14
Definitely a long bed for that truck. I had the short bed F250 as well and went to an F350 DRW long bed and don't regret it. I simply could not put as much in the bed of the F250 as I can with the F350, including dry wall, plywood, 2 x 4 x 8's and other longer building materials too.
You'll be able to put a bed tool box in the F350 and still have plenty of room for your hitch, which would be really tight with the short bed.
One of the other selling points for me with the long bed is I have lots more clearance from the front cap of my 5'er to the cab. Now I can make unbelievably sharp turns with it I could not with my F250 without hitting the cab.
GPs37FLH is offline   Reply With Quote
Old 10-08-2020, 08:58 PM   #15
I have owned both short and long bed. I have settled with a F350 long bed, single rear wheel crew, diesel. My fifth wheel is about 14000#. I would go with DRW long bed on the next purchase and may consider a F450. I did not have a slider in my short bed and there was no problem.
Grumpy7159 is offline   Reply With Quote
Old 10-09-2020, 10:36 AM   #16
If you have already ordered it how can you not know what you are getting? Don't you know what you ordered?
yukongold is offline   Reply With Quote
Old 10-09-2020, 11:04 AM   #17
Real men do not drive short beds !
wanderingbob is offline   Reply With Quote
Old 10-09-2020, 11:19 AM   #18
Real trucks donít have spark plugs !
dnicoll is offline   Reply With Quote
Old 10-09-2020, 11:37 AM   #19
DELI MAN
Ordered DRW today and got Coach
You are absolutely right. Doesn't come in short bed. I ordered it long but if I need to change any details I have until November 1st. I sometimes post and make mistakes. Thanks for the help. I really appreciate it.
Old 10-22-2020, 07:31 PM   #20
Go long my friend, I just upgrade to a GMC Sierra, 3500 with the Duramax, I was lucky to find a great deal on what I call never used truck, 4 years old and it only had 22,000 miles on it.
Point is you will never go wrong by having the extra space to cary those items your wife can't camp without. Not knowing what trailer you have or plan to buy you will never have to get a slider hitch if you go t a fifth wheel which is a considerable savings.
skipatroller is offline   Reply With Quote
bed
