Old 04-19-2020, 09:54 PM   #1
Mail-order source for chain?
Hello. Having installed a Propride P3 on my Mini-Lite 2507S, I need to extend the safety chains by 1'. I thought I found the right material at Lowe's but it was rusting within 24 hours. Can someone direct me to a galvanized product I can buy online? I need 2 x 1', precut. Everything I found at Home Depot or Lowe's is not galvanized.
- 2016 Ford F-150 SCrew Lariat 4x2 3.5L Ecoboost, 1700# payload
- 2020 Rockwood 2507S
chriscowles is online now   Reply With Quote
Old 04-19-2020, 10:06 PM   #2
rsdata's Avatar
have you tried lowes dot com or homedepot dot com?
they both carry way more online then they carry in the stores...
"Freedom is never more than one generation away from extinction. " - Ronald Reagan
“Too much of anything is bad, but too much good whiskey is barely enough.” – Mark Twain
2014 Shamrock 183
Old 04-19-2020, 10:12 PM   #3
etrailer.com has safety chains: https://www.etrailer.com/s.aspx?qry=Safety+Chains
-Qwkynuf
2003 F150 Supercab 4x4, tow pkg, 3.55 gears
2020 Flagstaff Micro Lite 21DS
Qwkynuf is offline   Reply With Quote
Old 04-19-2020, 10:14 PM   #4
You'd probably be better off buying a safety chain that is the length you need rather than trying to add a chain to it.
Try etrailer.com. Their site gives both length and towing weight.
Edit: Posted at the same time as the person above.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 04-19-2020, 11:06 PM   #5
dbledan's Avatar
On my trailer there was no way to remove and reattach the safety chains. I did manage to pull them off the trailer when fastening them outside the P3 once...don't do that. I had to find a mobile welder to weld them back on in different places on the frame instead of the Micky mouse common connection at the bottom of the tongue FR did.
For your chain problem propride does sell an extension kit which is what I used. I did not need the electrical extension.
https://store.propridehitch.com/exte...r-propride-3p/
Etrailer is also good and if you call them it's even easier to get help.
dbledan is offline   Reply With Quote
Old 04-20-2020, 04:41 AM   #6
Member: Old Man Club
RockDodger's Avatar
Originally Posted by Qwkynuf View Post
Anything I ever buy "hitchwise" I get from ETrailer. I have been using them for 10 years. They have everything and I trust them implicitly. I'm sure they will have what you need.
"Walk softly...and carry a lot of tools!"
2016 Ford F250 Super Duty Crew Cab, 4x4
2021 Palomino Puma 27RLSS
RockDodger is offline   Reply With Quote
Old 04-20-2020, 06:52 AM   #7
The kit Sean sells is $50. I need only the chain so I'd be paying (effectively) $25/ft for two feet of chain. Also, I read somewhere that what he supplies is lighter that what is already on the Mini-Lite.
I cannot tell if what I see online on Home Depot and Lowe's is the same chain as what comes in the trailer, and I want it precut. Other than a hacksaw, I don't have a way to cut it myself and I already have the necessary double-Clevis connector links. It's easy to disassemble and reassemble those to extend the original.
I'll call eTrailer and discuss with them.
Old 04-20-2020, 07:44 AM   #8
Contact Hensley MFG they have the "12" Safety chains with the C shaped Quick connects for 17.50$, Exactly what you are looking for! Youroo!!
Old 04-20-2020, 08:42 AM   #9
You can also try Buyers Products and anyone that sells TexTrail/Nuera Trailer Supplies.
I've bought trailer related items from both and found them reasonably priced.
I bought two complete safety chains w/hooks for about $15 about a year and a half ago from a TexTrail dealer.
Days Camped: '17=30 '18=51 '19=58 '20=98
Old 04-20-2020, 12:34 PM   #10
satdog01's Avatar
Our Tractor Supply has gav chain and links to add more chain. Used them on last trailer, also had to swap out hooks as the ones from FR were to small to connect to the GMC HD I had at the time,
2020 Georgetown 31L, Safe T steering, Sumo springs, Onan Geny
2015 GMC Canyon 4X4 TOAD w/Blue Ox tow plates
Pepper 🌶 Pomeranian rescue 368 nights as camping buddy
Days camped in FR, 2011-12 = 77, ‘13-14 = 98, ‘15 = 52
‘16 = 77, ‘17 = 81, ‘18 = 44, 19’ = 83, 2020 = 41
Retired :
satdog01 is offline   Reply With Quote
Old 04-20-2020, 12:40 PM   #11
I use McMaster Carr, they have all kinds of chain including stainless steel.
aircommuter is offline   Reply With Quote
Old 04-20-2020, 01:04 PM   #12
Tundra 2014
Chain
If you have a Tractor Supply Company near by, you can get a piece of piece of chain and connectors to fit needs. Get the med to higher grade of chain. Maybe cheaper, no shipping and you get exactly what you need. I found the premades were too short for my needs.
Tundra 2014 is offline   Reply With Quote
Old 04-20-2020, 01:46 PM   #13
West Marine or Ace Hardware would probably have it locally. Galvanized chain is used for boat anchor ropes between the anchor and the anchor rope. I have seen it at both stores in Florida. If you have a Tractor Supply store locally, they may also have what you are looking for. Any of those places have it in bulk, cut to length.
PenJoe is offline   Reply With Quote
Old 04-20-2020, 06:43 PM   #14
A boat dealer would have it.
mnoland30 is offline   Reply With Quote
Old 04-20-2020, 10:20 PM   #15
We have a Tractor Supply nearby. I didn't think of that. They'll be my first stop. If they don't have it (they probably do) I'll hit the Ace Hardware across the street from them.
Old 04-22-2020, 10:26 AM   #16
I couldn't find hot-dipped galvanized chain at Tractor Supply or Ace Hardware. In the end, I bought it at e-rigging.com:
https://www.e-rigging.com/three-eigh...Grade-43-chain
