04-11-2021, 05:18 PM
Max 5th Wheel Pivot Angle
Just completed my first weekend trip with the arctic wolf 3660. All went great but being the first time towing a 5th wheel had a question. Have a b&w companion slider, what is the max side to side pivot? The exit to the campground has a decent incline followed by direct 90 onto flat ground. Currently have 8" of clearance between the camper and top of bed rails. Turning off that incline today the bottom of the camper hit the top of my tri fold tonneau cover that was folded up. Is this too much of a angle to the side? What can this hitch head handle and what happens if that is surpassed? Should I raise me hitch one level its on the lowest right now.
04-11-2021, 08:11 PM
It's really hard to tell from photos because of camera angles but you already look nose high on the 5th wheel (even with what looks like a lot of squat on the truck) so raising the hitch probably isn't a good idea. Besides, 8" of clearance should be plenty. 6" is the usual recommendation.
When zooming in on your photo, one of the drawbacks of the trifold bed covers is the amount they stick up when folded. You might think about a roll up style or remove yours during travel.
04-11-2021, 08:25 PM
I'm surprised how squatted this looks with a 350. Granted I have a long box but a a little higher hitch weight and it hardly squats at all.
Side note: that combo does look nice together!
2021 Wolfpack 315Pack12
2014 Ford F350 6.7L Diesel
2019 Indian Chieftain Dark Horse
04-11-2021, 08:30 PM
Thanks! I'm surprised as well and confused why it is myself
04-11-2021, 09:33 PM
Maybe on the way out, you can fold your trifold up against the rear window. No sure if they all do that but mine does.
Just be sure not to turn so tight that you hit it. Then once your off the incline, you can lay it back down.
04-12-2021, 09:31 AM
I have a short bed truck with a TRI-Fold Tonneau cover also. But I take my cover off and leave this in the garage at home when ever I tow my fiver. Just one more thing to worry about so, the cover stays home.
As far as the rear squat I would do two things. First weight the truck and trailer to find out what the rear axle weight is. I would also look into an air bag system for your truck. I use the Air Lift LoadLifter 5000 series with an onboard wireless air compressor Gen 3, Kit 72000. This keeps the truck level when I am towing.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
04-12-2021, 09:45 AM
I ordered some firestone air bags, going to see if I have time after work to take it to the scales
04-12-2021, 02:51 PM
In the picture it also looks like the pin box is behind the rear axle. Sorry after zooming in I am wrong.
2017 Crusader Lite 29RS 5er 2018 Silverado 1500 5.3
04-12-2021, 03:52 PM
Hitch
Looks like the hitch is way back. Do you have the slide engaged? With my F-350 when 14K trailer is attached, less than 1 1/2" squat. Maybe just the way the photo is taken.
04-12-2021, 03:56 PM
It is a slider and it is locked in the forward position
04-12-2021, 04:19 PM
Hitch
TV is f-350?
04-12-2021, 06:50 PM
Went and got weighed and here are my numbers. Now this was after work so not completely camp ready, I did not have the kids, propane are about half full and no clothes in the camper but none of that should effect it too much. Also measured total sag is 1-3/4" so maybe my picture just looks off and it really isnt?
04-18-2021, 01:35 PM
Wanted to update, I measured and only about 1-3/4" of squat. That picture is messed up, I took a new one this weekend. Does this look better? Bought air bag but think Im going to return them as it rides great right now
04-18-2021, 02:44 PM
Yea that looks a lot better! I was wondering if the first picture was an optical illusion
04-18-2021, 02:52 PM
X2
That's why I said it's hard to tell from photos.
Camera angles can make things look completely different.
Even in your last photo, the shadows on the sidewalls appears to look like delamination!
