I am on my second Master Tow dolly. The first one did not have surge brakes and there were two problems with that dolly. First, after going through U.S. Customs at the Blue Water Bridge, Ontario, CA to Michigan they directed me through a maze of Jersey Barriers that caused all traffic to stop while I barely made it through the maze with my wife directing me from the ground. When I stopped at the rest stop a few miles away I found one of the directional lights hanging by the wires. Torque from the very tight turns cracked the lens bracket that holds the light in place. I duct-taped it until we got to our campground. Seeing the bracket split on the bottom, I re-applied the duct tape and left it that way until I sold it last Spring.
After about 4-5 years of use of that dolly, I noticed the fenders were vibrating while underway. The fiberglass cracked by the 3 mounting bolts is noticeable on the inside of the fender. Also one of the metal mounting brackets for the fender cracked also. I had that welded by a local prison workshop, and for the fender, I attached metal reinforcement sheet metal, bought at Home Depot, cut and shaped to the fender contours, and drilled holes to attach with larger washers. I also used construction adhesive to attach the metal sections to the fenders. Never budged after that fix.
After putting over 50K miles on that dolly I sold it last Spring and bought a brand new MT dolly with surge brakes. Combined with our coast-to-coast trip last summer and through the whole camping season in excess of 10K miles I have not had any issues with the new dolly. Before next camping season, I do plan to add larger washers to the mounting bolts hoping to spread the stress over a larger area and hopefully to avoid the fenders from cracking like the first dolly's.
sherman12 and The Fabulous Miss Barb
2014 SportsCoach Cross Country 360DL DP
Former 2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
