Originally Posted by reverand2000
Is it normal for the receiver piece of the hitch to be loose? I have looked at other hitches and all seem to fit the same. Why would you not want the hitch to be a snug fit? I can slip a 1/8 piece of metal stock into the hitch to tighten but wonder if I should?
With out the metal lots of movement and noise.
2014
FR3 30DS
I've welded a washer on mine and ground it down on the inner side to create a wedge.
I also remove my hitch after every use so it won't rust in. Used to work for a mechanic shop / towing shop and had a truck come in that wanted hitch removed. Rusted in so bad even with a tow truck winch hooked to it, it wouldn't come out
I also hate the rattle but a simple washer / wedge cures the problem.
